[Solved] Philips 55PUS6201 TV - Adding Bluetooth Functionality via USB Port? (3 months old)
Alek77 9966 4
  • #1 16682131
    Alek77
    Rate: 25
    I purchased a Philips TV 55PUS6201 without bluetooth about 3 months ago. :oops: Unfortunately, I did not pay attention to this. Now it turns out that such a function could be useful.
    Question - can you somehow "add" to bluetooth tv ??? E.g. in the USB port ??? :cunning:
    DriverMSG
    Help: 3984
    Rate: 4878
    The manual does not describe such a possibility, but to my (other Philips model) I connected a bluetooth keyboard and it worked.
    If you plan to use BT to send audio from TV, you probably won't.
    Looking from a different angle - my TV has Skype and I planned to buy a webcam, it turns out that the TV works only with a few selected models, and their price started from PLN 250 - I gave up.
    If it is similar with BT, then you would have to look for Philips devices dedicated to TV, because this one has a limited number of built-in drivers.
    What is your goal for Bluetooth?
  • #3 16682254
    Alek77
    Rate: 25
    Thank you for your answer.
    As for bluetooth, it actually plans to connect the sound - specifically the JBL Xtreme speaker.
    I just tried a moment ago by connecting a Bluetooth transmitter to the USB, but the tv did not react at all :cry:
    Then I connected the wireless keyboard via USB and here it is OK. The keyboard works. :spoko:
    Apparently it is as you wrote - only specific bluetooth transmitters should work.
    But if anyone has other ideas - I'm waiting for info.
  • #4 16749545
    Alek77
    Rate: 25
    Welcome back.
    Unfortunately, I connected several different bluetooth transmitters and none work. TV can't see him at all. Only this wireless keyboard, which of course I disconnect when connecting the transmitter.
    Any other suggestions ???
  • #5 17183090
    Alek77
    Rate: 25
    Unfortunately, the problem has not been solved.
    I think you have to buy Bluethoot TV next time ...
