50W LED Motion Sensor Lamp: How to Install with Switch Control?
PITTER 22 37224 4
  • #1 15087643
    PITTER 22
    Rate: 23
    I bought a 50w Led motion sensor lamp.
    I would like to install a lighting in front of the house, which would be controlled by a motion sensor and an ordinary switch.
    The principle of operation is to be as follows:
    - if the switch is on, the light is on and the motion detector has no effect on it.
    - if the switch is off, the light is turned on by the detector.
    How to do it?
    Please send me a diagram.
    Pitter
    jacekko63
    Help: 140
    Rate: 320
    You need to parallel the lamp relay contacts that activate the light source with the switch.
  • #3 15088417
    PITTER 22
    Rate: 23
    Thank you for the information, but does anyone have a ready diagram of how to connect it?
    Piter
    Ryszard49
    Help: 312
    Rate: 1011
    Link
    Greetings.
  • #5 15099419
    PITTER 22
    Rate: 23
    Hello, thank you for helping the lamp works
