Vag KKl Cable Compatibility with VCDS 12.12 Program for Cars Pre-2004: Driver Installation Query
TomiPl12 54534 11
Can I make VCDS 12.12 work with a VAG KKL cable just by installing the right drivers?
No, VCDS 12.12 will not work with a VAG KKL cable just by installing drivers; the KKL interface is for K/L-line diagnostics and does not support CAN, so VCDS will not recognize it [#16318542] VAG KKL cables are generally meant for older cars up to about 2005, while newer VAG models increasingly use CAN and need a different interface [#16317487] [#19467972] VCDS Lite or VAG-COM works with KKL on older cars, but not the full VCDS package with this cable [#16317521] [#19467972] For cars like an A6 from 2009, Passat B6 from 2006, or B8 from 2016, you need hardware such as HEX-V2 or HEX+CAN instead [#18023] [#19467972]
  • #1 16316366
    TomiPl12
    Hi, I have a vagkkl cable and software for cars not younger than 2004 and I would like to know if I could make the soft VCDS 12.12 work with the vagkkl cable? Is it enough to install some drivers for the cable?
  • #2 16317487
    r_Lunar
    Rate: 32
    vag kkl is for cars younger than 2005, usually, as the name says KKL, from the K-line. cars after 2004 had more and more CAN, and in the audi after 2006, your cable will not do anything at all.
    and VCDS will not work with KKL, install VAG COM. The cable drivers should be supplied from the manufacturer. If you do not find it on the KKL cable in google, read the installation instructions!
  • #3 16317497
    TomiPl12
    A vag com to which year the car will do the trick?
  • #4 16317498
    leonov
    Help: 1039
    Rate: 2246
    and VCDS will not work from the KKL
    Would it be for sure? link :idea:
  • #5 16317521
    r_Lunar
    Rate: 32
    Okay, I was thinking about VCDS for RossTech cables, I did not think about the Lite version, for example. And these cables from VAG COM work very steadily
    It is not important to vintage what the network in the car. Your cable works with, for example, Audi a4 b5, b6, a4 b7, unfortunately not especially from 2006. Tell me how you want to diagnose the cars in which yearbooks and, first of all, where did you buy the cable?
  • #6 16317939
    TomiPl12
    I have long cables, and I do not mean vcds lite only the full version, the cars I want to service: a6 from 2009, passat b6 from 2006 and b8 from 2016
  • #7 16318023
    piotrekwoj1
    Help: 947
    Rate: 3427
    Forget about this equipment for sure.
  • #9 16318542
    grala1
    VAG group specialist
    Help: 1495
    Rate: 5051
    You will not fire VCDS on KKL.
    VCDS requires a special interface that has a different construction.
    VCDS will not even notice your interface.
    Your interface does not support CAN and no software will change it.
  • #10 17231316
    motorek79
    What is different from vcds, from vcds lite, since solid reads from kkl, it sees everything that lite allows.
  • #11 19467891
    arek600
    good question too I have this problem and I would like to know the solution
  • #12 19467972
    marfur30
    Help: 138
    Rate: 386
    motorek79 wrote:
    What's the difference between vcds and vcds lite, since lite reads with kkl, sees everything that lite allows.
    The fact that Lite is soft for Vag-KKL and supports cars until 2005 that have diagnostics on the K and L lines. Newer models connect on the CAN bus that this cable does not support.
    For your cars you need to buy, for example, HEX-V2 or HEX + CAN.
✨ The discussion centers around the compatibility of the VAG KKL cable with the VCDS 12.12 software for vehicles manufactured before 2004. It is established that the VAG KKL cable is primarily designed for vehicles up to 2005, as newer models increasingly utilize the CAN bus system, which the KKL cable does not support. Users are advised that VCDS requires a different interface that can handle CAN communications, and thus, the KKL cable will not function with VCDS. Recommendations include using VAG COM or upgrading to interfaces like HEX-V2 or HEX + CAN for newer models. The importance of proper driver installation for the KKL cable is also highlighted, with suggestions to refer to the manufacturer's instructions for driver support.
