A6 c5 - A6 c5 2.4 advantages and disadvantages of the engine.
endriu110694 37251 20
What should I check for when buying an Audi A6 C5 with the 2.4 V6 engine, and what are its pros and cons?
The main things to watch for are oil leaks and the gearbox choice, because the 2.4 V6 is considered smooth but not very exciting, and with an automatic it feels sluggish [#17020775] [#17030325] Check the underside of the engine carefully for leaks from the valve covers, rear plugs, adjuster, shaft seal housing and oil sump, because owners report that these engines often sweat oil almost everywhere [#17020775] [#17029784] [#17029892] Before buying, connect VAG diagnostics, read the engine faults, drive a few kilometers, and read the errors again, while also listening for disturbing noises, checking exhaust color and engine culture [#17030363] [#17020775] Fuel consumption is about 11 liters in city driving, so it is not an economical engine [#17020775] Running costs are otherwise described as normal, except for the front suspension, which is the priciest common item [#17020775] Timing is said to be cramped, but it can be done from the front [#17031378]
  • #1 17020386
    endriu110694
    Rate: 13
    Hello, I'm going to buy a6 c5 with 2.4 engine without lpg, the network has a lot of information quite contradictory, what to be careful when buying this model, I mean mainly the engine because all the other pros and cons of this car I know how it is with combustion in this model and how the exploitation of this type of car comes out. Thank you in advance for all the advice and greetings.
  • Common oil leaks and front suspension costs on 2.4
    #2 17020775
    drdrug
    Help: 25
    Rate: 178
    It depends on whether the manual or the machine. I had such a 2.4 ball in the machine and generally I would not buy it for the second time. At least not again with this chest. As for me, this engine combined with this machine did not give any fun for the ride, it just was muddy despite such capacity in V''ce, but for a low power. Even a6c6 2.4 BDW in the machine is rolling. As for the engine, it was ok, the only problem I had (270 thousand of the raid) and it was probably my fate, oil spills. And this is leakage from the valve covers, from the rear end caps, the adjuster, etc. As I have already done, it is later from the shaft seal housing from the side and the oil sump. And after about 2-3 months of peace, the oil began to sweat from under the right head :-) .
    Well, beware of vending machines, note the underside of the leaks are always unfortunately, the color of the exhaust, the culture of the engine and if there are any disturbing noises.
    Mi Audi burned about 11 liters when driving in a chimney. When it comes to some exploitable topics, the most expensive element is the front suspension, the other suspension parts, other operating parts such as timing gear, accessories, candles, etc. are in normal money.
  • Comprehensive seal replacement cost for the 2.4 V6
    #3 17020985
    endriu110694
    Rate: 13
    Audi is in manual with 2 years gas, 243 raid. After the appearance of the interior you can agree + -100 thousand :D I know the whole subject perfectly because I had a4 and is interested in the subject, the only unknown for me is this engine, I chose it in general because the work 4garow is tiring, clatter of diesel and gasoline is a massacre and such a relaxed v6 without turba will probably be ok, and as a colleague you worked the subject of the seal is how much of such a comprehensive seal of this engine can be? So that after purchase, do it and have it off your head.
  • #4 17025956
    endriu110694
    Rate: 13
    Does anyone have any suggestions on what to look for when choosing this engine?
  • #5 17029784
    Cobrat
    Help: 35
    Rate: 501
    Oil spills from everywhere ... Drive through 2.4 and 2.8 ;) .
  • #6 17029892
    milejow
    Help: 1563
    Rate: 5149
    drdrug wrote:
    it was probably my fate, oil spills. And this is leakage from the valve covers, from the back plugs, the adjuster, etc.
    This engine was dry only on the production line.
    endriu110694 wrote:
    Someone has some suggestions
    Ma-2.8, because this one does not drive and it burns similarly.
    Działalność własna
    Mętów 99, Lublin, 20-388
  • #7 17029963
    endriu110694
    Rate: 13
    When it comes to power, 2.4 is enough, I had the opportunity to ride as a passenger but it gives me advice (at least for me) and what about 2.8 is it probably the same as 2.4? ;)
  • 1.8T preferred over 2.4 for tuning and LPG
    #8 17030325
    Kantylena
    Help: 18
    Rate: 222
    I have to choose 1.8T - much nicer, it travels similarly and there is a chiptuning option, which you will not do in a naturally aspirated, 2.4 nice sounds but otherwise nothing interesting.
