VCDS 10.6.1: Ross-Tech USB Interface Not Found with VAG KKL USB Cable for Car Diagnostics
Hielbi 74287 7
  • #1 9288403
    Hielbi
    Hello, I am new to the forum and I have this question a few days ago I received this cable for the so-called car diagnostics http://allegro.pl/vw-seat-audi-skoda-interfejs-vag-kkl-usb-kurier24h-i1469062975.html? source=oo I open the programs from the CD everything works fine I installed vcds 10.6.1 I open options>usb>test and Ross-Tech USB interface not found pops up! Could someone guide me? I desperately need this VCDS program, and urgently. Thanks in advance
  • #2 9288430
    dizba
    Help: 239
    Rate: 808
    You can't run it on this fake. You have to buy the original cable.
  • #4 9289429
    autoas
    Help: 571
    Rate: 3922
    And on the other hand, buying an interface for PLN 35 and "wanting" to run VCDS version 10 is lame and naive to the nth power
  • #5 9289739
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4181
    I would like that too, buy for pennies and a program from the net and let it hula.
    autoas cool signature - only all customers lie, not only those from the reserve without electricity.
  • #6 9310022
    adek444
    Rate: 8
    on kkl you need to download vcds-lite and it will work
  • #7 9346400
    jacks_pl
    Rate: 21
    This cable will go VCDS-Lite, VAG-COM to version 409.1 (VCDS predecessor) and Polish VAG 2.5 and 4.9. For private purposes and older cars (up to about 2001) it is enough. For newer cars you need a cable with a K-CAN interface. Regards
  • #8 9346740
    trans-serwis
    Help: 297
    Rate: 2259
    Hielbi has to pay for this version of VCDS.
The discussion revolves around the user's issue with the VCDS 10.6.1 software not recognizing the Ross-Tech USB interface when using a VAG KKL USB cable for car diagnostics. Responses indicate that the user is likely using a counterfeit or low-quality cable, which is incompatible with the VCDS software. Suggestions include using VCDS-Lite for compatibility with the KKL cable and acknowledging that the original Ross-Tech cable is necessary for full functionality with newer vehicles. The conversation highlights the limitations of using inexpensive interfaces for advanced diagnostic software.
