Peugeot 3008 (2015) - TMPS Message Post-Tire Replacement: How to Reset & Clear Low Pressure Alert
michu14031 21333 2
  • #1 16413065
    michu14031
    Help: 12
    Rate: 38
    Hello, as in the topic of auto 3008 year 15. After replacing the tires, he crashes a low pressure message in 3 wheels,
    what to do ?? How to delete ?? Wheel pressure correct in all wheels
  • #2 16413099
    siwak15
    Rate: 10
    When replacing the tires, the sensors were not damaged ?? It fits check if it's visible
  • #3 16413374
    drdrug
    Help: 25
    Rate: 178
    As a colleague writes, I see two options, damaged sensors when replacing tires, or just need to calibrate tpms sensors with a special device. Hardly any workshop has such equipment so you can drive to find out for service. In 2008 there is an option to do this manually so read this http://enginepartsdiagram.com/reset-low-tyre-pressure-warning-light-peugeot-2008/
