Is a 3dB or 10dB Increase in Loudspeaker Volume Perceived as Twice as Loud?
wojtek999 31666 28
What dB increase in a loudspeaker’s output is perceived as twice as loud, and how is that different from doubling power or sound pressure?
A 10 dB increase is generally perceived as about twice as loud, while 3 dB is only the smallest clearly noticeable change and corresponds to doubling power or intensity, not loudness [#1567434][#1579071][#1590030] Sound pressure scales differently: doubling pressure is about 6 dB, because intensity is proportional to the square of pressure [#1567434][#1567625] For loudspeakers, adding a second identical speaker with the same signal can give about +6 dB in pressure in ideal conditions, but the exact result depends on the setup and room [#1567276][#1572939] Loudness is subjective, and one reply describes an experiment where average listeners judged a loudness doubling at roughly +10 dB, with variation between people and signal types [#1611375] So the practical rule from the thread is: +3 dB = noticeable technical increase, +6 dB = doubled pressure, and about +10 dB = perceived as twice as loud [#1579071][#1611375]
  • #1 1567155
    wojtek999
    Rate: 13
    I got lost in all this ... so far I have read everywhere that an increase by 3dB is a double increase in volume. However, the article http://audiomania.info/articles.php?id=34 shows that 3dB is a clearly audible increase in the volume for the human ear, while 10dB is twice as loud. Where is the truth? If I misunderstood something ... this article probably concerns amplifiers, I mean mainly loudspeakers.
  • #2 1567200
    Taenia_Saginata
    Help: 38
    Rate: 111
    As far as I know, 10 dB is an audible doubling of the volume. But as our hearing is logarithmic to hear something twice as loud. This thing has to play 10 times louder, which means you have to deliver 10 times more power.
  • #3 1567276
    irek2
    Level 40  
    Help: 435
    Rate: 387
    what a difference whose ear hears.
    The more important thing is that when we connect the second speaker, we have twice as much pressure, i.e. an increase of 6dB.
  • #4 1567308
    Kwaczor
    Help: 186
    Rate: 42
    It is difficult to define something like "hears 2 times louder".
    From the technical side:
    Providing 2 times more power gives a profit of 3dB
    Adding a second speaker with the same signal gives a gain of 6dB
    The human notices a difference of 1-1.5dB
    MEDIVOICE Michał Kaczmarek
    Ogrodowa 14, Leszno, 64-100 | Tel.: 609XXXXXX (Show) | Company Website: www.mvoice.pl
  • #5 1567393
    Taenia_Saginata
    Help: 38
    Rate: 111
    2 times more pressure is not a coincidence 3 dB?
  • #6 1567434
    Kwaczor
    Help: 186
    Rate: 42
    Lp = 20 log P / P0
    Li = 10 log I / I0
    So 2 times the intensity is 3dB, the pressure is 6dB
  • #7 1567603
    wojtek999
    Rate: 13
    Intensity vs pressure ... what's the difference ?? I read everywhere, unless, instead of 1 speaker, we give two the same, the effectiveness increases by 3dB, so it sounds 2x louder.
    Added after 4 [minutes]:
    aaa ... I think something is already up :) So in plain, unprofessional language: intensity is the "amount of sound" measured with an instrument, and pressure is the "amount of sound" heard by a human ....? And because the human ear has a logarithmic scale, when the measured value increases 10 times, the hearing by the human ear will be 2 times louder.
  • #8 1567625
    Kwaczor
    Help: 186
    Rate: 42
    Intensity is a measure of energy, while sound pressure is a measure of pressure deviations from "normal"
    And the intensity is directly proportional to the square of the pressure, hence the differences. An increase in intensity twice causes an increase in pressure (averaged) by the root of 2.
  • #9 1568028
    toadi
    Level 36  
    Help: 315
    Rate: 63
    Hello....
