No Internet Connection: INEA Provider, Technicolor CGA2121 Modem, DNS Server Not Responding
Willyff 4986 14
How can I fix a “DNS server not responding” error on my INEA Technicolor CGA2121 modem?
Set the DNS servers manually on your network card to 62.21.99.95 as primary and 62.21.99.94 as secondary, then check whether Internet access starts working again [#16807819] If the problem persists, report it to your ISP because the issue may be on their side [#16807923]
  • #1 16807650
    Willyff
    Rate: 8
    Hello. I have a problem with my internet connection. The provider of my network is INEA and the modem is Technicolor CGA2121. I just reset the network but still get the error "DNS server not responding". What to do?
  • #2 16807667
    KSRhaziel
    Level 36  
    Help: 271
    Rate: 275
    Enter your network configuration. What is your DNS server set up?
  • #3 16807676
    jimasek
    Help: 3783
    Rate: 2681
    How do you connect to the router? Only one device on your home network at your disposal? You have not written anything what is this device with what operating system?
  • #4 16807681
    Willyff
    Rate: 8
    It connects to the DNS server automatically. I use a pcet with Windows 10. I have a cable on the Internet.
  • #5 16807700
    jimasek
    Help: 3783
    Rate: 2681
    Only have this computer at your disposal? Have you checked internet access on different ports on this router?
  • #6 16807709
    Willyff
    Rate: 8
    I checked all the ports and only this one computer is at my disposal.
  • #7 16807726
    jimasek
    Help: 3783
    Rate: 2681
    So how do you post in the forum !?
  • #8 16807735
    Willyff
    Rate: 8
    Internet package on the phone
  • #9 16807740
    jimasek
    Help: 3783
    Rate: 2681
    What does the ipconfig command typed in cmd show? The problem happened before?
    Well, and the router doesn't have wifi?
  • #10 16807777
    Willyff
    Rate: 8
    It does, but it doesn't work either. I had the same problem on October 26, i.e. when the error appeared, I returned to my hometown and did nothing with it and when I returned to the apartment on October 31, everything was working. Today the problem appeared again after I unplugged the original cable to check if the other old cable was working. After that, the connection was broken. Connecting the original one did nothing.
    Added after 9 [minutes]:
    Microsoft Windows [Version 10.0.15063]
    (c) 2017 Microsoft Corporation. All rights reserved.
    C: \ Users \ Michau> ipconfig
    Windows IP Configuration
    Ethernet Ethernet adapter:
    Connection-specific DNS Suffix. :
    Link-local IPv6 Address. . . . . : fe80 :: 80aa: f529: 65c0: 5e5a% 10
    IPv4 Address. . . . . . . . . . . : 192.168.0.12
    Subnet Mask. . . . . . . . . . . : 255.255.255.0
    Default Gateway. . . . . . . . . : 192.168.0.1
    Ethernet adapter Ethernet 2:
    Media State. . . . . . . . . . . : Media disconnected
  • #11 16807819
    jimasek
    Help: 3783
    Rate: 2681
    Add DNS to the network card from your hand:
    primary: 62.21.99.95
    secondary: 62.21.99.94
    And check if anything has changed in the Internet access. If not, report the problem to your supplier.
  • #12 16807829
    Willyff
    Rate: 8
    Ipv4 or ipv6?
  • #13 16807895
    jimasek
    Help: 3783
    Rate: 2681
    Well, I guess you can see that you have the IPv4 version addressing.
  • #14 16807916
    Willyff
    Rate: 8
    I get the message "This computer may be configured correctly, but the device or resource (DNS server) is not responding."
  • #15 16807923
    jimasek
    Help: 3783
    Rate: 2681
    Report the problem to your ISP.
The user is experiencing a "DNS server not responding" error with their internet connection provided by INEA, using a Technicolor CGA2121 modem. Despite resetting the network and checking all ports, the issue persists. The user connects via a Windows 10 PC and has attempted to troubleshoot by using different cables. Suggestions from the forum include checking the DNS server settings, using specific DNS addresses (62.21.99.95 as primary and 62.21.99.94 as secondary), and verifying the IP configuration. The user confirmed the IPv4 addressing and reported that the DNS server is still unresponsive, leading to recommendations to contact the ISP for further assistance.
TL;DR: Fix “DNS server not responding” by manually setting 2 DNS IPs (62.21.99.95 and 62.21.99.94); as the expert said, “Add DNS to the network card.” [Elektroda, jimasek, post #16807819]
How do I fix “DNS server not responding” with INEA and a Technicolor CGA2121?
Set manual IPv4 DNS on your PC to 62.21.99.95 and 62.21.99.94. Reconnect and test several sites. If it still fails, contact your ISP to check upstream DNS or line issues. “Add DNS to the network card.” [Elektroda, jimasek, post #16807819]
Where do I set IPv4 DNS in Windows 10?
  1. Open Network & Internet > Change adapter options > your Ethernet/Wi‑Fi > Properties.
  2. Select Internet Protocol Version 4 (TCP/IPv4) > Properties.
  3. Choose “Use the following DNS server addresses,” enter 62.21.99.95 and 62.21.99.94, then OK and reconnect. [Elektroda, jimasek, post #16807819]
Does this DNS error affect both Ethernet and Wi‑Fi?
Yes. In the case discussed, Ethernet failed and the router’s Wi‑Fi also had no internet. That points to an upstream or DNS issue rather than a single port. [Elektroda, Willyff, post #16807777]
What does the ipconfig output tell me here?
The PC received IPv4 192.168.0.12 with subnet 255.255.255.0 and gateway 192.168.0.1. That suggests local DHCP worked, but name resolution or upstream connectivity failed. [Elektroda, Willyff, post #16807777]
Should I use IPv4 or IPv6 DNS for this setup?
Use IPv4 DNS. The configuration and addresses shown were IPv4, and the helper explicitly pointed this out during troubleshooting. [Elektroda, jimasek, post #16807895]
What if manual DNS still doesn’t work?
Escalate to your ISP. The expert’s guidance was clear: “Report the problem to your ISP.” Persistent failures after correct DNS entry indicate a provider or upstream fault. [Elektroda, jimasek, post #16807923]
Why did the internet start working again days later without changes?
The user reported failure on October 26 and normal service on October 31 after doing nothing. That pattern fits a transient provider issue or network maintenance. [Elektroda, Willyff, post #16807777]
Could swapping Ethernet cables cause this symptom?
The issue appeared after unplugging the original cable to test another. Restoring the original cable did not fix it, indicating the fault was not the cable alone. [Elektroda, Willyff, post #16807777]
What does “Media disconnected” for Ethernet 2 mean?
Windows detected a second adapter that wasn’t linked. That interface was inactive, so only the primary Ethernet was participating in troubleshooting. [Elektroda, Willyff, post #16807777]
Can I still post or get help without home internet?
Yes. In the thread, the user used a phone data package to access the forum and continue troubleshooting. [Elektroda, Willyff, post #16807735]
What is a DNS error in this Windows case?
Windows reported, “This computer may be configured correctly, but the device or resource (DNS server) is not responding.” That indicates failed name resolution replies. [Elektroda, Willyff, post #16807916]
Which Windows 10 version appeared in the report?
The diagnostic output shows Microsoft Windows Version 10.0.15063. That build detail helps align settings with the steps above. [Elektroda, Willyff, post #16807777]
