[Solved] Audi RS6 C5 vs S6 C6: Which to Purchase with a Budget of 50 to 70 Thousand?
SZYMON BYDGOSZCZ 13146 14
  • #1 16289565
    SZYMON BYDGOSZCZ
    Help: 340
    Rate: 1705
    As the topic.
    Waiting for and against the Audi RS6 C5 or S6 C6 ?
  • #2 16289602
    siewcu
    Help: 133
    Rate: 458
    With this budget? None. The S6 has an emergency engine, and the RS6 is probably not the budget if it is to be healthy art. In both cars the starter pack will not be cheap either, so if the budget is for the car and the starter pack, then you may think about S4 B5 (B6 too, but here again engine problems), maybe S6 C5. Recently, I even talked to someone who was looking for a nice RS6 C5 - 70k is the absolute minimum if you want to think about a nice, healthy and well-kept car.
  • #3 16289611
    SZYMON BYDGOSZCZ
    Help: 340
    Rate: 1705
    Do you mean overheating of the rear cylinders?
    siewcu wrote:
    The starter pack will not be cheap either
    This is separate - about 10,000 is enough (unless c6 will have ceramics it is not enough).
    siewcu wrote:
    if it is to be really healthy art
    Only this is at stake.
    The car is to be used occasionally - about 5 - 10,000. km per year.
    What to avoid
    siewcu wrote:
    maybe S6 C5
    299-340 hp - a bit low.
    Added after 13 [minutes]:
    B6 seems to have the same engine as C5 S6.
  • #4 16289634
    siewcu
    Help: 133
    Rate: 458
    If you want to ride occasionally, this is a strange choice in my opinion - these are, however, heavy and large cows. And answering: V10 with S6 C6 has many different problems with the engine - it overheats, I have also heard about shells and oil pump. When it comes to avoiding - the S4 B6 has a lot of problems with timing, emergency phasers and the topic is very difficult to understand (besides, I am not sure if the RS6 C5 does not have the same problem - 2x2500 phasers + camshaft). And if it is supposed to be a car for driving and possibly freezing cash, I would be looking for some classic or S4 B5 + reinforcement - for 70 thousand you will break through the RS6 C5 powerfully, although it is a completely different category of car. Alternatively, some Porsche, although on a turbo budget is at least 2 times, preferably 3 times.
  • #5 16289637
    SZYMON BYDGOSZCZ
    Help: 340
    Rate: 1705
    That's right - not this price range.
    For a moment there was the Cayenne 4.8 turbo option but also the problematic engine - overheating of the rear cylinders.
    Added after 9 [minutes]:
    siewcu wrote:
    RS6 C5
    It's turbo.
    siewcu wrote:
    S4 B6
    There is no turbo.
  • #6 16291898
    siewcu
    Help: 133
    Rate: 458
    Well, I know that the S4 B6 is a Wolossak, just like the S6 C6 - only none of the cars listed by you can be bought in the budget, if it is a well-kept copy that will not require the investment of a dump truck ... be turbo and give driving pleasure, I would leave such cars as in the subject and look for, for example, STi Events. On Lancer Evo a bit budget. Possibly S3, though a bit small (or A3 3.2 + turbo), or S2 - but it's a classic and very hard to find. And if you want more help, it would be best if you wrote what are the assumptions about buying a car - without guessing you can help specifically.
  • #7 16292002
    Kantylena
    Help: 18
    Rate: 222
    Audi Rs6 C5 - this one you will find quietly around 2002-2003, just beware because there is a 4.2 V8 engine ordinary injection but double-charged (bi-turbo), whatever you sprinkle, you have a chapel right away.
    And you didn't think about 2.7T at the beginning? in ordinary A6 C5? you will find a good tuner and it will draw cool powers and yet the unit is a bit cheaper to maintain than such engines where any sensor is thousands of zlotys.
    possibly 1.8T, but here you have to walk a lot, but you will reach 280 by calmness.
    You can also look for the Audi A4 B7 1.8T will be quite a young car and for the rest of the money 20,000 calmly spend on even 300 horses.
    All those old RS6 S6 etc. A8 will pull hard on the pocket with these high mileage engines.
  • #8 16292262
    siewcu
    Help: 133
    Rate: 458
    Well, he will find. Checked copy. But you can see quite well that you lack knowledge in mechanics and tuning ... Because:
    1) Biturbo in V8 has nothing to spill it
    2) With 2.7 biturbo with A6 C5 too much can not be done, without another 1,000 you can not jump 300 KM
    3) 1.8T at 280 hp will also not be cheap, turbo + intake + exhaust + injection is just the beginning - and you are doing breath, and the car will not want to go, because it's too heavy.