    I will write as I wrote in one of my first posts here .... there was a fight between the two men I don't remember who (but not eqtkontra silversound ........... I miss them) ..... . it is impossible to say that it is 6 or 10dB, it is an individual subjective feeling, therefore large discrepancies depend only on the person assessing it ............. :D the matter is useless as a discussion about the superiority of Christmas over Easter, or it cannot be done, and here math does not work.
    One mosaic to say what has already been written by the predecessors of 3dB requires 2x more power louder
  • #10 1568487
    Hefajstos
    Help: 190
    Rate: 131
    Yes, the quarrel was cult ...
    With these 10dB, it is apparently true and also applies to other stimuli - touch, heat, etc. But how can you say that it is 2 times louder, or that my tooth hurts 3 times more. It's just like cosmetics, after which you are 30% healthier and 70% more radiant:] For me twice as loud it is when you place another child of the same size next to a screaming child and make them scream in unison. Of course, I ignore the mutual radiation resistance between children :D
    Hephi
  • #11 1569891
    wojtek999
    Rate: 13
    Thanks to you, many things have already understood :D
  • #12 1571164
    Passat_EQ
    Help: 39
    Rate: 16
    So do you think that if I add a second loudspeaker in my car and I still supply 1kW, the pressure will jump from 142.8 to 148.8? ;)
  • #13 1572939
    irek2
    Level 40  
    Help: 435
    Rate: 387
    Well, not if you add a second loudspeaker with the second 1KW boost, theoretically you will have 6dB more. But as you know, only theoretically. Measurement in the open air will give exactly 6dB more, but in a car it depends on which glass will break :)
    Well, but two speakers and two amplifiers are a different category and a different competition and twice as expensive and the cup is probably the same :)
  • #14 1572989
    Passat_EQ
    Help: 39
    Rate: 16
    no, same category yet. :)
    But let's not get off topic. :)
    The CRX windows withstand 156dB calmly :)
  • #15 1573414
    kosmaty
    Help: 13
    Once, my colleagues and I conducted a test of the amplifier in the chamber and during this test the "volume" increased 2x, ie 3dB, when we increased it from 50W to 200W. But it all depends a lot on the speakers used. Each company's loudspeaker works differently and has different parameters.
  • #16 1578444
    robxt
    kosmaty wrote:
    during this test, the "volume" increased 2x, ie 3dB, when we increased it from 50W to 200W.
    But what do you mean by "loudness". How did you measure it? Measuring the acoustic pressure? Or something else. If so, the result of 3dB is weak in my opinion, and it is strange that it came out like this. After all, there should be + 12dB of pressure for + 6dB of power. And how much "volume" here?
  • #17 1579071
    Hefajstos
    Help: 190
    Rate: 131
    Why + 12dB? After all, there are decibels, so that there is always the same number of them. 6dB of voltage and power is the same, but differently looks on the "normal" scale - 1.41 and 2, but it is precisely because 1.41 voltage increase gives a 2-fold increase in power. And pressure is the acoustic "equivalent" of voltage.
    3dB came out instead of 6, because the loudspeaker has power compression - what specific loudspeaker it was. For example, PD1850 (speaker for PLN 2,000, 18 with a 5 !!! inch coil) has according to manufacturer's 2dB compression at full power, so let alone "cheap" loudspeakers for several hundred zlotys, not to mention those for several dozen ...
    Hephi
  • #18 1579881
    toadi
    Level 36  
    Help: 315
    Rate: 63
    Well, companies like Mackie or RCF here "cheat" customers by giving max spl, e.g. 130dB for the 400W loudspeaker, because they give without taking into account the power compression and in addition in the peak (4x more power) it looks like PMPO power, even dexon gives max spl taking into account power compression (blah, I had the opportunity to find out that there is practically no difference in volume with the LDM 315 pro sound a little better but they were buying on decibels as evidenced by these companies)
  • #19 1581336
    kosmaty
    Help: 13
    The loudspeaker used is: BEYMA 12``M-300
    I don't know anything about him.
