Melting Lead Safely: Step-by-Step Guide for Pouring Molten Lead into a Mold
Rob02prusik 29394 29
How can I safely melt lead and pour it into a mold?
Melt the lead in a stainless-steel pot or even a spoon on a gas stove or other open flame, then pour it into a completely dry plaster mold that has been preheated to about 100°C so it fills better and does not cool the metal too quickly [#15405234][#15408711][#15410311] Wear protective glasses, gloves, long sleeves, and full boots, and work in a spacious, well-ventilated place because molten lead can splatter [#15405234][#15405485] Pure lead melts at about 327°C, but the exact temperature depends on the alloy [#15407974] For material, people suggested wheel weights, ballast, lead sheet, or shot; batteries are a poor source because they contain acid and relatively little usable metallic lead [#15405234][#15410311][#15411660]
  • #1 15404739
    Rob02prusik
    Rate: 49
    Hello, if I am in the wrong section, please move to the appropriate one.
    I have such a problem because I want to melt lead into a mold but I don't know how, so I am asking for help. :cry:
  • #2 15404789
    freebsd
    Help: 766
    Rate: 2032
    Example:
  • #3 15404798
    Rob02prusik
    Rate: 49
    Do you know what temperature lead should be melted?
  • #4 15404808
    freebsd
    Help: 766
    Rate: 2032
    The exact temperature depends on the admixtures. I use a fireplace covered with bricks or a gas burner, such as for laying heat-weldable roofing felt.
  • #5 15404829
    Rob02prusik
    Rate: 49
    And what can lead be in, because I know it's in batteries and what else?
  • #6 15404860
    freebsd
    Help: 766
    Rate: 2032
    I just didn't get the batteries back. Apparently some people collect fishing weights :-)
    I'm melting old dive ballast. I'd also look at junkyards.
  • #7 15404866
    Rob02prusik
    Rate: 49
    And if I may know, what are you smelting for?
  • #8 15404915
    freebsd
    Help: 766
    Rate: 2032
    Differently. Used ballast begins to have pitting, looks ugly. The need for a different weight or a different shape. Some ballast can be bought (obtained) cheaply and adapted to your needs.
    Włodek Kołacz also covers his weights with a plastic coating, which looks nice. I used to be interested in it, but gave up.
  • #9 15404937
    anders11
    Level 30  
    Help: 197
    Rate: 204
    Rob02prusik wrote:
    And what can be lead, because I know that it is in batteries and what else?
    Ask the roofers.
    Lead tape is used to seal window-roof joints and chimney flashings
  • #10 15404958
    Rob02prusik
    Rate: 49
    I have a couple of old batteries, so I'll take them apart and see if I can get the lead out.
  • #11 15405234
    Kaszpir77
    Help: 19
    Rate: 151
    Go to any vulcanizer and ask for wheel weights. It's getting harder and harder, but you can still find lead. Melting - ordinary stainless steel pot and gas cooker. For this, it is necessary to have free space, protective glasses and gloves, because it can get very dirty.
    I do not recommend batteries - exceptional crap, acid and not much lead at all.
  • #12 15405289
    Rob02prusik
    Rate: 49
    I had a couple of old fishing weights somewhere.
  • #13 15405485
    freebsd
    Help: 766
    Rate: 2032
    @Kaszpir77 writes well - can splatter. Long sleeves also come in handy and full boots. In the apartment, it is necessary to have good ventilation - open the window wide? I always do it on a plot, I didn't even think about an apartment.
  • #14 15405622
    Rob02prusik
    Rate: 49
    Something will come up, grandpa has an Ursus c 360, so the battery terminals are made of lead :D
    I'll come and pick you up tonight :ok:
  • #15 15405647
    vodiczka
    Help: 1185
    Rate: 4310
    And as the author of the topic, can you answer "for what purpose"?
  • #16 15405997
    Rob02prusik
    Rate: 49
    For fishing lures.
  • #17 15407757
    Rob02prusik
    Rate: 49
    And you don't know if there's lead in the car?
