[Solved] Charging Ca/Ca Batteries: Car Alternators, Optimal Voltage (16.2-16.8V), & Effect on Electronics
murgrabia 39663 5
  • #1 17115932
    murgrabia
    Help: 16
    Rate: 70
    As the batteries made in Ca / Ca calcium technology. They require increased voltage during the final phase of charging. Up to 16V. It is usually 16.2-16.8V. Otherwise, the battery being charged will not reach the correct electrolyte density. And now the question: How is the Ca / Ca battery charged by a car alternator? It is known that the voltage in the vehicle does not exceed 14-14.8V. So generally it appears that such a battery does not have the correct electrolyte density. And rather there is no question of a long life of such a battery. Is this not a deliberate act? Most batteries are unable to look into the cell. And measure the electrolyte density. Ba, even in most modern cars. There is no question of disconnecting the battery during charging. Will the voltage of 16.2-16.8V damage the installation and electronic components?
  • #2 17116031
    Xantix
    Help: 686
    Rate: 1657
    Why? In an old Audi 80 I had a Ca / Ca battery and lasted exactly 5 years despite being not very careful.
    No. This is a compromise between battery life and the complexity of a charging system. To be able to charge a battery up to 16 V, the charge regulator would need to closely monitor the battery status and reduce the voltage to a safe level in time, otherwise the battery would be damaged quickly. Why complicate the charging system too much if the profits will be rather disproportionate in relation to costs and disadvantages?
    Well, because most of the currently produced batteries do not require topping up, so the manufacturer does not anticipate the need for access to the cell.
    In any vehicle more advanced than the c 330 there is no question of disconnecting the battery while the engine is running - it may damage the electronic components in the vehicle's equipment.
    A short-term voltage spike is unlikely to hurt, but is long-term voltage of this value safe - I would have doubts.
  • #3 17116032
    czareqpl
    Help: 196
    Rate: 580
    I recommend using the search engine ...
  • #4 17547557
  • #6 19325249
    murgrabia
    Help: 16
    Rate: 70
    Battery used in vehicle, inserted with correct density of electrolyte. After X time it loses the correct density. The alternator is unable to bring it to the correct density, the final saturation phase is missing. Such a battery has a visible white residue. Ca/Ca technology is not compatible with the charging of current cars. This is a deliberate ageing of the product.