    Is it good, maybe different, is it reliable?
  • #20 1581440
    toadi
    Level 36  
    Help: 315
    Rate: 63
    The loudspeaker is good and reliable, I know I had loudspeakers on them and you have researched what often because it is a mid-range speaker (or rather a mid-bass), not a woofer
  • #21 1582139
    tomaszo
    Help: 139
    Rate: 100
    Everything is beautiful, but already 4 topics within these "dB" have scrolled - please, let's stick to the topic ...
  • #23 1585394
    wojtek999
    Rate: 13
    I started this topic because I wanted to know how to look at speaker efficiency. I wanted to know if the efficiency is higher by 3dB = 2x higher "volume". However, your posts show that this "loudness" is a subjective feeling and it is impossible to clearly determine how much it will be. So I wonder why in such magazines as e.g. "Audio" in the latest issue in one of the tests I read that some loudspeakers have a 3dB greater efficiency than the other, so it sounds 2x louder. Besides, I also remember from car tests, i.e. the noise they make while driving, the authors of these tests emphasized a little that the noise greater by 2-3dB is twice as much. This strange world .....
  • #24 1589807
    robxt
    And it's not like that 2x louder it was supposed to be 10 times more power ??
    Quote
    "3 dB is the smallest increase in volume clearly recorded by the human ear"
    "10 dB is a two-fold increase in human perceived loudness, for which we must increase the power 10 times, i.e. increase the voltage 3.2 times."
    People, let's finally come to a conclusion and let's finish the topic so that people find out something, and not so much that I don't know anything myself. It seems to me that I can agree with these quotes from the website. Especially with the former? And you? The latter quote is harder to measure (subjective feelings), but there must be something to it as well. Probably someone researched it and statistically that's how it turned out.
    What do you say?
  • #25 1590030
    J. S.
    Help: 94
    Rate: 18
    Make yourself a tee. In a sudden leap, increase the volume of your music by 1,2,3,6 dB and answer yourself when you hear the difference. I am at the computer, with the winamp, using the preamplifier in the EQ (I set, for example, -5.5 dB and then turn on the eqaualizer button), I hear the difference from, say, 1.3 dB on the computer speakers, although I can make a suggestion (because I know that it is to come change - I press the button itself). 3 dB (2.9 in the Winamp) is a clear change, 6 dB (5.5) I would call a double volume difference, 10 (9.7) is even more.
    Subjective feelings, you say. Let's see who dims better or who has better hearing ...
    Apparatus, measurements, power, voltage and pressure ratios - yes, even fractions of dB come out nicely. In the topic to which I linked in my previous post, everything is exactly written in the table.
    Subjective feelings can be very different, no one will tell anyone that for him, for example, 20 dB is not 2x louder. Musicians have a more sensitive hearing, acoustics know this and that about dB, and most of the nation says "make a half tone quieter" anyway.
    Greetings.
  • #26 1590121
    tomaszo
    Help: 139
    Rate: 100
    Musicians have a sensitive "musical" hearing (i.e. they distinguish changes in frequency, taste harmonics, often distinguish a few times better changes in intensity - this is related to HEARING MEMORY) - they often have physically damaged hearing - even as a result of frequent staying in noise ...
    You will stone me, but I hear the differences in the intensity of the order of 0.5 - 0.7 dB - someone else determines the level ... In 90 percent of cases I noticed the change well in any case - in the case of a 100Hz, 1kHz and 4kHz sine wave. The lower and higher than these values it is more difficult - due to the sensitivity of hearing ... When it comes to music - it is more difficult, but below 1 dB we went down. Everything in the range below 105 dB maximum, then it becomes more difficult ...
    The question of still hardware - you can not so-called computer loudspeakers - that is, some micro "series" (if the band 400Hz - 8kHz is "wide") define your full potential ...
