Audi A3 8P - Turning off the yellow power indicator on the clocks.
majuDJ 16743 4
  • #1 16983318
    majuDJ
    Rate: 35
    Can anyone help me and tell me how to turn off the yellow / red assist lamp on the clocks of the Audi A3 8P from 2004 prelift? It's best if it was a VCDS 17 instruction. Where should coding be changed and what values should it be?
    The car has a problem with the G269 assistance torque sensor, error 00573, signal incorrect constant. The yellow steering wheel indicator lights up immediately after firing but everything works.
    The complete maglowka was replaced by a mechanic once installed, second generation, but it was out of the way and after 300km (2 days) the indicator light came on and the guarantee was gone and several hundred zlotys went down the drain.
    I would like to avoid the problem during the review.
  • #3 16987733
  • #4 16987789
    majuDJ
    Rate: 35
    migmig85 wrote:
    How could that make any sense. You think I'm stupid and I didn't do it anymore, so I dumped a few hundred zlotys for the exchange of maglists.
    Falubaz1 wrote:
    decode geatway support and abs from the list of connections
    Can you ask more clearly and step by step?
  • Intermittent ABS sensor fault may trigger steering wheel light
    #5 17161906
    majuDJ
    Rate: 35
    The yellow steering wheel indicator comes back, once every 7 km, once after 300km. It clears the error and I have some peace or the next time I start the car it comes back and on. I repeat the question:
    Gentlemen or ABS error
    0283 - ABS system; wheel speed sensor; front left (G47)
    012 - Electrical fault in the circuit - Occasional
    can be affected by an error display and a yellow steering wheel illuminated ????
    00573 - Steering wheel torque sensor (G269)
    008 - Misunderstood signal
    Maglownia II gen 1K1 909 144 J
