Honda CRV III: DPF Filter Light & Hidden Firing Indication - Seeking Insights on Signaling Methods
650ccm 15933 5
  • #1 16345793
    650ccm
    Rate: 29
    Hello, gentlemen. Because of this in my autku is dpf filter I wanted to ask if any of the forum users know if there is any hidden filter firing indication in Honda ?? There is a DPF control on the board but it lights up when the filter is already dirty. Being in the workshop when firing the filter in the service mode, I heard that some cars have a hidden firing signal, eg by turning on the mirror heating (regardless of weather conditions). Some magicians supposedly do signaling on the diode and it is known when the firing procedure follows, because without this it is a lottery. Can anyone cope with anything?
  • #2 16346351
    damdam
    Help: 274
    Rate: 950
    you can observe - the chimney's sound of the engine's operation, the momentary combustion by several dozen percent, but to tell you the truth, if you use the car in a mixed cycle - why exactly do you know when it's regenerating?
    ACME Damian Michalski
    Boczna 3a, Żory, 44-240 | Tel.: +48XXXXXXXXX (Show)
  • #3 16346607
    650ccm
    Rate: 29
    I have recently had a car and it's hard to know the characteristic sound of the engine. The problem is that the car is used mainly in the city cycle, and I would like the control to be able to finish it properly at the start of the firing procedure.
  • #4 16873258
    Mirek1303
    Rate: 9
    I am the owner of crv 2.2 2014r maybe you figured out the subject of dpf control in the previous I bet on heating rear window or mirror and checked in crv I used for heating mirrors but does not activate the diode spontaneously husband maybe some info which is attached during firing dpf I will be grateful
  • #5 16873281
    650ccm
    Rate: 29
    I have not figured out the topic. I was in a "cleansing" car with this benefit and the problem was put to good.
  • #6 16873295
    Mirek1303
    Rate: 9
    Hello, have you had any accidents with this model which is average combustion ??