    In fact, all considerations about dB can help only in approximating the maximum intensity - and also approximate, because it depends on the compression of the converters, room, etc. ... the music itself - and learn to distinguish the level of nat. sound - in one word, noise ... - depending on the frequency ... Then you can define for yourself - well, these 3 dB are twice as louder for me, for example, but below the intensity of the order of 120 dB, where I feel right now. .. There is no need to worry so much about it.
  • #27 1590201
    Pyroaniah
    Help: 118
    Rate: 30
    Above 120 dB I can only distinguish the difference of 135-140dB for 16khz. On the basis of "it hurts a lot" - "it hurts weakly because I can't hear anything anymore" :) . The matter of sensitizing hearing ... Each of us has a hearing as individual as our musical taste and that's it, there's no need to mess around. So it is best to use it when creating your own "dream" loudspeakers, because our hearing also includes our preferences.
  • #28 1611375
    Zasil
    maybe I will describe the experiment we conducted at the university:
    There were about 40 people sitting in the room. A reference signal (white noise) was emitted from the loudspeakers, with a certain level of sound pressure. We defined this reference signal at 100 points. Then a signal with a changed pressure level was emitted (within +/- 20dB). The audience's task was to assign a number proportional to the impression of the sound compared to the reference signal. The ratings of the listeners varied, some rated + 20dB at 100, others at 300, and for -20dB from 5 to 30 ... However, after averaging the results and plotting the dependence of the rating on the pressure level, the line appeared confusingly resembling an exponential curve. After the logarithm, it was possible to determine the straight line factor, i.e. a factor that determines how much the pressure level must increase for the average listener to rate the loudness as twice as high. To everyone's surprise, it turned out that the volume doubles when the pressure level is increased by about 10dB. This is an average result, because as I wrote above, the opinions of the listeners were very divergent ... in general, 10 dB is only an approximate value, because the loudness of the sound also depends on factors such as, for example, bandwidth (the result would probably be different for the signal sinusoidal and for noise).
  • #29 6877697
    Piotrekk01
    I wanted to know what is the difference between the sound pressure level and the sound pressure level? Both are given in decibels. The sound pressure itself is given in Pascals.
    For example, car speakers produce a high level of sound pressure but a lower level of intensity. How is it possible that they generate a lot of pressure but at a low volume? It should be the same because pressure is pressure.
    I found a "graph" of pressure and sound pressure levels on the goggles. At 20uPa it is 0dB. Doubling the pressure gives + 3dB.
    So at 40uPa it should be 3dB, at 200uPa - 10dB.
    And it is different because at 200uPa it is 20dB. This is true when adding 6dB. And why is 6dB added and not 3dB?
✨ The discussion revolves around the relationship between decibels (dB) and perceived loudness in acoustics. Participants clarify that a 3dB increase corresponds to a doubling of power, while a 10dB increase is perceived as twice as loud by the human ear. The conversation highlights the logarithmic nature of human hearing, where a 1-1.5dB change is the minimum noticeable difference. The distinction between sound intensity and sound pressure is also emphasized, with intensity being a measure of energy and pressure being a measure of sound heard. The impact of adding speakers on sound pressure levels is discussed, noting that connecting a second speaker can yield a 6dB increase in sound pressure. The subjective nature of loudness perception is acknowledged, with individual differences in hearing sensitivity affecting how loudness is experienced. The conversation concludes with references to specific loudspeaker models and their performance characteristics.
TL;DR: Doubling amplifier power gives +3 dB, yet most listeners call a +10 dB rise “twice as loud” [Elektroda, Taenia_Saginata, post #1567200] “Human loudness grows logarithmically” [Elektroda, Zasil, post #1611375] Use +3 dB for hardware sizing, +10 dB for human perception. Why it matters: This FAQ clarifies decibel myths so DIY builders and car-audio tuners avoid costly mis-specifications.
