Sencor SLE 48f10m4 TV: Stuck on Logo, Standby & Winbond 25Q64FVSIG Issue - R579 Resistor Value
olda007 11529 5
  • #1 14867469
    olda007
    Rate: 11
    After turning on the TV, only the Sencor logo appeared and the TV switched off to standby. I suspected Winbond 25Q64FVSIG. I soldered the memory and now I do not know if it was on the motherboard next to the R579 resistor. I think yes, but I'm not sure. It is connected between pin 3 of the memory and pin 4 GND. What is the R579 value? Thank you very much.
  • #2 14867584
    sabret
    Help: 39
    Rate: 159
    What record is this TV on?
  • #3 14867598
    mirex
    Help: 1950
    Rate: 1991
    If it was, then probably the standard 4.7k & # 937 ;. ;)
    And this is a single-plate freak. :)
    I understand the author, that you have the batch. Exactly to him?
  • #4 14867738
    olda007
    Rate: 11
    I apologize for diacritics, I am from the Czech Republic.
    sabret:
    All numbers:
    KDL48LT618Q-SEC258YTK3
    350 8566
    GKGR14-0019141111561
    E148158
    RH-K4
    94V-0
    I attach photos
    mirex:
    Yes, it is - a single-board freak.
    I bought the memory s dunk (sahy.cz)
    • Sencor SLE 48f10m4 TV: Stuck on Logo, Standby & Winbond 25Q64FVSIG Issue - R579 Resistor Value plyta2.jpg (671.42 KB) You must be logged in to download this attachment.
    • Sencor SLE 48f10m4 TV: Stuck on Logo, Standby & Winbond 25Q64FVSIG Issue - R579 Resistor Value plyta1.jpg (674.08 KB) You must be logged in to download this attachment.
    hatron
    Rate: 14
    add a 100k resistor to the C702 backlight circuit
  • #6 15165388
    olda007
    Rate: 11
    Resistor R579 is not on main. The memory was ok.Sosen diodes replaced (8 LED) - less current. Type Lextar 3030 6V 265mA. Added resistor 100kohm k C702. The display works, TV also. Thank you hatron.
