Wiring 230V Motion Sensor with Manual Wall Switch for Continuous Lighting Control
Luuis 1527 1
  • #1 17490718
    Luuis
    I would like to plug in a motion sensor for 230V.
    The assumption is that the lighting would be switched on by the motion sensor but also by a wall switch (so that the light is on all the time).
    My question is whether it is possible to do this? If I give voltage from the switch, will it not burn out the detector?
    Motion detector (https://www.obi.pl/czujniki-ruchu/duewi-czujnik-ruchu-180-stopni-bialy/p/4389862)