    Years later, the horses disappear, the engine seals, I do not know if anyone but a lot of these engines require dismounting the whole while timing.
    with lpg it can also be a heavy topic because 6 gars.
    I would let it go and take it as it was set here for 2.8, although for me the better option is 1.8T + soft and for this sub-oxide lpg.
  • Recommend VAG diagnostics before buying A6 C5
    #9 17030363
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    And where is the AGA efficient?
    Before buying, of course, hook up Vagine and read the errors of the engine, drive a few km and read again.
    How efficient it tears asphalt and accelerates well.
    Bigger than the stupid 1,8T, which pulls like a turbo will wake up and tug at me which pisses me off.
    In addition, no one buys A6 in order to race with half-timbres in leons and 1.8T.
  • A6 C5 buyers value comfort over engine choice
    #10 17030393
    endriu110694
    Rate: 13
    So divided sentences, I felt so, but considering that with the car is not related to the whole life, I will take a chance, I am tempted to v6, but I am still waiting for opinions of those having and using everything they bring ;)
    And referring to a colleague above, it is exactly as you say buys a6 because of the comfort and spacious interior and the engine expects a high work culture and flexibility.
  • V6 is quiet and accelerates smoothly to 180 km/h
    #11 17030445
    Help: 1405
    Rate: 6430
    What do you want to know?
    Calm and easily accelerates to 180km / h you can drive at this speed and it's quiet.
    I do not buy from 10 owners in Poland which is easy to check in CEIDG because it will certainly be ripped.
    The most reliable are straight from abroad. I do not even know where you're from because you did not deign to fill in the fields.
    In Germany or Austria v6, you will buy a good condition for 5-8 thousand PLN.
  • Fresh oil change planned after purchase
    #12 17030461
    endriu110694
    Rate: 13
    As I said about the a6, I know practically everything about operation but not about this engine ;) I wrote it well because I have a little better overview of the problems. Of course, when I buy v6, I count with costs is simple, but I am pedantic when it comes to the car and if there are still leaks I will be in ..... :| Although on the other hand, if it drips, it means that there is oil :D
    And of course, right after the purchase, I would have a good oil because it's the basis and I do not have time to buy abroad, but I am looking for a freshly imported car, complementing my friend I am from near Zamość ;)
  • 1.8T offers better acceleration and overtaking flexibility
    #13 17030567
    Kantylena
    Help: 18
    Rate: 222
    Look neat 1.8T how you want to have peace
    For example, 1.8T AJL 180 horsepower is 8.5 to a hundred and vmax 230 km / h
    2.4 - 165 horses - 10.5 to hundreds and vmax 205 km / h
    AJL 0-180 about 25 seconds
    2.4 0-180 about 45 seconds
    with the rest up to 180 km / h, it is just golf 1.6 accelerates what is the issue of how and when it dies or whether it still has strength.
    When overtaking is also an important flexibility here unbeatable turbo, from 2500 thousand goes like f16
    Remember that the moment gives you this push in the turbo chair is the room for maneuver in the slow-motion not too much, and after many years, as I wrote, horses like to run away.
  • #14 17030631
    Help: 1405
    Rate: 6430
    Kantylena wrote:
    with the rest to 180 km / h, it's just golf 1.6 also speeds up what this achievement is
    As I thought trolling, compare the dimensions of G4 and A6.
    Kantylena wrote:
    Remember that the moment gives you this push in an armchair
    This is what I do not like most in dizzy. But the A6 c6 fortunately has a torque limiter and this tearing is less noticeable.
  • #15 17031378
    Cobrat
    Help: 35
    Rate: 501
    Come on with that 1.8T to this stall ... But who likes it. I rode 2.4 and 2.8. If I personally chose, then of course 2.8 (For prying and inquisitive - "magic rings" generally do not speak to me, so I will not buy ;) ). Some of the guys I know, some have 2.4 other 2.8, after traveling 2.8 everyone has one statement - he would not buy again 2.4. Operating costs approximate, and driving .... I know and delinquent with 1.8T in this shed, clean gasoline and is also happy, but he just makes a retiring ride from point A to B.
    PS. Timing - a fact, cramped, but you take off the front, you sit down and do what the problem ...
    And 1.8T if you gas it with your head, not at a cost like what some ...
