Understanding Broadcast Frequencies: Do Fire Brigades or Police Share Frequencies?
7548 18
Do the Polish fire service, volunteer fire units, and police use one shared radio frequency during major incidents, or do local units switch among assigned channels?
They normally do not all transmit on one shared frequency: services have assigned bands and channels, while fire-service networks include local, provincial, nationwide, rescue-and-firefighting, and cooperation channels. [#16641711] During operations, units may move to one of eight rescue-and-firefighting channels so they do not block the region’s main channel, and repeaters may provide coverage in difficult terrain. [#16650235] Radios are generally preprogrammed with approved channels rather than allowing field personnel to choose arbitrary frequencies; these may include the unit’s own and superior command channels. [#16641481] Major incidents can use inter-service cooperation channels, and trunked systems may allow different services to share channel groups, but that is coordinated network use rather than everyone simply switching to one frequency. [#16660500] [#16666099]
  • #1 16641327
  • #2 16641481
    JacekCz
    Help: 760
    Rate: 1464
    in the army (90s) I was taught about spare frequencies, e.g. a popular radio for combat vehicles allowed me to prepare (a kind of analog / mechanical memory) a total of four. The backup frequency was implicit. The guard or the police act less "in the face of the enemy", I do not know how similar it is. The higher-level command vehicles had 2 radio stations according to the classification "up" "down", because there is also such an element of the organization.
    Many serial firefighter radios have the option of only two channels set on the site. Perhaps they are programmed on the channel of the own and the superior unit, but this is a presumption.
    In general, with professionals there is no such thing that a "field" officer will set the frequency he chooses. They are not radio enthusiasts, they work in stress, etc ... there is no point in giving them such a "convenience"
  • #3 16641642
    gumisie
    Help: 1667
    Rate: 2486
    JacekCz wrote:
    in the military (1990s) I was taught about backup frequencies
    JacekCz wrote:
    In general, there is no such thing in professionals that "off-road" the officer will set the frequency he chooses
    Why would he do this? :!: , (probably so that he does not hear commands, or maybe so as not to eavesdrop on him). :cry:
    Thus: "off-road" the commander of the rescue operation has no "right" to demand from his "subordinates" to switch the TRX to another channel so as not to block the primary :?:
    Best regards.
  • #4 16641678
    Rezystor240
    Help: 689
    Rate: 1652
    The police transmit on a frequency of 172.250 MHz, in NFM modulation (i.e. narrow FM)
    I do not recommend broadcasting on this frequency, you know how it will end.
    You can only listen.
  • #5 16641709
    gumisie
    Help: 1667
    Rate: 2486
    If you say so, maybe it is. (not some services still use analog FM_ek) :D .
    And here I 100% agree with you, I would only add that transmitting on any frequency without authorization may also end up in the same.
    Best regards.
  • #6 16641711
    belzebub24
    Help: 16
    Rate: 28
    The fire brigade has about 50 channels (different frequencies) assigned, including rescue and firefighting channels assigned to various actions by the person who chooses the situation, provincial channels, nationwide channels, local channels for local units of the State Fire Service and the TSO. The whole system is tied together, so in an extreme (imaginary) situation, for example, you could hear, for example, the voivodeship command from Greater Poland in Krakow or, for example, the commander of the PSP Headquarters in Gdańsk.
  • #7 16641744
    Rezystor240
    Help: 689
    Rate: 1652
    gumisie wrote:
    If you say so, maybe it is so (not some services use analog FM_ek).
    For example, trains talk at 150,150MHz
    Here you can hear: '' 45WE ready to leave behind the Skierniewice Rawka station ''
    Added after 14 [minutes]:
    Already one of the other 'connected' to the frequency of the trains and did not do well.
    http://www.polskieradio.pl/5/3/Artykul/353765...ymywali-pociagi-za-pomoca-nadajnika-radiowego
  • #8 16642378
    gumisie
    Help: 1667
    Rate: 2486
    You can also hear "The train from Warsaw to Gdynia is delayed by the planned two hours, travelers are asked to step away from the tracks.
    Rezystor240 wrote:
    gumisie wrote:
    And here I 100% agree with you, I would only add that broadcasting on any frequency without authorization may also end up in the same.
    Already one of the other 'connected' to the frequency of trains and they did not do well at it .
    And how were they supposed to leave.
    Best regards.
  • #9 16642738
    Rezystor240
    Help: 689
    Rate: 1652
    Yes, but you hear it on the platform from the loudspeaker :wink:
    And not at home, almost 1000m from the platform.
  • #10 16642756
    robokop
    Help: 1763
    Rate: 6373
    They did not connect, but played with the PKP "radio" signal, causing confusion. And since it almost resulted in an attempt to overthrow democracy, a coup d'état and sabotage, the boys did not see their families a bit. Overall it looks like the radio spectrum is ordered and divided. Each service has its own frequency range, divided into channels, and units each use their own. Information easily available on the web.