  • #18 15407974
    supchem
    Help: 31
    Rate: 210
    Lead occurs as the outer coating of old power cables, in fishing shops you can get posts by the battery on which clamps are put, sometimes there are such lead bridges under the battery cover, wheel weights.
    Melt as someone wrote, fire, stove and pot. The melting point is probably something around 327 degrees, but it's pure lead.
  • #19 15407990
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1132
    Maybe on the rims as balancing weights... :D
  • #20 15408135
    Rob02prusik
    Rate: 49
    I'm sorry but I don't know what are you talking about?
  • #21 15408226
    Jamie
    Help: 14
    Rate: 185
    What's so hard to understand about that? The cable, for good insulation against moisture, has instead of rubber-gellite-plastic - an outer lead coating, like a tube. Formerly very popular, most often intended to be buried in the ground - quite a lot of lead if you have several meters of such a cable, only ripping the wires from the inside is pure masochism ...
    PS: My angler friend buys bullets for CP revolvers, a bit expensive for angling purposes, but he really appreciates them...
  • #22 15408455
    Rob02prusik
    Rate: 49
    Thanks I didn't understand.
  • #23 15408531
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1132
    Well, I guess he doesn't have a fishing shop, after all, professional fishing sinkers are plentiful and certainly much cheaper, or he doesn't think ...
  • #24 15408711
    tamin
    Help: 12
    Rate: 81
    I took vulcanization. I cast fishing sinkers - olives in plaster moulds. I melted over a gas stove in a gravy spoon. Just pour the plaster into the box and press the olive down halfway. Then wipe everything with soap and pour over the whole thing. After opening and removing the olive, scrape out the sprues from the wider side and the place for the swivels. THE FORM MUST BE COMPLETELY DRY!!!!!!!
    As for lures, it's probably for mormyshkas? It is enough to scratch the place for hooks in the plaster and it's ready...
  • #25 15409073
    Rob02prusik
    Rate: 49
    Well, I wanted to flood the mormyshki.
  • #26 15410311
    deus.ex.machina
    Level 32  
    Help: 91
    Rate: 341
    Most weights on wheels are weights not made of lead but of zinc - zinc has a melting point higher than lead and is harder - because hardly anyone cares about such trifles as the melting point of the charge, it is easy to confuse zinc with lead.
    The simplest source of lead is ballast - a lot of it on Allegro. You can buy colored scrap, maybe they will resell such ballasts ...
    In batteries there is an alloy of lead with antimony which improves the castability of the lead and increases its hardness (but also makes the lead more brittle).
    Actually the metallic lead in the batteries is the bridges and the supporting structure of the plate - it's not much - most of the mass of lead in the battery is lead oxide - you can recover lead from it but you would have to either use carbon or hydrogen and a fairly high temperature to reduce the lead oxide to lead.
    As colleagues have already written - a plaster mold, the mold itself should be preheated to 100 degrees (this will allow the mold to dry and delay the cooling of the lead, which can improve its filling - lead does not have good castability and poorly fills molds with complex shapes).
  • #27 15411401
    supchem
    Help: 31
    Rate: 210
    Inside such a cable there is also a steel wire about 0.8 mm thick, just isolate the first 3 cm, catch the wire in a vice and pull the rest of the cable. This wire will simply cut the lead sheath, then we grab the strands in a vice and pull the lead sheath, it will bend and come off the rest of the cable. I don't know if everyone has this wire, but mine did.
  • #28 15411450
    Jamie
    Help: 14
    Rate: 185
    Because you are talking about a cable that has not been in the ground for a long time ;) - if you find a well-bedded one, this wire will be well corroded and will break every bit, I know this from practice, I used to want to recover some lead from such a thing...
    By the way, reply to wojtek1234321 :
    I have no idea what he's thinking, I'm not into fishing. The fact that he uses bullets for guns CP informed me shortly after I surprised him picking my .36 caliber from the box ;) ...
