Can I Safely Charge a Car Battery at Home with 30A? Comparing to 40A Alternator
kolibercio 55113 16
Can I safely charge a car battery at home with a 30A charger, and why can a 40A alternator charge it without immediate damage?
Yes—if the charger is voltage-limited to about 14–14.4V, a 30A fast charge can be used, but it is more of an emergency method than a routine one because it can heat the battery, cause gassing, and shorten battery life [#14936951][#14926327] The alternator’s 40A+ rating is its maximum current capability, not the actual charging current all the time; in a car, the battery only draws the current it needs while the vehicle’s other loads use the rest [#14936886][#14936951] With a deeply discharged battery, the current can briefly reach tens of amps after starting, then falls quickly as the battery voltage rises and the battery approaches full charge [#14936951]
  • #1 14926181
    kolibercio
    Help: 25
    Rate: 78
    Hello. For some time I have been wondering how it is that a typical battery charger has 6A, while the alternator in a car is 40A +.
    So, could I safely charge the battery at home with 30A?
  • #2 14926211
    beatom
    Help: 421
    Rate: 875
    The alternator does not charge the battery with 30A.
    Typical charging current is 1/10 of the capacity.
  • #3 14926212
    kolibercio
    Help: 25
    Rate: 78
    The alternator is over 40A, so how can it charge a 1/10 capacity battery?
  • #4 14926236
    Falco76
    Help: 41
    Rate: 148
    Stock is needed because you have a few other items in your car that need electricity. The battery charging current is limited by the charging voltage.
  • #5 14926243
    ociz
    Help: 1379
    Rate: 3486
    It charges with time and with higher current, depending on the degree of discharge of the battery, which is of course harmful to it.
  • #6 14926303
    Zbigniew 400
    Help: 283
    Rate: 794
    In the old design of alternator regulators, charging the battery was indeed detrimental to the battery. In today's solutions / the on-board computer regulates the charging current / it is more delicate.
  • #7 14926327
    Xantix
    Help: 686
    Rate: 1657
    There is a method of charging the battery that the producers sometimes mention, namely the so-called quick charging with 0.8 C current. It is allowed only in emergency situations, as it strongly damages the battery. Then, there is a strong heating and gassing of the electrolyte, the active mass falls out of the plates (the cell may short-circuit) and the plates themselves bend. So even if the battery does not die, it will definitely shorten his life significantly. Why am I mentioning this? Because a similar situation is when we torture a weak battery with a few minutes of starting, finally the car fires and the altek starts loading. The voltage is stiff 14.4V and the battery draws as much current as the altek gives it (and it can even give it 50A depending on the consumption from other receivers). So you can charge the battery with high currents, but still it shouldn't be done, because the benefits are smaller than the losses. But if there is no breakdown in the car, and we use it properly, such situations practically do not occur ...
  • #8 14936886
    nightrunner
    Help: 48
    Rate: 43
    First of all, you need to start with the fact that the current value given on the alternator determines its efficiency, it is not information how much current flows from the alternator.
    This is only information that up to the maximum load of X amps, the alternator will maintain the rated voltage of 14.4V.
    How many amps will flow from the alternator depends on how many amps are needed by the devices connected to it.
    There is no such thing as a typical battery charging current in a normal automotive installation.
    Most often it is a simple cable connection, because nothing else is needed there.
    The alternator gives a voltage of 14.4V, the rated voltage of the battery is 12.6-12.8V. This potential difference causes that electricity flows to the battery, i.e. it is charged.
    The charging current of the battery depends on the potential difference of the battery-generator, so the lower the voltage of the battery, the greater the potential difference and the greater the charging current.
    The value of the charging current is also influenced by the battery capacity because its Rw depends on it, so the higher the battery, the greater the charging current with the same battery-alternator potential difference.
    So there is no magic or finesse here (in a simple "classic" solution, of course).
    It is a simple circuit that balances naturally and the charging current is typically a few amps, of course with the "normal" battery condition.
    Zbigniew 400, I am asking out of curiosity ... how old are you writing about?
    Because I remember that there were no miracles in the Polonaise, and the battery lasted the same as in modern computers on wheels ;)
  • #9 14936951
    ^ToM^
    Help: 495
    Rate: 2939
    The matter is simple and there is no contradiction here. An alternator with a rated current of 40 A can charge the battery with this current as long as the internal resistance of the battery allows it, and let me remind you that the resistance of the car battery is 5 mOhm. In fact, with a deeply discharged battery, the current can reach tens of amps, but only for a short while after starting the engine. As the voltage at the battery terminals increases, the current will decrease. In fact, the battery current is also limited by the resistance of the windings. As it is commonly known, alternators only have a voltage regulator, there is no separate current regulator (as in the old DC generators). It is not needed for the reasons mentioned above. So there is no harm to the battery in the car. The same can be designed a charger for a battery with a maximum capacity, e.g. 30 A, but with a voltage limitation, e.g. up to 14V. This will cause the connected, discharged battery to consume a large current for a short time, which quite quickly (as the voltage on the battery increases) will drop practically down to mA with a fully charged battery.
