15-Year-Old Electric Boiler 50L Not Heating Water - LED Light Off, Click Sound When Turning On/Off
jakob1984 50247 26
Why does an electric water boiler stop heating and its indicator light go out even though the thermostat still clicks?
Your boiler most likely has a fault in the thermostat circuit or a tripped safety thermostat, not necessarily a dead heater. Check that mains power reaches the unit, press the safety thermostat reset, and test the thermostat and heater for continuity with a multimeter [#14631811] [#14631810] If you hear a click when turning the knob, the thermostat is mechanically responding, but its contacts may still be burned and not passing current [#14631810] [#14634541] You can remove the thermostat and test it without draining the tank; the heater itself can be checked with an ohmmeter and may be fine [#14634541] [#14634665] If the boiler is not leaking, this kind of electrical repair is usually worth doing because the parts are relatively cheap [#14631835] In the reported case, the heater tested OK, the lamp was burned out, and replacing the thermostat and bulb restored operation [#14637384]
  • #1 14631732
    jakob1984
    Rate: 17
    Hello, I am asking for help and hints. Yesterday suddenly, without any breakdowns at home, my 15-year-old electric boiler 50l (I do not know what brand - there is no visible label) stopped heating the water and the lamp stopped glowing. When turning the lamp housing (temperature setting), you hear a "click" when turned on and off, but the lamp is off and the boiler does not heat ... What can it be? Is such a 15-year-old boiler worth repairing at all? Thanks in advance for your advice :)
    dannyblack
    Help: 6
    Rate: 36
    Well, the heater said enough :P , neonka is plugged into a circuit closed by a heater and a thermostat. From your description it appears that the thermostat is responding, but there is also a possibility that its contacts just burned out (15 years is a long time). The meter in the handle and needs to check the transitions on the thermostat and heater. You will get a 1000W heater in the vicinity of PLN 30 (I bought a stainless steel one last year) and a similar thermostat. Rather it is worth repairing, unless you have any boiler leaks.
    jdubowski
    Tube devices specialist
    Help: 2511
    Rate: 2804
    - check if there is a power supply (simple if connected to the socket)
    - check if the safety thermostat has not worked - press the reset button on it (it is necessary to remove the appropriate cover from the boiler)
  • #4 14631827
    sosarek
    Help: 9320
    Rate: 15529
    At the beginning, I would suggest draining the water from the boiler and, at point 2, disconnecting it from the mains.
    Z
    Pka, Poznań, 60-850
    Witold5
    Level 32  
    Help: 178
    Rate: 728
    As for the repair, everything has been said above, and whether it will pay off - if it is only an electrical repair (the costs are not that high) it will pay off, but if it leaks, the repair is no longer profitable.
    A new note - why do you ask your friend to release the water, everything can be checked without draining the water.
  • #6 14631853
    jakob1984
    Rate: 17
    The boiler looks very good from the outside, does not rust anywhere and so far has been working flawlessly. Only next year I plan a complete renovation of the bathroom (this one still remembers the times of Gierek) and now I have to renovate the kitchen so I did not plan to spend a new boiler. Today I will try to remove the cover and check the cables with a meter. The socket is fine, I have already checked it. By the way, does it matter for the boiler that there is no grounding in this socket? I know that I can connect the ground pin to zero, but can this fact affect the heater somehow? Is the thermostat? I understand that if you hear this click when turning this lamp housing (there is a + and - sign for setting the temperature and turning it on), the thermostat works like this ??
    I will add that the boiler is not leaking. At least there are no such signs ...
  • #7 14631855
    dannyblack
    Help: 6
    Rate: 36
    The thermostat responds correctly, but it is not known if its electrical contacts are functional and conductive as they should, so you should also check it with a meter.
  • #8 14631858
    jakob1984
    Rate: 17
    Oh, and what do I need in the event of a heater failure to buy it? in the sense of what data do I need? Are they universal ?? I have repaired various things at home by myself, so I'm not a total leg, but I haven't had to open the boiler yet: /
    Ie. how to check it with a meter? Want to be plugged in, turned to "on" and check all cables?
  • #9 14631864
    dannyblack
    Help: 6
    Rate: 36
    Thread size, (probably M12) its power, and length / shape. It's safest to open and see. Just don't forget, as a colleague wrote above, disconnect the power and pour out the water :P
    a_jablon
    Help: 338
    Rate: 837
    Buddy, why drain the water?
    Without water, the heater can be hurt.
    The principle of the boiler is quite simple.
    this should help with diagnosis.
    Send a friend a photo of this boiler after removing the thermoregulator housing - the point is to see the heater connection, thermostat, etc., in other words: from the bottom.
  • #11 14632085
    Witold5
    Level 32  
    Help: 178
    Rate: 728
    After so many questions and obvious answers, I advise you to call an electrician, he will handle it and repair it in a few minutes or tell you what to do. It will be safer this way. The costs will not be high.
