AUDI A6 C7 - WHICH ENGINE TO CHOOSE THE AUDI A6 C7 2.0 OR 3.0 TDI
Mariusz-M396 136833 9
Which Audi A6 C7 engine should I choose: 2.0 TDI or 3.0 TDI, and what should I check before buying one?
The 2.0 TDI is cheaper to run and repair, but the 3.0 TDI gives more driving pleasure; many users warn that buying a C7 with an engine below 200 HP is a poor choice [#15004895][#16405296] The biggest cost risks are the automatic gearbox and air suspension, which can become expensive “piggy banks” if they fail [#15004895][#16300189] For the gearbox, front-wheel-drive 2.0 TDI versions with Multitronic were called poor, while 2.0 TDI quattro or 3.0 TDI quattro were preferred; manual was considered the safest option [#16317555] One owner reported 7.5 L/100 km on a 2.0 TDI 177 HP manual on a 3,660 km trip with four people and a roof rack at up to 140 km/h [#15304963] For the 3.0 TDI, the common 245 HP version usually comes with S-tronic; it is said to be acceptable if the oil is changed, but a failure can cost about 6–7 thousand PLN [#16405296] Before buying, have the car checked at a dealer or specialist, especially if it has over 200,000 km [#15004895]
  • #1 15004488
    Mariusz-M396
    Rate: 12
    Hello, I would like to know more about the Audi A6 C7. Which engine to choose 2.0 tdi or 3.0 tdi What to pay attention to when buying a tgego car Air suspension is very emergency?
    Added after 6 [minutes]:
    And the Automatic transmission is very Emergency? What is the fuel consumption of this car at 2.0 TDI and at 3.0. What are their most common faults. With the 2.0 TDI engine they are doing well, is it a bit too little? I am planning to buy such a car and I would like to know as much as possible about them.
  • #2 15004650
    vagteile
    A6 C7 -2009 or 2009- because it is a significant difference.
  • Dealership inspection is crucial for high-mileage A6 C7s
    #3 15004895
  • #4 15005214
    Mariusz-M396
    Rate: 12
    Audi A6 C7 which has been produced since 2011.
    And the burning of the 2.0 TDI engine as it is. I think to buy a 2.0 TDI, chip it for some 210 HP It probably wouldn't be that bad. What do you think about this? Better to choose Automatic or DSG?
    Means Automatic traditional or DSG
  • #5 15304963
    gregoir250
    I have an A6 C7 2011. 2.0 tdi 177 hp manual. on the Poland-France route, a total of 3,660 km with a roof rack and four people on board, not exceeding 140 km / h. the average was 7.5L.
    Previously, the same route in the same line-up and with the luggage compartment of the Passat B5 FL 1.9 tdi 101 km, the average was 6.3L.
  • 2.0 TDI saves costs while 3.0 TDI improves driving enjoyment
    #6 16300189
    kisek123
    Rate: 9
    You are faced with a difficult choice, the same as I had. Whether to buy a manual with 2.0 tdi and have cheap operating costs or enjoy driving and buy a 3.0 tdi but incur high maintenance costs. Cars will vary a lot in maintenance costs. You can replace the manual and drive, while the automatic machine costs a lot of oil change over a thousand zlotys and it would be useful to do it every 80,000. Do not push the multitronic and the s-tronic will be more expensive in the event of a failure compared to the tiptronic. When it comes to the engine, you need to realize that 3 liters has 6 cylinders, so there are 6 shocks, 6 candles, two heads, and thus in the event of a breakdown, the costs increase compared to the regular R4. Well, the timing, which is already great in C7, but I would be careful about it. And when it comes to air suspension, this is another piggy bank. You have to think, buddy, if you want more driving fun or lower maintenance costs and then you have to answer what to take.
  • #7 16317555
    r_Lunar
    Rate: 32
    if the 2.0 tdi with front-wheel drive you will have multitronic which is junk. so either the 2.0 tdi quattro because it is a completely different gearbox or the 3.0 tdi quattro. and the best is manual
  • #8 16317628
  • #9 16405296
    ygrek1975
    In my opinion, buying this car with an engine below 200 HP is a bad choice. Unless you're really a disemboweled person (I mean while driving) ;)
    TipTronic is available in this model for 3.0 engines only above 300HP. Very rare. Manual available in the 3.0 engine only in the 204HP version. So we are a bit doomed to the S-tronic (or DSG) with the most common 245HP engine. 245KM was not "married" to another gearbox. It is not a bad chest. Of course, it can break down like any other, and then the repair costs about 6-7 thousand PLN. But this is probably the 3rd generation of these boxes and it is not so emergency. Oil has to be changed and that's it.
  • #10 16405609
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    Well, buddy, the particle filter bows. But if you are aiming for diesel with rings on the grill, remember that each ring is an expense and often.
The discussion revolves around the choice between the Audi A6 C7 2.0 TDI and 3.0 TDI engines. Key considerations include maintenance costs, driving pleasure, and fuel consumption. The 2.0 TDI is noted for being cheaper to operate and repair, but it lacks driving excitement. In contrast, the 3.0 TDI offers better performance but incurs higher maintenance costs due to its complexity. Automatic transmissions, particularly multitronic, are criticized for being unreliable and expensive to repair. Fuel consumption for the 2.0 TDI averages around 7.5L/100km, while the 3.0 TDI is expected to be higher. Air suspension is highlighted as a potential maintenance issue. Recommendations include opting for the quattro version for better performance and reliability, and considering manual transmission for lower costs.
