How to remove a stripped Phillips screw in a plastic radio case?
M-Zalew 48833 10
How can I remove a stripped Phillips screw from a plastic radio case when pliers cannot grip it?
Drill the screw head off with a bit slightly smaller than the head, remove the cover, and then try to unscrew the remaining screw shank with pliers if there is enough of it left [#10487838] [#10488921] Another option is to use a left-hand drill bit, which may back the screw out while you are drilling it [#10487840] If you want to avoid drilling the whole head off, you can cut a slot in the damaged head with a small chisel or screwdriver and try a flat screwdriver instead [#10491836] One reply also suggested gluing the screwdriver tip to the screw head with cyanoacrylate after degreasing, then breaking it free once the glue sets [#10491922]
  • #1 10487816
    M-Zalew
    I have such a radio to open. I unscrewed all the screws, but unfortunately the last one does not want to unscrew anymore, because the cross shape on the upper part of the screw has crumbled and deformed - now it is such a round hole. : /
    Question: What can I do to unscrew this screw? It is impossible to grab it with anything, e.g. pliers, because there is plastic around it. Maybe I was thinking about a screwdriver with a strong magnet, but if there is such a thing, I do not know?
    I am asking for advice.
  • #2 10487827
    darek4455
    Help: 33
    Rate: 66
    First, pop the WD-40 and try to unscrew it if you fail, you can saw it off and then unscrew it with pliers :)
  • #3 10487837
    M-Zalew
    Why WD-40? :|
    There is no way to saw it off, because there is plastic around ...
  • #4 10487838
    michcior
    Level 30  
    Help: 159
    Rate: 462
    Such screws are removed by drilling a hole in them. After that, you can use a special tool for loosening, which looks like a screw but has a thread on the other side. Well, only this screw of yours is probably so small that there is no need to drill in it. Just drill open the head until it comes off. Then you can somehow catch what is left if what is holding the screw has a thickness.
  • #5 10487840
    arewin
    Help: 33
    Rate: 198
    You have two options, the first is drilling with an appropriate drill (the diameter of the screw head is equal to the size of the drill), the second is uncoupling with a left-hand drill, when you try to drill it, it is possible to unscrew it by itself - Good luck ...)
  • #6 10488031
    ja-kenaj
    Help: 59
    Rate: 120
    After dropping a few drops of WD, wait about 30 minutes. In the meantime, if you have a grinder, sharpen the screwdriver in the shape of a triangular pyramid with sharp edges so that the top of the pyramid does not rest on the screw. Only the side edges of the screwdriver made in this way must touch the screw.
    Good luck.
  • #7 10488921
  • #8 10489008
  • #9 10491836
    Sasni
    Help: 23
    Rate: 57
    Sometimes I do it so that I "stick" a small chisel into such a screw or directly a screwdriver to create a groove instead of one hole. Thanks to this, it is sometimes possible to unscrew something like a flat screwdriver.
  • #10 10491922
    dual
    Help: 34
    Rate: 72
    It would be best to put a drop of cyanoacrylate glue, ie "Droplet" etc. on the end of the screwdriver, put it on the screw head, stiffen it until it hardens and wait until it sets completely. Before that, you need to degrease the gluing site. If you used WD40, for example, with a varnish solvent, because the bond will be too weak. A well-glued screwdriver tip should easily move and remove the screw. Then you just need to break it off and the screwdriver will still work after cleaning. The glue should not be applied too much, so that it does not drip beyond the metal and does not additionally stick the screw in the housing.
  • #11 10494700
The discussion revolves around a user facing difficulty unscrewing a deformed screw on a radio, where the cross shape has crumbled into a round hole. Various solutions are proposed, including using WD-40 to loosen the screw, although some participants express skepticism about its effectiveness due to potential damage to the plastic housing. Drilling the screw head is suggested as a viable method, with recommendations to use a drill bit smaller than the screw head diameter to avoid excessive drilling. Other techniques include creating a groove with a chisel or screwdriver, and using cyanoacrylate glue to bond a screwdriver tip to the screw for removal. Caution is advised regarding the use of WD-40 near plastic components.