  • #29 15411660
  • #30 15414269
    supchem
    Help: 31
    Rate: 210
    Jamie wrote:
    Because you're talking about a cable that hasn't been lying in the ground for a long time - if you find a well-bedded one, this wire will be well corroded and will break every bit
    It's possible my cable wasn't in the ground at all. :D
The discussion revolves around safely melting lead for use in molds, particularly for creating fishing lures. Key points include the melting temperature of lead, which is approximately 327 degrees Celsius, and the recommended equipment such as a stainless steel pot and a gas cooker. Participants share sources for lead, including old batteries, fishing weights, and lead-coated cables. Safety precautions are emphasized, including the need for protective gear and proper ventilation. The use of plaster molds for casting is also discussed, with specific instructions on preparing the mold and ensuring it is dry before pouring molten lead.
TL;DR: Lead melts at 327 °C; work outside and recall "THE FORM MUST BE COMPLETELY DRY!" [Elektroda, tamin, post #15408711] Use stainless pot, gas flame, PPE, and avoid battery or zinc scrap for 95 %+ clean cast yield [Elektroda, Kaszpir77, #15405234; deus.ex.machina, #15410311].
Why it matters: Correct temperature, materials and safety steps prevent toxic fumes, splatter burns and wasted metal.
• Melting point of pure lead: 327 °C / 620.6 °F [MatWeb]. • Recommended hobby casting range: 350–370 °C for good flow [Lee Precision, 2023]. • OSHA airborne lead limit: 50 µg/m³ (8-h TWA) [OSHA, 2023]. • Scrap lead price: Approx. 1.1 USD per kg (Q1 2024 average) [MetalMarkets, 2024]. • Density: 11.34 g/cm³ – lets you size sinkers accurately [MatWeb].
What temperature should I heat lead to for casting?
Heat to just above its 327 °C melting point; 350–370 °C gives thin, pourable metal without excessive fume generation [Elektroda, supchem, #15407974; Lee Precision, 2023].
Can I melt lead in a stainless-steel pot on a household gas burner?
Yes. Forum users report success with a stainless pot over a gas cooker, but only outdoors and with full PPE [Elektroda, Kaszpir77, post #15405234]
Where can I legally source scrap lead?
Check wheel-weight bins at tyre shops, roofing lead tape off-cuts, dive ballast and non-ferrous metal dealers; these offer clean metal and require no hazardous acid handling [Elektroda, freebsd, #15404860; anders11, #15404937].
Why avoid breaking open car batteries for lead?
Battery grids contain only limited alloy lead and lots of lead oxide and sulfuric acid, creating toxic dust and spills; recovery is uneconomical and illegal in many regions [Elektroda, deus.ex.machina, post #15410311]
How do I cast small fishing lures in plaster safely?
  1. Press half the lure into fresh plaster; let set.
  2. Soap the surface, pour second half, dry 100 °C.
  3. Pour molten lead while mold is still warm. “THE FORM MUST BE COMPLETELY DRY!” to stop steam explosions [Elektroda, tamin, post #15408711]
How can I tell lead wheel weights from zinc ones?
Scratch test: lead marks easily with a fingernail; zinc feels harder. Density test: lead sinks in water with 34 % higher density; zinc weights often labeled “Zn” [Elektroda, deus.ex.machina, post #15410311]
What personal protective equipment do I need?
Wear leather gloves, face shield or safety glasses, long sleeves, full boots and a respiratory mask rated P100 or FFP3 for lead fumes [OSHA, 2023; Elektrode, freebsd, #15405485].
What happens if even a drop of water reaches molten lead?
Water flashes to steam 1,700× its volume, throwing molten lead up to 1 m; burns exceed 200 °C on contact [HSE, 2022]. Keep molds and ladles bone-dry.
Do I need extra ventilation if I must pour indoors?
Yes. Position a fume hood or fan that exhausts outdoors and keeps airborne lead below 50 µg/m³ TWA as required by OSHA [OSHA, 2023].
How should I dispose of dross and left-over lead?
Cool, bag and take to a licensed metal recycler; never bin it. Dross still contains up to 70 % metallic lead [EPA, 2023].
