[Solved] INEA Services: Understanding IP Changes - Fixed vs Variable IP, Reasons & Scenarios
blazkowicz 14277 5
  • #1 14775744
    blazkowicz
    Rate: 23
    One thing "worried" me - that is, I have been using Inea's services for several years and I was convinced that it has a fixed IP - looking at gmail / bank accounts logs, etc., I had the same IP for a long time - 85.221.147.xxx (since I look, i.e. over half a year for sure), regardless of the router reset, the IP always kept coming back the same for a long time.
    Yesterday at 11 am "suddenly" my IP changed to a completely different 77.65.91.xx - and since yesterday I have it all the time. I haven't changed any contracts, routers or anything like that.
    Hence my question - does Inea have a fixed or variable IP? Could it "itself" change like that for no reason after such a time? What could it be caused by?
  • #2 14776093
    askr
    Help: 302
    Rate: 364
    Depends on what you have in the contract.
    If you don't have a constant written on it, the fact that it hasn't changed over x times doesn't mean anything.
  • #3 14776149
    blazkowicz
    Rate: 23
    There is nothing written about fixed IP in the contract. It just hasn't changed for so long that I assumed it was constant.
    And most of all, what could have been caused by the fact that nothing changed for such a long time, and then suddenly ... I wonder if it is a normal thing or should I be disturbed by such a change.
  • #4 14776275
    askr
    Help: 302
    Rate: 364
    Normal thing.
    Apparently, someone else at that time reset the router and you swapped, or some forced change on the operator's side.
  • #5 14776484
    jimasek
    Help: 3783
    Rate: 2682
    blazkowicz wrote:
    How could it "itself" change without a reason after such a time? What could it be caused by?
    Yes it can change and you have no influence on it.
  • #6 18083084
    blazkowicz
    Rate: 23
    TO close (change from ip4 to ip6)
