[Z-Wave] How to send on/off commands and set brightness for Fibaro Dimmer via Z-Stick?
TomekMus 1497 1
  • #1 15070777
    TomekMus
    Welcome,
    I want to connect a Fibaro Dimmer with a Z-Wave Z-Stick Gen5 Adapter.
    How to send a simple on/off command over COM and set the brightness.
    Is there any Z-Wave documentation that shows a frame/protocol of how such a data frame is handled?
    Kuniarz
    Moderator of Designing
    Help: 371
    Rate: 826
    The Fibaro communication framework is not publicly available as the system does not run on OpenZwave, only the commercial version. You can scrape an email to support, although I doubt they will make it available....