    Greetings!
  • #10 14936995
    Zbigniew 400
    Help: 283
    Rate: 794
    Old solutions are the Polonez / internal regulator that sets the voltage of the alternator /. In newer solutions, the computer controls the voltage depending on the condition of the battery, faster recharging / starts, winter / or lowering charging / temperature /. Alaska and Africa different voltages in the car's installation.
  • #11 14937095
    ^ToM^
    Help: 495
    Rate: 2939
    Zbigniew 400 wrote:
    Old solutions are the Polonez / internal regulator that sets the voltage of the alternator /. In newer solutions, the computer controls the voltage depending on the state of the battery, faster recharging / starts, winter / or lower charging / temperature /
    To my knowledge, this old solution is used to this day in 99% of cars on our roads. Controlling the alternator with a computer is maybe in some expensive Lexus or other hybrid inventions ;) Although, to be honest, I do not know why anyone would produce something like this for an ordinary car. All you need is an alternator and a voltage regulator.
    Zbigniew 400 wrote:
    Alaska and Africa have different voltages in the car installation.
    There is just another version of the regulator. For climatic reasons in Africa ~ 13.5V and in Alaska ~ 14.5V.
  • #12 14938402
    Falco76
    Help: 41
    Rate: 148
    This is the first time I hear about it ....
  • #13 14940684
    Xantix
    Help: 686
    Rate: 1657
    You are indeed right, normally all you need is an ordinary voltage regulator. But not nowadays, when you have to complicate everything as much as possible (so that everything should break) and connect to the computer. Today, new cars (and not those of the top shelf) use intelligent charging regulators controlled by the ECU. It is supposed to bring many benefits, extending the life of the batteries or reducing fuel consumption. But somehow I doubt these benefits ...
    http://truckfocus.pl/nowosci/6181/wazna-rzecz-regulatory-napiecia-w-alternatorach
  • #14 14940750
    kkknc
    Help: 1915
    Rate: 6705
    The fact that the rectifier has 6A and the alternator 50A, it only means that you can safely draw so much electricity from these devices for some time. And you get a lot more out of it, Ohm's law bows. And as for charging, I have already written here.
    https://www.elektroda.pl/rtvforum/topic100799.html#8930747
    I will only add that with this method of charging, damaged or sulphated batteries are heated. Serviceable and worn, but not sulphated. In addition, they do not gas and the entire charging process is fast.
    And so from myself I will add that after almost 3 years I finished 500 cycles of charging two 7.2Ah gel batteries. Charged quickly and slowly (one fast and the other slow with 1/10 current). Same result, both got used up at the same time. In fact, after 350-380 cycles, the loss of capacity was already visible. And after these 500, they only had 2Ah with a capacity of them, so I skipped the next cycles.
  • #15 14942926
    ^ToM^
    Help: 495
    Rate: 2939
    You see, it's worth reading an electrode - you can always learn something new. I have found out about it more than once. And by the way, I refer you to books on automotive electrical engineering where this problem is explained in more detail. The problem essentially concerns the charging voltage as a function of the ambient temperature. As it is known, in tropical countries the average temperature is different than in Europe or Alaska, hence the car for export to tropical countries receives different equipment (also a voltage regulator) than that for sale, for example, in Europe. There is nothing revealing here.
    Best wishes!
  • #16 14943043
    kkknc
    Help: 1915
    Rate: 6705
    In Kamazy there was a screw on the alternator marked winter / summer. In hot climates, the electrolyte in batteries has a lower concentration.
  • #17 14945284
    Falco76
    Help: 41
    Rate: 148
    Of course it's worth reading the electrode. Man learns all his life.
Charging a car battery at home with a 30A charger is generally not recommended due to potential damage to the battery. The typical charging current is often limited to 1/10 of the battery's capacity, while alternators can provide higher currents (e.g., 40A) under specific conditions. The alternator's output is regulated by its voltage, which is typically around 14.4V, allowing for varying charging currents based on the battery's state of charge. Quick charging methods (0.8C) can lead to overheating and reduced battery lifespan. Modern vehicles may utilize intelligent charging systems controlled by the ECU to optimize battery health, contrasting with older designs that lacked such regulation. Overall, while high currents can charge a battery quickly, the risks often outweigh the benefits.
