Electric Kettle: LED Light On, Plate Not Heating, 200 Ohm Range Resistance Test & Burned Disc
siejson 29289 3
  • #1 16391411
    siejson
    Hello, I have a problem with the kettle yesterday.
    Well, the LED diode does not heat the plate I checked with a meter and electricity to the heating plate comes. I don't really know how to check the resistance, so I switched the meter to 200 ohm range, applied it to the heater, of course, on the off kettle and the meter still shows 1, while on the kettle the results jump
    Can anyone give a hint or a good measure, or maybe it's all from a burned disc ??
  • #2 16391446
    MARCIN.SLASK
    Home appliances specialist
    Help: 1033
    Rate: 2642
    siejson wrote:
    so I switched the range to 200 ohm on the meter, of course, put the heater on the off kettle and all the time the meter shows 1
    So the burned out heater.
  • #3 16391473
  • #4 16392558
    nioop
    Help: 503
    Rate: 3329
    Just like a colleague above,
    I presume that this is a typical Chinese meter, which probably does not work anymore, so at this point it is difficult to determine whether these indications are correct ...
    I had a kettle a few days ago, total Chinese with the same symptom / The thermostat was broken.
    It is worth checking again on a certain meter measurements without connecting power.
    Kawa i Naprawa - Serwis AGD
