Setting Frequencies with Baofeng 888s in Warsaw for Scanning Emergency Services
TheAspartam 49749 10
What frequencies should I program into a Baofeng BF-888S in Warsaw to receive emergency services such as police, fire brigade, and PKP?
You won’t reliably receive Warsaw police, fire brigade, or PKP on a Baofeng BF-888S, because it is described as a 70 cm / 400–470 MHz radio, while those services were said to be on much lower bands or otherwise not really listenable there [#14799023][#15188344][#15275281] One reply suggested looking for police at 170–174 MHz, fire brigade at 148–150 MHz, PKP at 150–152 MHz, and amateur radio at 145–146 MHz, but another said there is silence on those frequencies in the capital and that the 888S is only 70 cm [#14772618][#15188344] In practice, users said you will mostly hear 400–470 MHz repeaters, PMR, and taxi traffic, not emergency services [#14799023][#15276997] Example frequencies mentioned were Sawa taxi 429.600, GLOB 427.025 and 427.100, Merc taxi 418.900/428.900 and 418.925/428.925, City 427.1250/417.2150, Copernicus 417.7250/427.7250, and MPT taxi 419.8875/429.8875 [#15273736][#15275281] If you want real scanning, one reply recommended using an older radio or a proper scanner instead [#15275281]
  • #1 14772552
    TheAspartam
    Hello, I bought Baofeng 888s walkie-talkies with software and a PC-USB cable, these Chinese toys even work well and their advantage is the ability to set other frequencies, and this advantage is a big problem, what frequencies should be set to receive anything, e.g. fire brigade, police, units emergency, PKP, etc. in Warsaw? I know that broadcasting in these bands is prohibited, but reception is not and can be used as a cheap frequency scanner :-) Setting Frequencies with Baofeng 888s in Warsaw for Scanning Emergency Services . Setting Frequencies with Baofeng 888s in Warsaw for Scanning Emergency Services
  • #2 14772618
    kriss51
    Help: 672
    Rate: 482
    You need to scan a bit. Generally, look for the police from 170 to 174 MHz, the fire brigade from 148 to 150 MHz, the PKP from 150 to 152 MHz, hams from 145 to 146 MHz. Look for the rest. Maybe you'll hit something else.
  • #3 14799023
    ostry1234
    I have these radios and they are great, but unfortunately only for the 70cm band, i.e. the PSP police monitoring is out, etc.
  • #4 14947891
    pawelekk24
    Hello, you will only listen to repeaters for 70 cm pmr or taxi on it.
    I think the police are already coded, I have uv-82 but I haven't listened to any station.
  • #5 15188344
  • #6 15268216
    djtrebla
    Help: 15
    Rate: 28
    I have this Baofeng, and as the previous speakers said, you won't listen to much here on this band.
    In the summer, you will occasionally listen to a pilgrimage.
    "Two companies that operate on terminals and voice calls are sporadic."
    More is possible ... listen, but in the intervals between broadcasting there is a "fart".
    Taxi GLOB'us broadcasts non-stop and on Friday and Saturday evenings with nights it's chaff there.
    The range of GLOB'us Branszczyk near Wyszków on Bs 888s was no problem.
    I noticed in the BS-888s software there are no all CTCSS tones, maybe I have the wrong program, I don't know ...
  • #7 15269234
    yes2mike
    Help: 258
    Rate: 322
    The SAWA taxi complaint channel is also cool. 1/3 of the conversations conducted there are fights ;)
  • #8 15269752
  • #9 15273736
    yes2mike
    Help: 258
    Rate: 322
    Sawa complaints 429.600
    Glob 427.0250 and 427.100, but I don't know which one is with the data. Frequencies given are output (duosimplex).
  • #10 15275281
    djtrebla
    Help: 15
    Rate: 28
    The GLOBus has 2 channels. One is general and the other is private.
    Master globe (output) 427,025 CTCSS and DCTSS tones I won't give you so you don't dirty them there. :P
    I talked to the Grosiks, they have radios, but they have free phones from the company and they practically do not answer on the radio.
    Verify these frequencies because I gave up ... work.
    Merc taxi 418.900
    428,900
    418.925
    428.925
    Mermaid, City427.1250
    417.2150
    Copernicus 417.7250
    427.7250
    Corporate taxi 418,900
    428,900
    MPT taxi 419.8875
    429.8875
    Unverified...
    427.115
    449,680
    429,300
    429,930
    427.100
    And that's it.
    During the day you won't hear much, wait until the evening, or as in the previous post I wrote Friday, Saturday evening with night.
    Modern radios, wouxun/baofeng and the like, are deaf outside the bands for which they are intended.
    I recommend a radio from the early 90's Alan, Adi, Rexon, Sender 450, or a scanner.
  • #11 15276997
    kriss51
    Help: 672
    Rate: 482
    Nonsense. They receive these frequencies without any problem and not only these. Practically from 400 to 470 MHz they work without any problems.
The discussion revolves around setting frequencies on Baofeng 888s walkie-talkies for scanning emergency services in Warsaw. Users suggest scanning frequencies for various services: police (170-174 MHz), fire brigade (148-150 MHz), and PKP (150-152 MHz). However, limitations are noted, as the Baofeng 888s primarily operates on the 70cm band, which restricts access to certain emergency communications. Users mention the sporadic nature of transmissions and the potential for listening to taxi communications, particularly from GLOB' us and SAWA. Specific taxi frequencies are provided, including 427.0250 MHz for GLOB' us and 429.600 MHz for SAWA. Overall, while the Baofeng 888s can receive a range of frequencies, the effectiveness for emergency services is limited.