  • #16 17031392
    endriu110694
    Rate: 13
    But these 2.8 are much harder to hit than 2.4 :D
  • #17 17031402
    Cobrat
    Help: 35
    Rate: 501
    I know exactly because anyone who has this rides. A lot of 2.4 are imported, in addition usually to fees, so 18.6% ...
  • #18 17031404
    andrzej20001
    Help: 1578
    Rate: 6669
    And 2.8 fewer piles ..
  • #19 17031439
    Cobrat
    Help: 35
    Rate: 501
    And with regard to this 1.8T. Last year, at the request of a friend, we were looking for A4 B6 1.8T (popular small game). We traveled, we watched, we checked, most of everything brought back, prices for grain. This 1.8T unit has become glorified and gilded like the legendary 1.9TDI !!! And really with a clear conscience there was nothing to choose from. In the end, the friend gave up the requirements and bought the A3 aspirated.
  • #20 17032004
    endriu110694
    Rate: 13
    More and more doubts :D 1.8 t very cool for the job but for me it's totally unnecessary 150 + it's enough power for me, much more price when I overtake and do not leave the smoke screen and I do not have to add a liter of oil for 1000 km, I was talking today with a friend mechanic and said these spills are not so bothersome and it is very important to have good oil and temporary servicing, as to 1.9, it is not perfect too. 2. I care very much about the engine, zero on cold oil, oil every 10,000, cooling turbine after driving, always better pus and somehow here the pneumothorax, here the elastic joint here the fuel pump here gasket under the bowl, so that the ideal engines are probably not there.
  • #21 21577767
    arturjankowski51
    Mate, I have a 2.4 ben. What 180? Tell me how I can send you as it goes 235 km/h, also what are you talking about?
The Audi A6 C5 with the 2.4L naturally aspirated engine presents a mixed reputation among users. The engine is noted for its smooth operation and adequate power for relaxed driving, but it lacks the performance and flexibility of turbocharged alternatives like the 1.8T. Common issues include frequent oil leaks from valve covers, shaft seal housings, and oil sumps, which are typical for this engine and should be expected. Maintenance can be demanding, especially regarding timing belt replacement, which requires significant disassembly. The 2.4L engine consumes more fuel and oil compared to turbocharged variants and offers slower acceleration (0-180 km/h in about 45 seconds) and lower top speed (~205 km/h). Users recommend careful inspection for oil leaks, engine noise, and exhaust color before purchase. The 2.8L V6 is considered a better option by some but also has its drawbacks. The 1.8T turbocharged engine is favored for its better performance, tuning potential, and fuel efficiency, though it may not suit those prioritizing simplicity and low power. Overall, buyers should prioritize engine condition, especially oil tightness and timing belt status, and consider the trade-offs between engine smoothness, power, and maintenance costs when choosing the A6 C5 2.4L model.
TL;DR: Considering an A6 C5 2.4? Expect ~11 L/100 km, and "Beware of vending machines." We cover checks, leaks, manual vs auto, performance, LPG, and timing. Best for buyers wanting smooth V6 comfort without surprises. [Elektroda, drdrug, post #17020775]
Why it matters: The right pre-buy checks and expectations prevent costly oil-leak reseals and disappointing automatic-transmission drivability.
What are the real-world pros and cons of the A6 C5 2.4 V6?
The 2.4 V6 runs smoothly and suits relaxed driving. Expect modest acceleration versus turbo options. Oil leaks from multiple seals are common with age. Automatics can feel 'muddy'; "Beware of vending machines." Fuel around 11 L/100 km when pushed. Front multi-link suspension is the costliest wear item; other parts are reasonable. [Elektroda, drdrug, post #17020775]
What should I check before buying an A6 C5 2.4?
Use a scan tool and a structured test drive. Do this:
  1. Scan the engine with VCDS, save codes.
  2. Drive several kilometers, checking pull and smoothness.
  3. Scan again to spot returning or new faults. This reveals hidden issues quickly and safely. [Elektroda, Strumien swiadomosci swia, post #17030363]
Is the automatic gearbox a bad match for the 2.4?
Many owners find the 2.4 with an automatic feels dull. One reports the combo "did not give any fun," calling it 'muddy.' Manual gearboxes deliver a more responsive feel. If you must buy auto, test drive thoroughly. Check for smooth shifts and hesitation. [Elektroda, drdrug, post #17020775]
How does 2.4 performance compare with 1.8T and 2.8?
