Samsung UE32EH4003: No Picture, T-Con HV320WX2-261_X-PCB-X0.0 Voltages, MAX17126B DC-DC Converter
master250 4932 2
  • #1 15049290
    master250
    Help: 30
    Rate: 178
    In the above TV, the 13V voltage reaches the T-Con HV320WX2-261_X-PCB-X0.0
    There is 3V3 and 1V7 voltage present. Natomist does not have VGH, VOFF, VON, VRREF, GREF.
    The DC17DC converter is MAX17126B, which is also powered by IN2 and LX1 pins.
    I would like to add that the above arrangement is completely cold or does this system need an enable signal?
    Thanks in advance for your help.
  • #2 15049462
    mirex
    Help: 1950
    Rate: 1990
    Look. Compare with nature.
    • MAX17126B.pdf (2.38 MB) You must be logged in to download this attachment.
  • #3 15049671
    master250
    Help: 30
    Rate: 178
    On pin 8, GVOFF is 2V5, and on 9 ON / OFF is 4V2.
    Are these values correct and does this mean damage to MAX17126B?
