Unscrewing Damaged Screw in Samsung Laptop: Removing Broken Cross to O Shape Fastener
45210 11
How can I unscrew a laptop screw whose cross head is stripped into a round hole?
Use a flat-blade screwdriver that fits the damaged head as tightly as possible, tap it in lightly if needed, and try to turn the screw out; if that still fails, drill the head with a 2 mm bit or use a damaged-screw removal kit [#15109233] [#15109248] [#15109353] One reply also suggests filing the screw head’s sides and gripping it with pliers, but the thread mostly recommends making a better flat-slot drive or drilling it out [#15109168] [#15109248]
  • #1 15109159
  • #2 15109168
  • #3 15109191
  • #4 15109202
    Błażej
    Help: 1923
    Rate: 3625
    Cover everything around and drill it gently using this screwdriver slot.
  • #5 15109205
  • #6 15109221
    tzok
    Help: 3175
    Rate: 6540
    She's not that crazy, little one flat you should unscrew it with a screwdriver.
  • #7 15109226
  • #8 15109233
    djlukas
    Help: 94
    Rate: 266
    Use a flat, hard screwdriver to tap something lightly into the screw and it must release.
  • #9 15109248
    zjo
    Help: 144
    Rate: 276
    In this state, the only way is to smash it more ... As above, choose the size of a flat screwdriver so that it fits into the head of the screw as tightly as possible, tighten it carefully and try to unscrew it. It will go or you carve it to the rest, then it remains to be drilled anyway.
    PS A colleague above warned me :)
  • #10 15109337
  • #11 15109353
    zjo
    Help: 144
    Rate: 276
    You can and yes ... But in my opinion the fastest and most sensible solution is a 2mm drill. :) Alternatively, there are special kits for removing damaged screws, but is the skin worth a layette ...
  • #12 15110003
A user encountered a broken screw on their Samsung laptop, which had transformed from a cross to an O shape, making it difficult to remove. Various suggestions were provided, including filing the sides of the screw head to grip it with pliers, using a flat screwdriver to tap into the screw, and drilling it out. Some recommended sharpening a Phillips screwdriver to create a cutting edge for better grip. Ultimately, the user successfully removed the screw using an old, half-sliced flat screwdriver.