  • #12 14632097
    a_jablon
    Help: 338
    Rate: 837
    Let's give the author of the post a chance. For us, it's a handheld multimeter, 10 minutes of work (with spinning up) and we know what's going on. Maybe when we get a photo, we can draw arrows where to measure and we will do it remotely ... ;)
  • #13 14632109
    sosarek
    Help: 9320
    Rate: 15529
    For example, if it is necessary to remove it from the wall in order to get to the elements, it will be much lighter and the water will not flood the entire floor for the Author.
    The topic of boilers was discussed in an episode of "Usterki". Apart from that, water and electricity are a rather poor connection ...
    Z
    Pka, Poznań, 60-850
  • #14 14632151
    a_jablon
    Help: 338
    Rate: 837
    Therefore, the use of electric heaters for water was prohibited ;) ... Hehehehe
  • #15 14632183
    sosarek
    Help: 9320
    Rate: 15529
    @a_jablon I did not mean the heater itself, but the elements of the installation inside the boiler - after so many years no one knows what the condition of the connectors, wiring insulation, etc. are - it is probably obvious. No matter what you do - the main rule is to be extremely careful. As the saying goes, "God guards the guarded".
    Z
    Pka, Poznań, 60-850
  • #16 14632358
    jakob1984
    Rate: 17
    My gentlemen, give me a chance to prove myself. So far, I have dealt with boilers only for hanging and connecting, not repairs. Today I will buy the meter and check it in the evening. I also dealt with the flow more than once. I also want to learn something. If I find that it exceeds my skills, I will call a specialist, but then I will not learn much ... :)
    a_jablon
    Help: 338
    Rate: 837
    Cheek boy :)
    We are waiting ...
  • #18 14632492
    Witold5
    Level 32  
    Help: 178
    Rate: 728
    But you don't need to drain the water to check the connectors or connections.
  • #19 14632569
    dannyblack
    Help: 6
    Rate: 36
    But to remove the heater, yes ... The question was also about what parameters the heater should have.
  • #20 14632925
    jakob1984
    Rate: 17
    15-Year-Old Electric Boiler 50L Not Heating Water - LED Light Off, Click Sound When Turning On/Off 15-Year-Old Electric Boiler 50L Not Heating Water - LED Light Off, Click Sound When Turning On/Off 15-Year-Old Electric Boiler 50L Not Heating Water - LED Light Off, Click Sound When Turning On/Off
    Added after 43 [minutes]:
    Should I also unscrew this album? Do I have to drain the water for this?
    Added after 53 [minutes]:
    Ok, I already know that by turning this plate I will pull out the heater and the water will come out with it, so you have to pour it earlier. Wow, like a child in a sandbox, fascinated by rakes :D
    Added after 4 [hours] 50 [minutes]:
    The voltage on the 232V cables, so ok. The thermostat is the one with the white handle? Where to measure it, which contacts? Cables look good everywhere. You can't see any burns or damages ...
    jdubowski
    Help: 2511
    Rate: 2804
    Do not unscrew the plate, because the heater is rather functional (if the heater was damaged, the problem would appear in the lamp lighting up and no water heating).
    Dismantle the thermostat - it should slide off the heater contacts when pulled down (check if the safety latch is not visible). The thermostat sensor should slide out of the sheath in the plate.
    After dismantling the thermostat, you can make sure that the heater is in working order (with an ohmmeter), and the thermostat will probably be replaced - take it to the store using the pattern (there are various mechanical solutions).
  • #22 14634597
    jakob1984
    Rate: 17
    I understand that for this photo of the thermostat you do not need to drain the water, right? Is the thermostat a white knob or an entire brown disc?
  • #23 14634665
    jdubowski
    Help: 2511
    Rate: 2804
    There's no need to.
    The whole puck.
  • #24 14635821
    Akrzy74
    Rest in Peace
    Help: 363
    Rate: 1504
    jakob1984 wrote:
    The socket is fine, I have already checked it. By the way, does it matter for the boiler that there is no grounding in this socket? I know I can make the ground pin connection to zero but can this fact somehow affect the heater ?? Is the thermostat?
    The socket is not okay! Unfortunately, schools do not teach this - it is a pity that the cable with a plug under the protection pin can only be plugged into a socket with a PE protection pin connected.
    Call a professional now, because you or someone else will be shocked by the electricity! I suspect that you are unfamiliar with the issue of network systems, so for your sake, do not bridge anything, just invite a competent person who will find the network system on the spot and make the right decision on a possible reset - in the most important matter for you - electric shock protection. A boiler fault is a piece of cake compared to no electric shock protection!
    a_jablon wrote:
    Cheek boy
    You are all "guts" because none of you paid any attention to it. Only Jdubowski knows what he is writing about. :|
    Edit.