• +3 dB = 2× electrical power into the speaker [Elektroda, Kwaczor, post #1567308] • +6 dB = 2× identical speakers fed the same signal [Elektroda, irek2, post #1567276] • +10 dB ≈ perceived doubling of loudness for the average listener [Elektroda, Zasil, #1611375; ISO 532-1] • Most people detect ≥1 dB change; musicians can hear ≈0.5 dB [Elektroda, tomaszo, post #1590121] • Power compression can steal 2 dB at full power even in premium drivers [Elektroda, Hefajstos, post #1579071]
What does the decibel mean for power versus loudness?
A decibel is a ratio. For electrical or acoustic power you use 10 log(P2/P1). For sound pressure you use 20 log(p2/p1) because power is proportional to pressure squared. Thus 2× power → +3 dB, while 2× pressure → +6 dB [Elektroda, Kwaczor, post #1567434]
Is a +3 dB boost really twice as loud to human ears?
+3 dB is clearly audible, but listeners call it only “a bit louder,” not double. Controlled tests show people rate loudness as doubled near +10 dB, not +3 dB [Elektroda, Zasil, post #1611375]
Why do many engineers say +10 dB feels like double loudness?
Human loudness perception follows a power law. Listener polls averaged across music and noise give a doubling coefficient of ≈10 dB SPL [Elektroda, Zasil, #1611375; ISO 532-1]. Earlies Fletcher-Munson studies report similar results. One acoustician notes, “Ten decibels is the psychological halfway mark” [ISO 532-1].
How much extra amplifier power gives me a +6 dB increase?
+6 dB needs 4× the power, because each doubling adds +3 dB (2 × 2 = 4) [Elektroda, Kwaczor, post #1567308] For a 50 W rig, expect 200 W to sound “noticeably louder,” not double to the ear.
What’s the difference between sound intensity and sound pressure?
Intensity is acoustic power per area (W/m²). Sound pressure is the instantaneous pressure deviation (Pa). Intensity ∝ pressure², so doubling intensity raises pressure by √2 and yields +3 dB vs +6 dB respectively [Elektroda, Kwaczor, post #1567625]
How small a decibel change can humans actually hear?
Average listeners notice ≈1 dB; trained ears can pick 0.5 dB in mid-band tones [Elektroda, Kwaczor, #1567308; Elektroda, tomaszo, #1590121]. Below 0.3 dB, even golden ears struggle.
How does a car cabin alter theoretical dB gains?
Cabin gain below 100 Hz can add 6–12 dB, but cancellations above 200 Hz can erase predicted gains. A user saw only +3 dB instead of +6 dB after adding a driver because standing waves limited pressure build-up [Elektroda, Passat_EQ, post #1571164]
What is power compression and why does my speaker get quieter at high power?
Voice-coil heating raises resistance, cutting motor force. Tests show high-end 18-inch drivers lose 2 dB at rated power [Elektroda, Hefajstos, post #1579071] That shrinkage means a theoretical +6 dB upgrade may net only +4 dB in practice.
Quick 3-step method to estimate SPL change when upgrading gear?
  1. Find current SPL (e.g., 90 dB at 1 m). 2. Add +3 dB for each power doubling or +6 dB for each identical driver. 3. Subtract 1–2 dB to account for power compression and room losses. This rule-of-thumb keeps surprises low [Elektroda, Kwaczor, post #1567308]
My meter shows only +3 dB but theory says +6 dB—what went wrong?
Possible causes: drivers out of phase, placement causing destructive interference, power compression, or SPL meter damping fast peaks. Phase flip alone costs 6 dB by cancelling pressure [Elektroda, robxt, post #1578444]
Can I trust manufacturer “Max SPL” specifications?
Treat them as marketing. Some brands quote peak (×4 power) and ignore power compression, inflating numbers by 3–4 dB [Elektroda, toadi, post #1579881] Look for AES-standard continuous SPL or test with an ANSI-certified meter.
