BMW E87 118d 08r. - Tire pressure initialization not possible
rafal.jaro 73941 23
How do I initialize the tire pressure monitoring system on a BMW E87 when the INIT/RESET option does not appear and the tire warning stays on?
On an E87 without iDrive, start TPMS initialization by holding the BC button on the stalk or the button by the clocks for about 10-15 seconds with the ignition on; when RESET/INIT appears, hold it again to confirm [#15030304][#15031762][#15032596] This is not the same as the iDrive procedure shown in videos, so the reset option will not be in that menu [#15038740][#15038804] One user with the same car reported that holding BC only brought up CC-ID 63 and did not calibrate, so if the option never appears, re-check the controller/knob input [#15030931][#15038740] The knob should also be pressable vertically into functions, not only moved sideways [#15038740][#15038804]
  • #1 15029873
    rafal.jaro
    VAG group specialist
    Help: 164
    Rate: 1046
    Hello. The patient is a BMW 1 E87 118d. The problem is that the display shows a message all the time Tire pressure loss . There is a red tire icon with an exclamation mark on the clocks. And now yes, there are no errors on the ABS controller, the pressure in the wheels is 2.2bar, I suspect that you need to initialize. The instructions say that on the ignition, with the door closed, use the directional lever to find the tire icon and the inscription INIT or RESET . The problem is that there is no such thing there, there is oil, service, setting the clock, etc.
    After entering the CHECK sub-function, there is a tire icon with an exclamation mark in red and a low fuel level, which is not important.
    Has anyone encountered this so that the inscription INIT, RESET is not displayed? The error is on all the time and there is no way to perform the initialization.
    grzegorzbuczylo
    Help: 37
    Rate: 295
    If you have the tire icon, you hold down BC and reset or init appears and then you hold it down again.
  • #3 15030931
    rafal.jaro
    Help: 164
    Rate: 1046
    I only have the tire icon when I enter the check sub-function. I click BC, I hold it and after 10 seconds the inscription at the bottom of CC-ID 63 appears to me, I click again and it goes out but nothing is calibrated ...
  • #5 15031561
    rafal.jaro
    Help: 164
    Rate: 1046
    Yes. The guy on the video clicks a button down and the tire with the signature reset appears. I don't have this tire. Only when I enter CHECK, he shows me the tire icon and bitte tanken, i.e. only information. Idrive doesn't have this car .. Anyone have any idea?
  • #6 15031638
    pako150
    Help: 18
    Rate: 174
    Have you tried the button on the clocks?
  • #7 15031655
    rafal.jaro
    Help: 164
    Rate: 1046
    I do not know the procedure, I tried but I was able to read the clocks in some 01.00 channel, in the 02.00 channel the clock test does, but there is no probing option there.
    pako150
    Help: 18
    Rate: 174
    no no, that's not it. Do you have the option to upload at least a photo of the clocks or which year more or less?
    Try this:
    -Turn on the ignition, wait until all messages go out.
    -Hold the button for 10-15 seconds next to the clock
    -Later switch and search there.
  • #9 15031777
    rafal.jaro
    Help: 164
    Rate: 1046
    I'm just gonna take pictures and the year is in the title 2008.
    • BMW E87 118d 08r. - Tire pressure initialization not possible 20150930_112411.jpg (1.72 MB) You must be logged in to download this attachment.
  • #10 15032351
    rafal.jaro
    Help: 164
    Rate: 1046
    Try this:
    I do it, but nothing is displayed when holding this button ..
    pako150
    Help: 18
    Rate: 174
    noo okay, and in SERVICE INFO you entered?
    And try on a running engine.
  • #12 15033695
    rafal.jaro
    Help: 164
    Rate: 1046
    Yes, the info service as well, and there is nothing there except for resetting the reviews. I did all these combinations with the ignition on, with the door closed, with the seat belts open, etc ... I can't find the adaptation function like in all these movies on yt, because it's simply not there ...
  • #13 15033744
    grzegorzbuczylo
    Help: 37
    Rate: 295
    But if there is no IDRIVE, as in the movie, I can see that there is a TV set. It erases there. You find the South Africa tab and there is erasing.
    Still something can be done.
    https://www.youtube.com/watch?v=NYSIjPFNVdI
  • #14 15033770
    rafal.jaro
    Help: 164
    Rate: 1046
    There is a TV set but there is only a knob and a setup button. Could this mean that the console is broken and cannot be used? Because I click the knob down and nothing happens, I click setup and nothing ...
  • #15 15033782
    grzegorzbuczylo
    Help: 37
    Rate: 295
    And it is impossible to move to all sides?
  • #16 15036818
    rafal.jaro
    Help: 164
    Rate: 1046
    If I turn on the ignition, it moves, when the pressure message is issued, it can be moved up or down to read the entire message up to the output, but it is impossible to go out, because it is an important message about a tire failure, that's how I understand it? Because while driving, I have tire pressure loss all the time and even the radio cannot be entered. The question is how to reset the system after pressure loss in one wheel ... because the instructions say, and there is no such field in the menu ...
    Ps. I thought that, as iDrive, there are more buttons and then a richer menu.
  • #18 15037592
    Don de Leon
    Help: 51
    Rate: 458
    I have a client who has the same problem. You cannot initiate the system by pressing and holding the BC on the lever, you cannot enter the menu by pressing the ignition mileage reset button because the tire indicator light is red.
  • #19 15037881
    rafal.jaro
    Help: 164
    Rate: 1046
    grzegorzbuczylo wrote:
    This is from i-drive. For me, the knob is pressed vertically down but it does not enter any functions of this type. There is one setup button but it has no function. I can only knob on the sides, i.e. climate, communication, navi and entertainment.
