I count well? The resistor for one should be: 420 ?? and times 5 now?
Nie, dziękuję Przekieruj mnie tamjas2010 wrote:exactly, from the beginning, I am asking you to calculate the resistor, the formula gives me strange values
WoZaj wrote:According to the link provided by you, this LED bulb draws a power of 3W.
You should have a 5W load for CAN.
So you do this:
You connect this LED bulb (YOU WILL NOT CHANGE NOTHING IN IT) in place of the old bulb.
From the side of the plug you connect an additional resistor PARALLEL.
Since you have to lose 2W on it, this resistor should be at least 3W (preferably 5W) and should be 75 Ohm.
The resistor will be warm.
And that's all.
mendozek666 wrote:Hello
It seems to me that the problem with these leds is caused by one integrated circuit that is located in the comfort module or the BSI module.
I did this recently in my car.
After inserting all the LED bulbs inside the car and in the trunk, after closing the car with the remote control, the bulbs glow a little. The voltage measurement in this case is around 6-7V. I replaced one bulb with an old tube one and it's ok. Now all goes out to zero.
I will add that in my module it is the U4791B chip and it is probably called a car lamp failure monitor or something like that.
The system checks the set current consumption threshold, and after replacing ordinary lamps with LEDs, it is probably smaller, so problems with possible errors or turning off lamps with LED bulbs.
Regards
jas2010 wrote:
maybe that would be enough
http://www.sklepledowy.pl/pl_PL/p/Rezystor-0,25W-560ohm-dla-Zarowek-Led/525
jas2010 wrote:You did not understand, it was supposed to be for my friend mendozek666
what should I check?
Moderated By trymer01:Regulations, point 3.1.19. Do not send messages on archival topics if this is another question, in particular other than the questioning person. Out of respect for the questioner, create your own topic. You can only add a solution to the problem.
3.1.13. Take care of linguistic correctness and follow the rules of netiquette. Do not post messages that make it difficult to deduce what their author wanted to convey.
3.1.18. Do not send links that will cease to be active after some time. This will make the discussion meaningless.
3.1.11. Don't post messages that add nothing to the discussion.
jackins wrote:Hello,
I connected the LEDs without the module - 3 cables from lamps + and - and + control room.
+ control connected to the parking lamp
- connected to the akku.
+ after the ignition switch to the ignition module in the cabin under the glove box.
TL;DR: Switching from a 5 W W5W bulb to a 3 W LED cuts current by about 40 %, triggering Skoda CAN-bus errors; “The resistor will be warm” [Elektroda, Anonymous, post #14604392] A 75 Ω / 5 W shunt restores the expected 350 mA load.
Why it matters: The right resistor stops flicker, dash warnings, and premature LED shutdown.
• OEM W5W (T10) parking bulb: 5 W @ 12.8 V, 0.39 A [Osram W5W Datasheet]. • 5×5050 LED replacement: 3 – 4.2 W draw [Elektroda, jas2010, post #14603733] • Recommended shunt: 75 Ω, ≥5 W; dissipates ≈2.6 W at 14 V [Elektroda, Anonymous, post #14604392] • White 5050 LED Vf: 3.0 – 3.4 V @ 60 mA [Cree Spec Sheet; Elektroda, jas2010, #14604261]. • Power check formula: P = U² / R; e.g., 14 V² / 75 Ω ≈ 2.6 W [Ohm’s Law].
