Earthing of the F / UTP twisted pair - how and where?
patrykry 21621 9
How should I ground an F/UTP twisted-pair installation, and at which ends should the shield be connected?
Ground the shield at the patch-panel end by bonding the FTP patch panel to the cabinet/earthing strip; if the socket end is unshielded, do not connect the screen there and cut it flush with the insulation [#14707943][#16710243] Some replies say that grounding only one point is enough in practice, preferably in the patch-panel cabinet [#14707563] Another reply says that if the cabling and terminations are fully shielded, the shield can be grounded at both ends, especially for lightning protection, but if you do that, use proper FTP copper components rather than CCA [#14708745] One reply also notes that if there are no industrial machines and the environment is just ordinary office equipment, UTP may be a better choice than FTP [#14707563][#14708745]
  • #1 14707420
    patrykry
    I know that the topic has been rolled over several times, but I have not found an answer that satisfies me. I have a LAN installation to do, 90% of the twisted pair will go next to 230V current cables, so the choice fell on the F / UTP twisted pair. I have a patchpanel and FTP sockets. The switch has sockets with a screen + ground on the back, the router has the same. At what points should I ground the twisted pair. Opinions differ, some say that at one point - on the patch panel. Others say that a patch panel and a socket, and others that a patch panel and a device connected to a shielded socket.
    I have a grounding strip to which I can bring the grounding of the patchpanel.
    Next to the RJ45 sockets there are 230V sockets (red with protection), the grounding of which is also connected to this earthing strip.
    I am asking for advice.
  • #2 14707563
    mbo
    Help: 2333
    Rate: 845
    You only have to ground in one place - preferably in a patchpanel cabinet.
    Do you power any motors or other industrial equipment with these power cables?
    If not, shielding may be more trouble than good.
  • #3 14707611
    patrykry
    from motors, it's just the gate actuators. The lighting (fluorescent lamps), computer equipment, printers, etc. are also supplied. The current cables and the twisted pair should be run next to each other, the twisted pair at 90% of its length is to go next to the current cable, and in some places it is to cross with it.
    I would like to get 1GB / s on this
  • #4 14707943
    jimasek
    Help: 3783
    Rate: 2681
    You buy an FTP patchpanel on which the twisted pair is grounded during assembly (metal bands included) and the patchpanel itself is grounded to the cabinet. From all philosophy.
    smario11
    Help: 140
    Rate: 120
    It should be grounded on both sides. If you do only on a patch panel, it is ok. All the muck that will fly from other cables will be removed, but when it comes to protection against lightning, it is grounded on both sides
    If there are no industrial machines with 20kW power consumption, only an ordinary office machine, I would do UTP.
    If you are going to do this, it will be copper cables, not CCA. Better UTP copper than FTP CCA
  • #6 14717464
    patrykry
    Thank you for your answer. Case solved, we put the UTP. Maybe you have some proven installation cables? At the moment, drak and molex cabling looks interesting.
    jimasek
    Help: 3783
    Rate: 2681
    patrykry wrote:
    draka and molex.
    I would add Madex.
  • #8 16709206
    wojtek_n
    Should the FTP twisted pair be grounded in only one place (e.g. patchpanel in a cabinet)? On the other hand (socket, plug) they can be unshielded, ungrounded (I cut the screen off)?
    And what if the FTP twisted pair goes from cabinet A (grounded on the patchpanel) to cabinet B (or grounded here on the patchpanel)? This is to power another part of the building.
  • FTP shield should be grounded only at the patch panel
    #9 16710243
    jimasek
    Help: 3783
    Rate: 2681
    Since the socket is unshielded, you will not connect the screen there. You cut the screen flush with the insulation. Of course, such an installation is not art-compatible.
    This is how you actually earn money in the FTP Pachpanel, which should be grounded together with the cabinet.
  • #10 16711403
    wojtek_n
    Do I ground at both ends (in both patch panels) or only in one place?
    The twisted pair goes from the cabinet to the cabinet (powering another part of the building).
The discussion revolves around the grounding of F/UTP twisted pair cables in a LAN installation, particularly when running alongside 230V power cables. Participants suggest grounding at a single point, preferably at the patch panel, to avoid complications from electromagnetic interference. Some recommend grounding at both the patch panel and the connected devices for enhanced protection against lightning. The consensus leans towards using UTP cables instead of FTP if the environment does not involve high-power industrial equipment. Recommendations for installation cables include brands like Drak, Molex, and Madex.