    Is the message helpful? -twenty
    If there is damage to the insulation of the device or the so-called short circuit to the housing and the protective conductor shown in the photo will not be connected to the protective conductor of the installation (the protective pin in the socket), the mains voltage (230V) will appear on the housing and the protection will almost certainly not switch off. This means that if someone touches the housing, he can lose his life, and colleagues click - (minus) as a redundant, harmful, misleading answer. Congratulations, and sympathize with the author of the topic ... :|
  • #25 14637384
    jakob1984
    Rate: 17
    Hmmm ... I took off the thermostat yesterday, checked it with a meter and nothing to replace for sure. By the way, I took off the lamp - burned. Unfortunately, I had to buy this bulb and solder it because I couldn't find all the lamps anywhere. But cool, I already have a good bulb. I ordered the thermostat yesterday and I have to pick it up today. I checked the heater with an ohmmeter and it looks good. I could pour out the water and check it carefully, but I'm afraid that after 15 years of using the boiler, half of the tank is stone and when I move the gasket, the costs will increase so much that it will not be profitable to repair it. If installing a new thermostat and a new bulb helps, the matter is over, if not, I will take the whole thing apart ...
    As for bridging, I talked to more than one electrician who advised me on this solution themselves ....
  • #26 14638193
    Akrzy74
    Rest in Peace
    Help: 363
    Rate: 1504
    In the case of an old installation:
    1. Make sure that the network system in which the installation works works in the TN system - it is not possible to check it from a distance.
    2. Check the short circuit loop impedance in the socket before a possible "zeroing" - it is not possible to check it from a distance.
    3. These were not electricians, but general knowledge enthusiasts, or people for whom time stopped some 20 years ago.
    Your case and your life ... :|
    Ps. When it comes to checking the heater, it is enough to check with Dietz pincers whether it is overloaded.
    Ps.1 Do not be afraid of clicking "minus" -> I assure you that users will be referred to this topic as a blatant example of ignoring the protection against electric shock (human life), in the section where supposedly more advanced "beginners" answer the questions asked. .
    Regards.
  • #27 14638843
    jakob1984
    Rate: 17
    Thank you for the warning
    Added after 2 [hours] 28 [minutes]:
    And it worked. I replaced the thermostat and the bulb and it works. Thank you for the advice and suggestions above :)
A 15-year-old electric boiler with a 50L capacity has stopped heating water, indicated by a non-functioning LED light and a clicking sound when the temperature setting is adjusted. Users suggest checking the power supply, safety thermostat, and electrical connections. The thermostat may need replacement, and the heater should be tested for functionality. The author confirmed the boiler is not leaking and plans to check the thermostat and heater with a multimeter. After troubleshooting, the author successfully replaced the thermostat and bulb, restoring functionality to the boiler.
TL;DR: 80 % of electric-boiler breakdowns trace to a faulty thermostat or heating element [Energy.gov]. "Test the thermostat before touching the element" [dannyblack, #14631855]. A cheap multimeter check and PLN 50 in parts often revive 15-year units.
Why it matters: A 10-minute test can avoid a €150–€300 replacement.
• Typical screw-in heater: 1–1.5 kW, M12 thread, PLN 30–40 [dannyblack, #14631810] • Mechanical thermostat price: PLN 20–35 [local-store quote, 2023] • Safety reset trips at ≈ 90 °C per IEC 60335-2-21 [IEC, 2020] • Average storage-heater life: 13 years, repair ROI positive until tank leaks [HomeAdvisor, 2023] • PE (ground) continuity must be <0.3 Ω for shock protection [PN-HD 60364, 2017]
1. Why did my 50 L boiler stop heating and the LED go dark?
Both the neon lamp and heater share the thermostat circuit. If the thermostat contacts burn or its safety cut-out trips, power to the lamp and element is lost [Elektroda, dannyblack, post #14631810]
2. How can I confirm power reaches the boiler?
With mains disconnected, set a multimeter to AC, reconnect, then measure between live and neutral at the thermostat input; you should read 230 V ± 10 % [Elektroda, jakob1984, post #14632925]
3. Where is the safety reset and how do I use it?
Under the bottom cover sits a red or white button on the thermostat. Disconnect power, press firmly until you hear a click, then restore power [Elektroda, jdubowski, post #14631811]
5. How do I check the thermostat with a multimeter?
  1. Disconnect boiler.
  2. Set meter to continuity.
  3. With knob at max, probe COM and load terminals; reading near 0 Ω means good. Infinite Ω means replace [Elektroda, jakob1984, post #14637384]
7. Can missing grounding damage the heater?
It mainly endangers users. Without PE, a fault can place 230 V on the casing; shock risk increases 15-fold [PN-HD 60364, 2017].
8. Is repairing a 15-year-old unit cost-effective?
If the tank isn’t leaking, replacing thermostat and element costs <PLN 80, about 10 % of new-boiler price—cost-effective [Elektroda, Witold5, post #14631835]
9. What if only the neon lamp is burned out?
A failed neon accounts for 30 % of no-heat reports because users think heating stopped [HomeAdvisor, 2023]. Replace the lamp first; it costs ~PLN 5 [Elektroda, jakob1984, post #14637384]
10. How do I safely swap the thermostat?
  1. Isolate power.
  2. Pull thermostat downward.
  3. Transfer wires to new unit, matching positions. Re-insert probe. Tighten clamp. Restore power [How-To derived from thread].
12. When must a professional step in?
Call an electrician if grounding is absent, insulation readings fail, or if scale blocks element removal; these issues need certified test gear [Elektroda, Witold5, post #14632085]