  • #11 16642761
    Rezystor240
    Help: 689
    Rate: 1652
    They played with the radio-stop signal, which should only be used in emergency situations.
    But they sent him 'just for fun'
    And one of them was a subway driver.
    robokop wrote:
    the guys haven't seen their families a bit.
    No, all three of them received a hinged sentence, so they missed the boarding house.
    I greet my friend, yes2mike.
  • #12 16642776
    gumisie
    Help: 1667
    Rate: 2486
    @robokop ,, I regret to say that it was not gummy bears he wrote:
    robokop wrote:
    but :( # 7)
    Gumisie advises against, warns what such fun may end with. # 5, # 8
    gumisie wrote:
    gummy, replied:
    May I "fart" and not a tragedy of innocent people.
    Best regards.
  • #13 16650235
    Jap
    Help: 114
    Rate: 654
    back to the point: in my area, the services do not have common frequencies. This is probably due to the fact that the relevant services have their ranges assigned. The guard has a general voivodeship channel - for me it is 149.100MHz. But generally, during rescue operations, they go to the Rescue and Fire-Fighting Canals - there are 8 of them. Then they do not unnecessarily block the main canal for the region.
    It may also be surprising sometimes that I hear the guards on 147.8875 and immediately on 171.025MHz - it turns out that they have a relay installed that allows them to communicate in mountainous terrain.
    I ordered a policeman friend of mine - a small piece of equipment - Zastone ZT2R - as a receiver of other services - so that he would know what was going on. The problem of common frequencies has been raised by the services for a long time - but the topic is not very moving forward in my area. Maybe the inevitable digitization will change something - but then we will have nothing to listen to ...
  • #14 16650768
    Interesant
    Help: 204
    Rate: 249
    Rumor had it that 2 out of 3, it was half a year in Łowicz on vacation for the case.
  • #15 16650982
    czacheur
    Of course, not only at 172.250 MHz.
    Wrocław is 164,525-167,475 and 172-174.
  • #16 16651258
    Rezystor240
    Help: 689
    Rate: 1652
    Not true, I know this case, no one was sent to ZK Łowicz.
    Please come back to the topic.
    I gave the frequencies used in my city.
    The same with 150,150MHz trains, i.e. the 2nd channel in my city is valid.
  • #17 16652584
    czacheur
    Yeah. In towns where there is one unit, one frequency is used. There are more units in Wrocław, hence my previous post.
  • Additional shared channels and service-specific radio uses
    #18 16660500
    jkk
    Help: 31
    Rate: 40
    Let us add to this the services that use ripiters with a fairly large distance TX / RX (probably KMP Koszalin), the Fire Brigade, which, in addition to operating channels, uses frequencies for remote activation of OSP sirens, railway, where in addition to 10 road channels (R 0 - R 9), the topography of which on the network is generally known - also uses frequencies intended for shunting traffic, locomotive sheds, depot and work trains. Juice players also have their own nationwide channel. Aviators and sailors have their own table. I do not know if any of my colleagues also pointed out that many professional portable devices do not have the ability to adjust the volume "to zero" - so that the user could not mute it completely. They are also called cooperation channels to coordinate the work of services in the event of major events. Finally, a Police officer has the option of summoning the emergency service or the fire brigade on duty through his station without the mediation of his dispatcher. The subject is a river, a longer discussion is preparing ...
  • #19 16666099
    Interesant
    Help: 204
    Rate: 249
    @jkk you put everything into one boiler. While until recently the operator responsible for radio communication on the Railway was TK-Telekom, now, after the division and sale of TK-Telekom, it was taken over by PKP-PLK through its daughter company - PKP-U Maintanie. Returning to the merits, on the PKP-PLK tracks there are simplex channels with a 25kHz step and, apart from 8 road channels and two maintenance channels, the rest of the channels (Manewrowe, Rewidenckie from the 150MHz band) used by carriers from the PKP group are leased from PKP-PLK, otherwise As for private carriers using their own infrastructure, then the passage or maneuvers on the siding can take place in the 171MHZ band with a channel spacing of 12.5kHz. Government services subordinate to the Ministry of the Interior have several bands, the most famous are several sections in the VHF band (For WCZK, PSP, SW, BOR, PP, etc.). There, communications can be simplex, doubleimplex (through "simple" converters and Trunking zone converters) with 6.25-12.5-25.0kHz channel spacing. In the case of single repeaters, a given service uses the same two frequencies (Channel), In the case of Trunking Zones, different services may use the same group of channels
The discussion revolves around the sharing of broadcast frequencies between fire brigades and police services, particularly in the context of emergency situations. Participants note that while police typically operate on specific frequencies (e.g., 172.250 MHz), fire services have a broader range of channels assigned for various operations, including local, provincial, and nationwide communications. It is suggested that during extreme conditions, units may utilize shared frequencies to avoid congestion on primary channels. The conversation highlights the importance of maintaining organized communication channels to prevent interference and ensure effective coordination among emergency services.