Reported figures: 2.4 0–100 km/h ~10.5 s and vmax ~205 km/h. 1.8T AJL 180 hp does ~8.5 s and 230 km/h. A cited 0–180 km/h comparison shows 1.8T ~25 s versus 2.4 ~45 s. The turbo’s torque improves overtaking flexibility. Consider your driving style and priorities. [Elektroda, Kantylena, post #17030567]
Where do 2.4 V6 oil leaks come from?
Typical sources include valve cover gaskets and rear end plugs. Cam adjuster seals and the crank seal housing also seep. The oil pan gasket area can weep after time. One edge case reported sweat from under a head after reseal. Inspect from below with a light before buying. [Elektroda, drdrug, post #17020775]
Is chronic oil seepage basically "normal" on the 2.4?
Owners often accept minor sweating as age-related. One expert summary says, "This engine was dry only on the production line." Expect to refresh gaskets during ownership. Budget for periodic resealing on higher-mileage units. Clean the underside and monitor over time after repairs. [Elektroda, milejow, post #17029892]
What fuel consumption should I expect from the 2.4?
Plan around 11 L/100 km when driven briskly. Gentle highway use can do better, aggressive city use worse. Automatics and short trips push the number up. The 2.4 trades economy for smoothness and simplicity. Verify with your own route and style during test drives. [Elektroda, drdrug, post #17020775]
Is LPG a good idea on the 2.4 V6?
It can work, but setup is more involved on a V6. Six cylinders raise component count and calibration effort. Poor installation can cause drivability issues and backfires. Choose an experienced installer and quality components. Check service records if a car is already converted. [Elektroda, Kantylena, post #17030325]
How hard is timing-belt service on the 2.4?
Access is tight, but removing the front clip helps a lot. With the front off, belt work is straightforward for a pro. Plan downtime and ensure proper locking tools are used. Replace related rollers and the water pump while in there. This approach minimizes repeat labor later. [Elektroda, Cobrat, post #17031378]
How much to reseal a 2.4 V6?
A full reseal typically covers valve cover gaskets, end plugs, and cam adjuster seals. It can include crank seal housings and the oil pan. Scope varies by leak sources and access required. Labor dominates cost due to packaging complexity. Get itemized quotes that match the leak list. [Elektroda, drdrug, post #17020775]
Why do some suggest the 2.8 instead of the 2.4?
Owners say the 2.4 feels underpowered in the A6 body. The 2.8 V6 pulls stronger with similar everyday economy. "Take 2.8," one advises, reflecting satisfaction with its drive. If availability permits, test both back-to-back. Choose based on your performance expectations. [Elektroda, milejow, post #17029892]
Is 1.8T a smarter buy than 2.4 for pace and tuning?
If you want speed per złoty and tuning headroom, yes. The 1.8T matches or beats 2.4 pace and accepts a safe remap. The 2.4 mainly brings V6 sound and smoothness. Older engines can also lose some horses with age. Pick based on priorities, not badge lore. [Elektroda, Kantylena, post #17030325]
I prefer comfort and smoothness. 2.4 or 1.8T?
Choose the 2.4 if you value linear, quiet delivery. Some dislike the 1.8T’s on-boost surge in traffic. One owner notes the turbo “wakes up and tugs,” which annoys them. The A6 cabin suits a calm V6 character. Test both to feel the difference firsthand. [Elektroda, Strumien swiadomosci swia, post #17030363]
Why are 2.8 cars harder to find than 2.4?
Owners tend to keep the 2.8 because they like driving it. Many 2.4s are imported, often sold “to fees.” One member noted ~18.6% import charges on such deals. Expect fewer 2.8 listings and act quickly on good ones. Verify paperwork and history for any import. [Elektroda, Cobrat, post #17031402]
Can a stock 2.4 really do 235 km/h?
Published forum figures cite about 205 km/h as the 2.4’s vmax. Higher indicated speeds can come from speedometer overread. Downhill grades and tailwinds also inflate readings. Use GPS for verification during safe, legal testing. Focus on condition over absolute top speed. [Elektroda, Kantylena, post #17030567]
Any buying-source tips or price context for V6 cars?
One member recommends avoiding multi-owner, domestically flipped cars. They suggest importing straight from Germany or Austria. In 2018, they cited 5–8k PLN for decent V6 examples abroad. Today’s prices differ; use that only as historical context. Inspect thoroughly regardless of asking price. [Elektroda, Strumien swiadomosci swia, post #17030445]
