Honda Civic 2012: Understanding A Circle Arrow Indicator & Button Function on Dashboard
bolekf2 49581 7
  • #1 14981940
    bolekf2
    Rate: 258
    Hello, what does the indicator A in a circle with an arrow mean, as in the attachment on the board.
    Everything works, when you press the button on the console "A", the message on the console lights up, when you press it again, everything disappears. So I guess everything is ok as with ESP.
    But what is this button and light, what is it for?
  • #2 14982032
    ociz
    Help: 1379
    Rate: 3486
    The function that automatically turns off the engine when stationary is not available, the ideogram can guess that it is due to the poor condition of the battery.
  • #3 15026373
    norbi2566
    Rate: 41
    the start / stop function turns off the engine during a long stop, e.g. at a red light, my opinion is unnecessary
  • #4 15042630
    bolekf2
    Rate: 258
    Thank you for your help. greetings
  • #5 18493710
    Baron73
    Rate: 25
    Have you solved this problem?
  • #6 21529693
    skorpion201
    Rate: 24
    have you found the reason for this message?
  • #7 21538402
    ladamaniac
    Help: 724
    Rate: 2078
    Only computer diagnostics and correct interpretation of the parameters will help here. There are many reasons for this light, ranging from a weak battery, to faults with the measuring clamps, the warm-up phase of the engine, an open bonnet or even a driver's seat belt not being fastened (tested in Jeeps).
  • #8 21540010
    andrzej20001
    Help: 1578
    Rate: 6669
    9 out of 10 are batteries.
The indicator showing an "A" inside a circle with an arrow on the 2012 Honda Civic dashboard relates to the vehicle's automatic start/stop system, which turns off the engine during extended stops, such as at traffic lights, to save fuel. The button labeled "A" on the console activates or deactivates this function, with the corresponding message appearing or disappearing on the display. Common causes for the indicator to remain lit or the system to be unavailable include a weak or poor battery condition, issues with measuring clamps, engine warm-up phase, an open bonnet, or safety features like an unfastened driver's seat belt. Diagnosing persistent issues requires computer diagnostics to interpret system parameters accurately.