    4) Buying A4 1.8T and putting 20,000 in them is pointless, you can spend this money better and have a car once that faster, and two - not losing value at such a pace.
  • #9 16292373
    Kantylena
    Help: 18
    Rate: 222
    So for your suggestions great, uturbie 3.2 V6 ... what ??
    engine, wheels, clutch, gearbox etc. .. maybe 30k is enough for him + purchase of the car and in a moment the car will be 10 years old and flowers will start coming out + bad driving.
    Or Audi S2..no fact, he can look for one copy all over Europe, it is best to recommend him a Saab 900 turbo from 80 years and the author's budget note 70 thousand ... :D
    So in the will to clarify the Audi RS6 C5 will find it calmly, because it's 15-year-old cars, how much is it supposed to cost 2 million ??
    1.8T 270 horses ride as if you were interested in:
    At least in the case of A4 B7 the author will find a young healthy car and not refuse bins for the second price that you propose to him.
    And what about this V8 I do not understand? where did I write that due to biturbo something is supposed to go wrong?
    I don't know who lacks any knowledge here, because I don't think so.
  • #10 16292386
    andrzej lukaszewicz
    Help: 623
    Rate: 2109
    For a dignified rocking of large and slightly "faster" cars for reasonable money you can buy a 10-year non-tired "brick" 6.1 SRT 430KM. It is true that this is not S6, but rather for straight-ahead, only one-wheel drive (which may be an advantage for some).
  • #11 16294205
    siewcu
    Help: 133
    Rate: 458
    Ok, based on a movie from the internet you say about how a given car goes? Did you actually deal with such cars or just want to "help"? Lack of knowledge can be seen e.g. after ...
    You don't know what you write. Something is calling, but you did not deal with tuning. Video from the internet, replacement of the box which accepts 800+ hp, wheels ... If you have never had anything to do with such a car, do not write about it, and try yourself on the passenger seat in the A6 C5 / C6. You have no practical knowledge in this topic, and you criticize me - I drove the A6, I also drove cars on the Golf 4 disc - and if you say that the S6 C6 / RS6 C5 will drive better than the S3 with VR6 ... Maybe you better not write no statements here because you're just sinking. And you do not understand the idea of having a car that gives you pleasure from driving, although this is a subjective matter - but driving an A4 B7 will not give you any pleasure from driving.
  • #12 16294840
    Kantylena
    Help: 18
    Rate: 222
    I am already lost in this discussion and I will just ask what is this car?
    siewcu wrote:
    S3 with VR6 ...
    VR6 is a Golf III engine, the S3 has 2.0 TFSI, besides the S3 is a sports compact with a quattro drive.
    If you mean 3.2 V6 is a slightly different engine, understeer, e.g. put two 10 kg nets on the handlebar of a bicycle and ride it, you will understand and read about engine turbo operation but this is not an oil change, really!
    Returning to the topic can find the RS6 C5:
    http://allegro.pl/show_item.php?item=6723789036#thumb/5
    you can also choose another car, e.g.
    https://www.otomoto.pl/oferta/volkswagen-golf...agen-golf-vi-r-270km-ID6yEayb.html#666620a071
    and play for now in Stage II, i.e. modify the exhaust system and there will be 340 horses and 420 Nm and it will be less than a hundred seconds
    You can search for BMW M3 E46 etc etc ...
    I end this discussion because it makes no sense. The author has already presented everything.
  • #13 16295003
    siewcu
    Help: 133
    Rate: 458
    And so much about your competences. A3 3.2 was sometimes referred to as S3, but V6 is not. Find, read and then make your decisions.
  • #14 16295096
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4171
    Szymon, buy turbo gas. It gives you great fun from driving. And this turbine whistling ...
  • #15 17730940
    SZYMON BYDGOSZCZ
    Help: 340
    Rate: 1705
    I bought a Mercedes S400 hybrid.
✨ The discussion revolves around the decision to purchase either an Audi RS6 C5 or an S6 C6 within a budget of 50 to 70 thousand. Participants express concerns about the reliability and maintenance costs of both models, highlighting the RS6 C5's bi-turbo V8 engine and the S6 C6's V10 engine, which are prone to overheating and other mechanical issues. Suggestions include considering alternatives like the S4 B5 or B6, which may offer better reliability. The consensus is that finding a well-maintained RS6 C5 within the budget is challenging, and potential buyers should be cautious of high maintenance costs associated with older performance vehicles. Some participants recommend exploring other brands or models, such as Porsche or Subaru, for a more reliable driving experience.
