Saba SBC32FH TV Stuck on Logo: Exploring EEPROM 25Q64 and TPSIS231.PT851 Firmware Solutions
ferrorep 2937 4
  • #1 18369914
    ferrorep
    Mark: saba
    Model: sbc32fh
    Chassis (main board, components): TPSIS231.PT851
    LCD Screen/Panel (if exist):
    More informations:
    Hello to all
    I have a saba tv in the lab that gets stuck in the SABA logo.
    After that it restarts for a while. When it remains on, it cannot be turned off except by removing the plug from the socket.
    I read that it is possible to write eeprom 25Q64 to work again or to put a new integrated one.
    I can't find the firmware for my model only similar of TPSIS231.PT851.
  • #3 18377379
    VINZA
    Help: 49
    Rate: 164
    Hi, post a photo of the label on the back of the appliance and the serial number.
  • #4 18379472
    ferrorep
    I wonder if it will be appropriate to change it for a new one.
    The TV is working perfectly for now, problem solved.
    Thank you.
  • #5 18380201
    Aquario_blue
    Level 19  
    Help: 41
    Rate: 155
    I think it is not worth changing equipment, now advise the following, reset the equipment factory and save the data from eproom. You may need to recover the card in the future.
