Water Gurgling in Sink & Shower Tray, Paddling Pool Overflow, Bathroom Renovation & Pipe Unclogging
telker 29676 9
Why does water gurgle in the sink and shower tray, and why does it back up into the nearby tray when it drains?
The most likely cause is a blocked or poorly vented riser, or a partial obstruction in the shared drain section where the new installation joins the old vertical pipe. Check that the riser ventilation is unobstructed, because a vent problem can make the drains gurgle and behave as if air is pushing the water back [#14922667] Also inspect the patency behind the point where the sink and shower tray drains connect, especially the old glued vertical section, since that is the place the replies point to as the likely trouble spot [#14922699] [#14922737] The symptom that water from the nearby basin drains very slowly also fits a restriction or air-lock in that shared section [#14922716] If possible, disassemble and recheck the installation, because an incorrect slope or something left in the pipe could still be causing the blockage [#14922754]
  • #1 14922313
    telker
    Rate: 39
    After 3 years after the renovation of the bathroom and toilet, there was a problem, namely there is a bubbling while the water flows from the washbasin - the shower tray, etc. It looks like that when the water flows from the washbasin, it gurgles in the washbasin and the water appears in the nearby paddling pool. It seems as if the water wanted to go out of this paddling pool. The running off is well done - why would it be bad if everything worked for 3 years. The new drainage installation has been attached to a piece of starek which is glued vertically. In this riser there is also a water outlet from the toilet but nothing is happening there. Yesterday a specialist was called to push this old piece of pipe because there was a suspicion that it might be clogged. He put a 5-meter-long spring in, twirled it, slid it and left. After all the action this am - gurgling gurgling. It looks like some air - the pressure in these pipes was and was circulating in this water - I don't know how to explain it. The restaurant is on the 5th floor and it is like a half of the building and the first zone because it is an 11-story building. There is a problem somewhere, but I cannot locate it. All drain siphons - pipes with a cross section of 50 mm.
    What could be the reason ?
  • #2 14922667
    zetdeel
    Help: 719
    Rate: 884
    Venting the riser unobstructed?
  • #3 14922690
    telker
    Rate: 39
    How to check it? How to suggest that the administration check it.
    Will the gurgling effect when the riser is deaerated only be with me due to the fact that it is an apartment that ends the first division of the building?
  • #4 14922699
    Qbuś
    Help: 380
    Rate: 876
    I would check the patency behind the place where the drains from the sink and the shower tray connect.
    when water flows from the washbasin, it gurgles in the washbasin and the water appears in the nearby paddling pool
    . If it cannot flow into the main pipe, it flows out of the tray!
    Link :D .
  • #5 14922716
    telker
    Rate: 39
    Link :D .
    The pipes are completely empty - even the water in the washbasin in the toilet, which is very close to the vertical, flows very slowly - as if some air was pushing it the other way.
  • #6 14922725
    Qbuś
    Help: 380
    Rate: 876
    It must be the "sparrows" made a nest in the venting, Or someone who mixed up something and will not admit it.
  • #7 14922730
    telker
    Rate: 39
    The problem with venting - that would be correct and the latter part of the answer
    "Or someone who mixed up something and won't admit it" - where, in what place - I put the water installations myself.
  • #8 14922737
    Qbuś
    Help: 380
    Rate: 876
    The new drainage installation has been attached to a piece of the old one that is glued vertically
    Here I would be looking for the cause :idea: .
  • #9 14922744
    telker
    Rate: 39
    The old piece is about 70 cm, which could not be replaced because it is glued to the main pipe. Yesterday it was pushed by a spring. It climbed 5 meters - and it was scratching the back of the neighbor downstairs.
  • #10 14922754
    Qbuś
    Help: 380
    Rate: 876
    It's hard to advise anything wise without seeing this installation, if you have the opportunity and willingness to disassemble it and check it again. Maybe the "drops" were wrong, maybe something was left in the tube, maybe, maybe? Maybe some sketch or photos?
    Ps. What ? is the main pipe?
The discussion revolves around a plumbing issue where water gurgles in the sink and shower tray, with water appearing in a nearby paddling pool after three years of a bathroom renovation. The user suspects a clog in the drainage system, particularly in the riser connected to the toilet. Responses suggest checking the venting system for obstructions and ensuring proper drainage from the sink and shower tray. There are concerns about air pressure affecting water flow, and the possibility of a blockage in the old pipe, which was recently cleared with a spring. Suggestions include inspecting the installation for potential errors or leftover debris.
