[Solved] Philips SWB50 Wireless Subwoofer: Upgrading & Optimizing Performance for TV Audio Support
chudy_b 30222 22
Why does my Philips SWB50 wireless subwoofer sound distorted with TV audio, and how can I make it work better or convert it to a wired sub?
The most likely cause is the Bluetooth/TV processing or the internal amplifier, not just the speaker itself, and the easiest improvement is to bypass Bluetooth and feed the board with a wired analog signal [#15107333][#18535779] The sub has no normal audio input by default; it only has power and Bluetooth, so to use it wired you need to solder to the pins marked GND, BT LCH and BT RCH on the board [#17941759][#17851066][#18406993] One reply notes that you can then connect it to an analog source such as TV RCA/jack output, SCART, or an optical/coax converter, or any other line-level source [#17851212][#18406283] Another report says that with newer TV software and after re-pairing or unplugging/re-enabling the sub, it worked much better, so firmware/software may also be part of the problem [#18754976] If you want real improvement, the best path is likely replacing the BT module or amplifier, or even driving a better speaker/driver directly, because this small cabinet/driver is not expected to produce great bass [#18535779][#18757830]
  • Disassembling SWB50 to diagnose poor sound quality
    #1 15105723
    chudy_b
    Help: 37
    Rate: 48
    Hi
    The sub mentioned in the topic was given to me as a freebie for my TV. For half a year it was lying unused, because the TV software is basically a collection of bugs and the TV did not feel like making a connection. After a recent upgrade the connection to the sub was able to be established and I decided to see if it was worth using it at all. I say straight away that I wasn't expecting a bump in the liver from this device. He's only there to assist the TV speakers in reproducing low tones when listening to a normal programme not too loudly. For movies and music I have an external amplifier with decent speakers.
    After pairing the sub with the TV the former started to make some sounds. Sounds that are best described by the word "farting". It sounds hopeless. The sub not only does not improve anything in the listening, it spoils it. It is simply impossible to listen to. Quiet farting, in addition I think out of phase gives the effect of tiring reverberation. As if a lost pad is smashing on the diaphragm of some speaker.
    There was nothing left to do but to see this invention from the inside.
    From the outside, a rather large speaker cover and a bassreflex opening plugged with a sponge.
    After removing the loudspeaker cover a slight surprise:
    And then a glance at the electronics:
    I don't know whether the fact that it sounds so bad is due to the small loudspeaker, the amplifier used or maybe transmission problems.
    For the time being I have only tested the speaker. I hooked it up to a regular stereo amplifier. It plays poorly. There is hardly any bass, but no farting either. I plan to power a regular speaker with this amplifier. Maybe I will learn something about its quality. Ultimately I would like to build a new sub if possible using the original cabinet and communication module.
    What do you guys think? Any ideas?
  • #2 15107333
    chudy_b
    Help: 37
    Rate: 48
    I did a couple of tests.
    I connected a normal speaker in place of the speaker, this did not change anything. I connected a so-called signal seeker with a small loudspeaker to the output of the BT module, basically no sound comes out of it. There is something minimally buzzing to the rhythm of the TV sound, but you really have to listen in. Probably the small speaker does not transmit low frequencies.
    This all indicates that either something is wrong with the BT module, or the TV itself cuts (probably software) the frequencies sent to the sub.
    In this case, there is nothing to move the sub itself. You have to wait for the next TV software update.
    I would be sure, if it would be possible to pair this sub with another device. Unfortunately, the phones detect it but won't connect. One ignores it completely, the other asks for a PIN, which I don't know. I could still feed the amplifier input with a normal signal from a CD for example, and that's probably what I'll do, but it's a bit more fun.
  • #3 15158328
    blackrafal
    Rate: 17
    Is it worth buying this model of sub? I wanted to buy it for the Philips 55PUS7600
    Have you been able to test it under another TV? I have seen one at auctions for PLN250-400 each.
  • #4 15158338
    chudy_b
    Help: 37
    Rate: 48
    blackrafal wrote:
    Would you buy this model of sub?
    In my opinion, definitely not. Its design does not promise any good results. Admittedly, it plays tragically in my house, most likely for software reasons, but I still wouldn't give a penny for it.
  • #5 15158748
    blackrafal
    Rate: 17
    Have you tried setting multichannel sound or other settings in the options?
    For me, the PS3 made strange sounds with bad sound settings in the options.
  • #6 16272224
    czlowiek33
    Rate: 11
    I'll join the topic with a question, how do I convert this to a wired sub, where do I plug in the cinch plug
    Philips SWB50 Wireless Subwoofer: Upgrading & Optimizing Performance for TV Audio Support .
  • #7 16273396
    blackrafal
    Rate: 17
    How do I make a switch so that I can connect via cable and possibly some kind of driver so that I can switch to bluetooth in case of emergency?
    Through bluetooth it has a slight delay, they should fix this in software in the 55pus7600.
    If we already have a connection, to which input on the TV and which option should I choose in the software so that the speaker works as a subwoofer?
  • #8 17851066
    Tomek 35
    Help: 7
    Rate: 78
    We solder the pins in such a way as to connect the amplifier. Next to the connector there is a description where to connect the audio input.
