Honda Civic VI gen. 2001 - CIVIC - The green key is flashing, the car does not s
osliczka 30453 15
Why is the green immobilizer key flashing on my 2001 Honda Civic and how can I restore engine start permission?
Your Civic’s flashing green key is being treated in the thread as a lost immobilizer/ECU synchronization, which leaves the ECU with “no permission to start” [#13909737] The suggested fix is to perform an immobilizer synchro or key/ECU re-coding with a diagnostic tool that supports Honda immobilizer functions; a Diagun was specifically recommended as enough to do it in a few minutes [#13911435] Autocom may read some parameters, but the replies imply it may not be sufficient for this job [#13912635] The thread does not point to a separate engine-bay wiring or cut-off issue to check first; the main diagnosis is the sync problem itself [#13909737][#13913160]
  • #1 13909605
    osliczka
    Rate: 169
    I have the following car problem. Honda Civic 2001 i.e. VI gen. The car was driving normally, but after reaching the place and turning it off, it no longer wants to start. A green key flashes on the dashboard. This indicates a problem with the immo.
    I used the second black key and no change. I do not have a red key or it was no longer present in this model. After connecting the autocom, there is proper communication with the ECU, but the parameters show the status of no permission to start the engine. So IMMO seems to be blocking it. I took the immo out from under the steering wheel, I could only measure the resistance of the coil surrounding the key - approx. 14 Ohm.
    Further searches led me to the ECU where after removing it and dismantling I did not see a vertically soldered immo plate as it used to be in the 5th generation of the model.
    The ECU is 37820-PLH-G01.
    I noticed that the wires from the cube from the immobilizer go in a common bundle towards the controller, but several of them are not connected to the plugs going directly to the car's controller, but are connected to a gray long cube from which the bundle goes through the bulkhead to the engine.
    What else can you check yourself, what installation points to exclude the obvious. How is the key coded in this model and how does the immo box under the steering wheel communicate the start permission signal to the ECU? Is it possible to bypass this system, at least enough to confirm for a moment that the problem is with the immobilizer and start the car?
    The starter spins even when I disconnect the immobilizer under the steering wheel, so there is no cut-off for the machine in this model. You can also hear the fuel pump when you turn the ignition on.
  • #2 13909737
    jokerro
    Help: 207
    Rate: 1146
    The synchro flew or there is no permission from the can for the ecu. So everything is still broken. I think that your mission is over. There is nothing more to check, the fault is found at your fingertips.
    It remains to zatargac the car to someone who will do a synchro.
  • #3 13909937
    osliczka
    Rate: 169
    ok, it will probably end like this, I just wanted to eliminate faults such as damage to the installation somewhere on the ECU immo road or somewhere in the engine compartment.
  • #4 13911435
    yaaro
    Help: 195
    Rate: 1083
    Look for someone with a diagun and a few minutes and you have a synchro.
  • #5 13911851
    osliczka
    Rate: 169
    and only the diagoon? Autocom won't go?
  • #6 13912186
    mariank32
    Help: 9
    Rate: 98
    I think you are asking too much from the equipment that costs as much as a few kilos of potatoes.
  • #7 13912635
    osliczka
    Rate: 169
    Apparently so, but I played with the diagun a few times and did not find any outstanding difference in its favor in relation to the autocom. Maybe it supports more old cars and has a wonderful red suitcase with adapters, but the procedures themselves were similar to autocom.
    Is there any other interface like HIM/HDS that can do this?
    One more thing, aren't there some idiotic pitfalls in this car like going through the coils or anything else in the engine compartment before the signal from the Immo reaches the ECU? Can the flashing green key on the board be only a symptom of lack of synchronization, i.e. key recognition, or can it signal any other Immo fault in the form of power failure or damage to one of the wires. A cube with 7 wires comes to Immo.
  • #8 13913082
    ozi-77
    Help: 8
    Rate: 106
    Don't you have some sort of secondary alarm or ignition cut-off?
  • #9 13913160
    jokerro
    Help: 207
    Rate: 1146
    Don't wind the noodles on your ears, the guy is blinking the key on the wardrobe. Synchro flew and that's it. He would have done it inexpensively a long time ago.
  • #10 13913185
    robek
    Help: 19
    Rate: 55
    I have a very similar problem with this model. The green light is flashing all the time, but the car starts. Unfortunately, the engine works normally only up to about 2500 rpm and above it cuts off as if there was no air. An additional fault is the lack of communication with the ECU. The situation does not change after unfastening the immo box, the engine starts normally and continues to throttle it.
    Anyone got an idea what could have happened?
  • #11 13913227
    osliczka
    Rate: 169
    Is synchro in your view the same as recoding immo keys?
    What is the concept of inexpensive and do you know anyone in the vicinity of Warsaw or the city itself who could do it?
    How do you manage to start the car after disconnecting the immo box?
    After all, without immo, the driver does not get "permission" to start.
  • #12 13913326
    robek
    Help: 19
    Rate: 55
    well, this is strange, but whether the immo is disconnected or connected, the car fires the same.
    The immo coil for me is also about 14 Ohm, so it is likely that it is good for me and for you.
    I will add once again that I cannot diagnose the ECU because there is no communication with it, the CHECK indicator is on all the time.
  • #13 13913339
    osliczka
    Rate: 169
    Which exact year of car do you have and with what engine?
    Maybe you've already had the immo picked out and hence the effect, or it only signals a defect that allows you to start it. What do you want to connect this honda with? Autocom sees nothing but the current parameters from the engine and the fact that it is not allowed to start the engine from the immobilizer.
  • #14 13913341
    Pawel wawa
    Help: 1262
    Rate: 4433
    Damaged driver. There is a chance that if you disconnect the battery for a long time, it will not start again. The subject is known.
  • #15 13913616
    jokerro
    Help: 207
    Rate: 1146
    osliczka wrote:
    do you know someone in the vicinity of Warsaw or the city itself who could do it?
    Look above and read what your friend has in the description, even the phone and it will even arrive.
    He'll fly in, do whatever it takes, and after the race.
  • Seeking a PLH-G01 ECU replacement or repair in Warsaw
    #16 14194798
    MarcinWa22honda
    Hello, I have the same problem with the computer, literally the same. I can't get such a computer with this Plh-G01 designation anywhere. How did you deal with yours?
    Added after 9 [minutes]:
    I will add that the car has been in the service for two months, nothing can be done with the old computer, it does not accept any software, I even bought another driver with the designation Plh-G02 and it turned out that it does not fit and errors pop up.
    I'm also from Warsaw and that's why I'm asking how you dealt with it, who fixed it for you, because I'd love to go there.
The discussion revolves around a 2001 Honda Civic (VI generation) experiencing a starting issue, indicated by a flashing green key on the dashboard, suggesting an immobilizer (immo) problem. The owner has tried using a second key without success and has confirmed communication with the ECU via diagnostic tools, but the engine remains blocked from starting. Responses suggest that the issue may be related to synchronization failure between the key and the ECU, and recommend seeking a professional with specific diagnostic tools (diagun) for synchronization. There are concerns about potential wiring issues or secondary alarms affecting the immo system. One participant shares a similar experience with the car starting but cutting off at higher RPMs, indicating possible ECU communication issues. The discussion highlights the importance of proper diagnostic equipment and the potential need for professional intervention to resolve the immo-related starting problem.