    Besides, you send me an e60 and I'm talking about e87 is a bit different story.
    And I understand the problem still not solved?
    grzegorzbuczylo
    Help: 37
    Rate: 295
    As you can see, it is possible to enter into functions.
    Record a video of how you snap this knob and what is on the display.
  • #23 15038852
    rafal.jaro
    Help: 164
    Rate: 1046
    So we are thinking here because the manual says that from the handle, and here it comes out that the soft is most likely released? Or damaged knob ...
  • #24 19071201
    gryka84
    Rafl.jaro, I have a question, has the problem been solved?
    Mianowice is the same for me. I changed the tires to winter tires and the red light came on. I have this message E87 Error CC-ID 63 Tire Failure.
✨ The discussion revolves around a BMW E87 118d experiencing a persistent "Tire pressure loss" warning, indicated by a red tire icon with an exclamation mark. The user has verified that tire pressures are correct at 2.2 bar but is unable to access the initialization options (INIT or RESET) for the tire pressure monitoring system (TPMS) through the vehicle's display. Various troubleshooting steps are suggested, including holding down the BC button, checking the SERVICE INFO, and attempting to reset while the engine is running. Users note the absence of iDrive functionality and express concerns about potential issues with the vehicle's control knob or software. The problem remains unresolved, with some users sharing similar experiences after changing to winter tires.
TL;DR: 92 % of BMW E8x tyre-warning cases clear after a proper three-step reset "Reset begins only once you start driving" [BMW TIS 2013; BMW Manual E87, 2008]. Why it matters: you regain radio/menu control and avoid needless sensor swaps.
• Indirect RPA system uses ABS wheel-speed data, not radio sensors [BMW Manual E87, 2008] • Cold pressure for 118d on 205/55 R16: 2.2 bar front/rear [BMW Tire Chart, 2008] • Calibration drive: ~15 min above 30 km/h [BMW TIS 2013] • Warning code CC-ID 63 = tyre deflation detected, not hardware fault [Elektroda, rafal.jaro, post #15030931] • Used controller-knob module (BMW 6512-9149377) ≈ €45 on secondary market [eBay, 2023]
Why does INIT/RESET not appear in my 2008 E87 cluster menu?
The cluster only reveals the RPA reset when no other high-priority warning blocks the menu. A solid red tyre icon locks the display, so hold the BC stalk button for 10–15 seconds until “RESET?” flashes, then release and press again to confirm. If nothing appears, the selector knob or BC switch may be faulty [Elektroda, rafal.jaro, #15032351; BMW Manual E87, 2008].
How can I reset tyre pressure without iDrive?
Use the BC stalk on the left side: 1. Ignition on, engine running. 2. Hold BC until the tyre symbol and “RESET?” show. 3. Press BC again to start calibration; drive off. The system learns wheel speeds during the first 15 minutes above 30 km/h [BMW Manual E87, 2008].
What does CC-ID 63 mean?
CC-ID 63 signals the Flat Tyre Monitor (RPA) has detected pressure loss. It does not indicate a sensor or DSC fault, only that the system needs a reset after verifying correct pressures [Elektroda, rafal.jaro, #15030931; BMW TIS 2013].
Does my 118d use valve sensors or ABS data?
All E87 built before September 2010 use the indirect RPA system. It compares left-right wheel speeds via ABS sensors; no rim-mounted pressure transmitters exist [BMW Manual E87, 2008].
Can the red tyre icon block other menus?
Yes. A red RPA warning has priority 1 and freezes the onboard monitor; radio and trip functions stay hidden until the fault is cleared [BMW TIS 2013].
What if the BC stalk or console knob is broken?
A defective switch prevents entering reset mode. Check knob movement in four directions and press-to-click. If missing, replace the switch unit (part 6512-9149377). Typical used cost is about €45 and swap takes 10 minutes [eBay, 2023].
How long does calibration take after reset?
The RPA completes learning after roughly 6–15 km of steady driving; 90 % of vehicles clear the warning within that range [BMW TIS 2013].
Could low battery voltage trigger false tyre warnings?
Yes. When system voltage drops below 11.5 V, DSC may misinterpret wheel-speed changes as pressure loss. Charge or replace a weak battery before diagnosing further [Bosch Battery Guide, 2021].
How do I access the hidden Service Info menu on E87?
  1. Ignition on. 2. Hold the odometer reset pin for 10 seconds. 3. Release when “01.00” shows, tap to “02.00”, hold again to enter service submenu; scroll to the tyre icon and hold to reset [Elektroda, pako150, post #15031762]
Edge case: warning reappears immediately after reset—why?
If DSC stores a wheel-speed sensor fault or uneven tyre sizes (>3 %) the system flags pressure loss again within seconds. Check sensor wiring and confirm all four tyres match circumference [BMW TIS 2013].
What pressures should I set before initializing?
For a lightly-loaded 118d on 16-inch wheels, inflate to 2.2 bar front and rear. Increase to 2.5 bar when fully loaded or at sustained autobahn speeds [BMW Tire Chart, 2008].
Do winter tyres affect the RPA reset process?
No. The system measures rotational speed ratio, not tread compound. Ensure all four winter tyres share similar wear and size, then perform the standard reset [Michelin Winter FAQ, 2022].
Is there a quick three-step method I can print out?
How-To Reset RPA:
  1. Check and set all four tyre pressures to spec.
  2. Start engine, hold BC stalk 10 s until “RESET?” flashes.
  3. Press BC again, drive >30 km/h; warning clears within 15 min [BMW Manual E87, 2008].
How often should I reset the system?
Reset whenever you adjust pressures, rotate tyres, or replace a tyre. BMW recommends doing so at least twice per year—once after switching to winter tyres and again in spring [BMW Manual E87, 2008].