  • #9 17851092
    blackrafal
    Rate: 17
    Ok, but which socket on the TV do I plug it into and with which cable? Do I have to select an option on the TV for it to work?
  • #10 17851212
    Tomek 35
    Help: 7
    Rate: 78
    You can then connect to any analogue audio source, i.e.:
    1. audio output via cinch or jack from TV if available
    2. audio output via euro from TV if available
    3. from digital audio output IRDA or COAXIAL via converter if available
    4. other devices with audio output, e.g. telephone with headphone output, mp3, DVD, radio etc.
  • #11 17940822
    blackrafal
    Rate: 17
    When connected via coaxial, will the TV detect this device as a subwoofer?
    Do you have a picture of the finished project?
  • #12 17941759
    Tomek 35
    Help: 7
    Rate: 78
    This device does not have a coaxial input. There is no physical input by default. It only has a power cord and fussy bluetooth communication.
  • #13 18405678
    Dudeman
    Good morning
    @Tomek 35, your post on this subwoofer was extremely helpful. I got to the stage where I soldered the pins mute/gnd is standby/gnd, now I'm not sure where or how to connect the Aux cable.
  • #14 18406283
    Tremolo
    Help: 1016
    Rate: 497
    In the audio output from the TV, unfortunately new TVs do not have and you need an adapter, from optical the easiest way to do it. Or, if not, from a EURO SCART cable, for this an active filter.
  • #15 18406300
    Dudeman
    Yes, but to the subwoofer where should I connect now. Which pins are from receiving an analogue signal?
  • #16 18406993
    Tomek 35
    Help: 7
    Rate: 78
    On the left side of the slot there is a description on the laminate.
    GND
    BT LCH
    BT RCH
  • #17 18407341
    Dudeman
    Great, thanks for the reply. On my system the lettering was painted over with some kind of marker, but indeed described in the photo above.
  • #18 18535677
    maniekw18
    How about connecting another Bluetooth module that we pair with the TV, and analogue from the module to these pins?
  • #19 18535779
    Karaczan
    Help: 869
    Rate: 1127
    The most sensible thing to do is to connect the Line-In to these BT L/RCH and see how it plays with a normal source.
    Then possibly connect a better amplifier directly to the speaker.
    The quality is rather indicative of problems with the BT module or/and the amplifier itself.
    Fact that it is unlikely to expect miracles from such a small diaphragm, not less there are designs that can surprise. I myself have a Pioneer SW-90 subwoofer, yes, a slightly different class and dimensions of equipment, but it has only a 14 cm driver. Even computer 2.1 systems often have such micro subs and still don't fart.
    "Farting" can also result from poor cable routing inside. I once had this happen in one active sub, where the cables resonated against the plastic cover of the amplifier.
  • #20 18754976
    blackrafal
    Rate: 17
    With the latest 2017 software after disabling this subwoofer in the options and re-pairing (or unplugging the subwoofer from the socket) it works quite well.
    I would bet on a few options for improvement:
    1. Replacing the components with better ones
    2. Changing the bluetooth transmitter/receiver to some more powerful or newer version.
    3. Connecting this subwoofer to some connector - although here the option is average, because if the TV does not detect it as a subwoofer or audio device, it misses the point.
    4. Replacing the module from bluetooth to Wi-Fi, which would reduce the latency, but you would also have to dig into the software of the TV :)
    I fixed the antenna inside a bit, but it did not do anything, the problem is in the communication.
    I am curious how it works with the new Philips TVs, whether it also stutters and rumbles so much, and what kind of latency it has then.
  • #21 18757830
    Tremolo
    Help: 1016
    Rate: 497
    Since the bass is non-directional, I would put it on the cable. The phase and delay of the bass as well as the position of the BR is crucial. As the delay from the module comes in, it misses the point. You can just buy a 25 cm car subwoofer enclosure, some used STX or a passive car subwoofer on large speakers. To that an amplifier with Alixspress 2x something there, depends how big your room is.
  • #22 18759115
    blackrafal
    Rate: 17
    It's mainly a question of whether the TV detects it programmatically, if it doesn't, then even designing an entire subwoofer is pointless.
  • #23 18759898
    Tremolo
    Help: 1016
    Rate: 497
    If it has an optical output, as most new TVs only have that apart from HDMI, you'll do anything with a converter. Through 2x500 kOhm you can output the sound from the stereo outputs of the amplifier you use for normal stereo. Although if you have at least 16 cm in the speakers, you will get more bass by actively boosting the 35-50 Hz region with loudness.
The discussion revolves around the Philips SWB50 Wireless Subwoofer, which a user received for free but initially struggled to connect due to software issues with their TV. After a successful connection, the user reported poor audio quality, describing the sound as "farting" and indicating that the subwoofer did not enhance the listening experience. Other participants suggested potential issues with the Bluetooth module or TV software, and some recommended testing the subwoofer with different devices or settings. There were inquiries about converting the subwoofer to a wired connection and suggestions for improving performance, including replacing components and using different audio outputs. The conversation highlighted the challenges of integrating the subwoofer with modern TVs and the importance of proper setup and configuration.