TL;DR: Fire brigades use about 50 assigned channels; “the whole system is tied together,” enabling regional coordination during incidents. [Elektroda, belzebub24, post #16641711]
Why it matters: This FAQ helps scanner listeners and hobbyists understand who shares what, what to tune, and what to avoid legally.
Do fire brigades and police share the same frequencies?
No. The spectrum is organized and divided by service. Each service operates within its own assigned ranges and channels. Interoperability is coordinated rather than “shared all the time.” During major events, services coordinate through designated channels rather than merging bands. “Each service has its own frequency range, divided into channels.” [Elektroda, robokop, post #16642756]
Why did I hear a Toruń dispatcher managing units in Chełmża?
Regional dispatch often runs on a voivodeship channel, so units across nearby towns share that dispatch net. During operations, firefighters switch to one of the eight Rescue-and-Firefighting channels to keep the main regional channel clear. Relays can also extend coverage, so you may hear distant traffic. [Elektroda, Jap, post #16650235]
What are Rescue-and-Firefighting channels and when are they used?
They are eight tactical channels reserved for on‑scene coordination. Crews move to these channels during incidents to avoid blocking the voivodeship dispatch channel. This keeps command traffic clear and improves safety during storms, fires, and mass events. [Elektroda, Jap, post #16650235]
Can field officers freely change frequencies on their radios?
Generally no. Professional users get preset channel lists, often just two accessible on the device. This prevents misconfiguration under stress and maintains command structure. As one expert notes, many firefighter radios expose “only two channels set on the site.” [Elektroda, JacekCz, post #16641481]
What does “backup frequency” mean in practice?
It’s a pre-programmed alternative channel used when the primary is congested or compromised. Older military and service radios supported several preset memories to switch quickly without manual tuning. The concept persists to maintain communications resilience during operations. [Elektroda, JacekCz, post #16641481]
Is police radio just 172.250 MHz in NFM?
No. Some places may use that frequency, but city ranges vary. For example, Wrocław uses 164.525–167.475 MHz and 172–174 MHz. Many channels use narrow FM (NFM), but exact allocations are regional. Monitor ranges, not a single spot. [Elektroda, czacheur, post #16650982]
What is NFM (narrow FM)?
NFM means narrowband frequency‑modulated voice. In the thread, police operation was noted in NFM. Your scanner should support NFM demodulation for these channels. Set receive‑only to stay legal. [Elektroda, Rezystor240, post #16641678]
Are there cross‑service cooperation channels for big incidents?
Yes. Services maintain cooperation channels for interagency coordination during large events. Fire units also use remote siren activation frequencies for OSP, and officers can summon other services directly from their radios when needed. [Elektroda, jkk, post #16660500]
Why do I sometimes hear the same fire unit on two very different frequencies?
Relays and terrain‑focused links can repeat traffic on another band to improve coverage, especially in mountains. You might hear a local VHF channel and a higher‑frequency link carrying the same conversation for reach. [Elektroda, Jap, post #16650235]
Is it legal to transmit on these channels with my handheld?
No. Transmitting without authorization is illegal and can lead to serious penalties. Monitor passively only. As one expert warns, transmitting on any frequency without authorization can end the same way—badly. [Elektroda, gumisie, post #16641709]
What happens if someone triggers railway radio‑stop signals?
Trains can halt, disrupting safety and operations. There was a case where people misused the signal “for fun,” highlighting severe consequences. Do not interfere with rail communications under any circumstances. This is a critical safety edge case. [Elektroda, Rezystor240, post #16641744]
Why won’t my professional handheld radio mute to absolute silence?
Many professional radios prevent volume from going to zero. Designers ensure users cannot miss critical traffic during emergencies. You’ll still hear alerts or commands even at minimum volume by design. [Elektroda, jkk, post #16660500]
How do I set up a scanner to follow fire traffic legally?
  1. Program your region’s voivodeship dispatch frequency (e.g., 149.100 MHz if applicable).
  2. Add the eight Rescue‑and‑Firefighting channels for incident traffic.
  3. Enable NFM receive mode and lock out transmit to stay listen‑only. [Elektroda, Jap, post #16650235]
Can a simple receiver like Zastone ZT2R help me stay informed?
Yes, as a receive‑only companion. Some users equip officers with small receivers to monitor nearby services and improve situational awareness. Ensure you configure it for NFM and do not transmit. [Elektroda, Jap, post #16650235]
What is a trunking zone in public safety radio?
A trunking zone is a group of shared channels managed by a controller. Different services can use the same pool while staying in separate talkgroups. Single repeaters use fixed pairs; trunked zones dynamically assign channels. [Elektroda, Interesant, post #16666099]
Do small towns use one channel while big cities use many?
Often yes. Towns with one unit may run a single channel. Larger cities host multiple units and therefore more frequencies and channels to coordinate traffic. Plan your scan lists accordingly. [Elektroda, czacheur, post #16652584]
