Comparing dB and dBA: Understanding Differences in Sound Intensity Measurements for Fans
J_ros 45650 10
How are fan noise measurements in dB compared to dBA, and why can two fans with the same dBA rating sound very different?
dBA is not the same as raw dB; it is an A-weighted sound level that filters the measurement to reflect the ear’s sensitivity, especially the 1–4 kHz range [#3767192] Fan ratings with the same dBA value may still sound different because the measurements may have been taken under different, unknown conditions, so the numbers are not directly comparable [#3767192] In practice, a 1 dB difference is hard to hear, so if one fan sounds clearly louder than another, the real difference is probably larger than the published labels suggest [#3767192] So the safest way to judge fan noise is a reliable review made under consistent measurement conditions, not the spec sheet value alone [#3767192]
  • #1 3752232
    J_ros
    Help: 35
    Rate: 30
    Well, I'm interested in how dB is compared to dBA.
    The information I was able to find showed that dBA represents the amount of dB that corresponds to the listener's experience. However, when I bought a fan that was supposed to work at 21dBA, I was unpleasantly surprised by the huge difference between another, almost inaudible 21dB fan.
    How are dB actually compared to dBA?
  • #2 3752928
    andrew751
    Help: 7
    Rate: 31
    Hey, a decibel is a decibel, you got the wrong look because it should be: dB (A) that is on the acoustic scale, but it doesn't always add up. Greetings.
  • #3 3754936
    J_ros
    Help: 35
    Rate: 30
    So dB and dBA / dB (A) are exactly the same when it comes to sound intensity?
  • #4 3765992
    J_ros
    Help: 35
    Rate: 30
    Well, I bought a fan that has 19dBA and is louder than the GlacialTech I wrote about earlier. I found a box from him and it turned out to be 20dBA ...
    it's a bit of a strange thing ...
    While searching for the answer, I found a certain page (http://www.digit-life.com/articles2/glacialte...cialtech-socketa-coolers-shootout-nov2k3.html " target="_blank" rel="nofollow noopener ugc" class="postlink inline" title="" > http://www.digit-life.com/articles2/glacialte...cialtech-socketa-coolers-shootout-nov2k3.html ) pay attention to the table at the bottom.
    First of all there is some explanation "A-weighted sound level" - I don't know English very well so I'm curious how you interpret it
    Secondly, GlacialTech Silent Breeze 462 II - which I have and which is supposed to have 20dBA has 30dbA here. (This fan is almost inaudible in the city during the day)
  • #5 3766859
    Petros
    Rate: 355
    dBA is the maira of sound intensity as a weighted average z measured over time with some background noise, i.e. it is a kind of relative loudness
    in the link you provided:
    "The background noise is 19 dBA"
    I hope I helped
  • #6 3767000
    J_ros
    Help: 35
    Rate: 30
    Does everyone calculate this value according to specific parameters - e.g. measurement duration, the same weights or are they any?
    I will not ask about the weights anymore, but if someone knows a published article, I would like to read it (unfortunately it is difficult to find something by typing dBA because it is equivalent to the word cares)
    I saw it, but I have no idea how with 20dBA and 19dBA it comes out 30dBA
    Paweł Es.
    Help: 1236
    Rate: 692
    "A-weighted sound level" means the A-weighted sound level measurement.
    This curve reflects the changes in the ear's sensitivity to signals of different frequencies (the ear is most sensitive in the 1-4kHz range, outside of this range the ear sensitivity drops).
    Obviously, this curve corresponds to the averaged hearing characteristics and does not take into account the phenomenon of a dynamic change in the frequency characteristics of the ear.
    As for the fan, the problem may be that it is not really known under what conditions the noise level caused by the fan was measured and the results may be incomparable. Besides, the 1 dB difference is quite hard to hear :) If you can hear a difference then there must be a lot more than 1 dB difference in levels.
  • #8 3767601
    J_ros
    Help: 35
    Rate: 30
    So there is no other way to determine fan noise than a reliable source review?
    This would be in line with what I see on my fans (19, 20, 21 [dBA]). The one with 19 dBA is incomparably louder than the one with 20dBA, and the one with 21 is a little louder than the one with 19dBA ...
  • #9 3767675
    Paweł Es.
    Help: 1236
    Rate: 692
    And there are no minuses with these numbers? Then it would make sense that -19 dBA is noisy than -21 dBA
  • #10 3768718
    J_ros
    Help: 35
    Rate: 30
    I don't see any downsides
    These fans are:
    21dBA - Silent Cat 90mm
    20dBA - cooler - GlacialTech Igloo Silent Breeze 462 II
    19dBA - cooler - Spire WhisperRock 5
    So my conclusion from the previous post is not true?
  • #11 3784664
    J_ros
    Help: 35
    Rate: 30
    I also have a DO8T-12PM S fan - 21dB also quieter than the Spire WhisperRock 5, but louder than the GlacialTech Igloo Silent Breeze 462 II ...
    This is an interesting matter - if anyone knows what it is, I will be grateful for the answer.
✨ The discussion centers on the differences between dB and dBA measurements in sound intensity, particularly in relation to fan noise levels. Users express confusion over the perceived loudness of fans rated at similar dBA levels, noting discrepancies in actual sound experience. It is clarified that dBA is an A-weighted measurement that accounts for human hearing sensitivity across different frequencies, making it more reflective of perceived loudness. Factors such as measurement conditions and the inherent difficulty in detecting small differences in dB levels (1 dB) are highlighted. Users share experiences with specific fan models, noting that subjective loudness can vary significantly despite similar dBA ratings.
