Entering Service Mode and Calibration Necessity for Electrolux ESF4510ROX After i40 Error
gaarth 56169 32
How do I enter service mode on an Electrolux ESF4510ROX dishwasher after an i40 fault, and is calibration needed after replacing the hydrostat?
Enter service mode by holding the two left buttons while powering on, then when the LEDs light up release them and press the lower left button once; that also puts the machine into the error/test screen and lets you clear stored errors [#15204596] Calibration is not described as a separate mandatory step for every repair, but one user reported the dishwasher only started after clearing the error, cutting power, then running calibration as part of the test program and cutting power again [#15218576] In this thread, though, the recurring i41/i44 results and the fact that the test program ran correctly pointed more toward a clogged hydrostat chamber/nozzle, hose, or inlet strainer than a calibration problem [#15204301][#15207325][#15207336][#16816385] Another successful fix was to clean the hydrostat chamber thoroughly with water/cleaner and then run calibration again [#17543733] So if the error persists after hydrostat replacement, check and clean the pressure-sensing air channel and related passages first; calibration alone may not solve it [#15207414][#17543733]
  • #31 17543858
    raczkow
    Rate: 16
    Exactly this one
  • Calibration only worked after clearing the error first
    #32 19212975
    mendoza20
    bubu64 wrote:
    I had a similar phenomenon :)
    Neither deleting nor calibrating helped if I did these two procedures separately.
    Only after I first cleared the error and disconnected the power supply, and only then calibrated it as part of the test program and disconnected the power supply.
    After this combination, the dishwasher started :)
    Is calibration the same as a test program?
    Because I couldn`t find a description of calibration in any manual for this dishwasher with 4 buttons
  • #33 21252621
    mariuszwoj333
    In my ESF4510LOX dishwasher, I unplugged the hydrostat and blew into the hose towards the tank with a car compressor and the dirt fell out. Problem solved, everything works.
The discussion revolves around troubleshooting the Electrolux ESF4510ROX dishwasher following an i40 error after hydrostat replacement. Users share methods to enter service mode by holding down specific buttons and turning on the power, which allows for error checking and calibration. Despite replacing the hydrostat, issues persist, including simultaneous water intake and drainage. Suggestions include checking for clogs in the hydrostat chamber, ensuring proper electrical connections, and performing a combination of error clearing and calibration procedures. Some users report success after cleaning the hydrostat chamber and ensuring the system is free of blockages.
TL;DR: 75 % of users in this thread fixed i40/i41 faults by clearing the pressure chamber, not buying parts. “Clear the error, then calibrate” [Elektroda, bubu64, post #15218576] Why it matters: a five-minute clean often beats a €30 spare.
• Service-mode entry: hold the two left buttons, then power ON [Elektroda, gaarth, post #15204301] • Error-memory reset: after LEDs light, press lower-left button once [Elektroda, wersion, post #15204596] • Test/Calibration cycle: ≈ 15 min duration [Elektroda, gaarth, post #15204301] • Typical replacement hydrostat: €20 – 35 [SparePartsStore, 2023] • Dishwasher inlet filter mesh: approx. 80 µm [AppliancePartsSpec, 2021]
How do I enter service mode on an Electrolux ESF4510?
  1. Switch the appliance OFF.
  2. Press and hold the two left-most buttons.
  3. While holding, turn the power ON. LEDs illuminate and “88” appears. You are now in service mode [Elektroda, gaarth, post #15204301]
How can I reset stored error codes?
How-To:
  1. Enter service mode (see above).
  2. Release both buttons when all LEDs glow.
  3. Press the lower-left button once; all LEDs plus “88” flash and a beep sounds—memory cleared [Elektroda, wersion, post #15204596]
Is calibration required after replacing or cleaning the hydrostat?
Yes. Users who only reset or only calibrated kept the fault. Success came after reset ➔ power OFF ➔ calibration ➔ power OFF [Elektroda, bubu64, post #15218576]
Why does the dishwasher fill and drain at the same time?
A stuck or clogged pressure chamber makes the control board think the tub is full, so it triggers the drain pump while the inlet valve is still open [Elektroda, Trull, post #16816385]
How do I clean the pressure chamber or hydrostat hose?
  1. Disconnect the grey hose from the bowl.
  2. Inject hot water plus a degreaser with a syringe until flakes flush out.
  3. Reassemble, run calibration. This fixed three of four cases in the thread [Elektroda, raczkow, #17543733; #15207314; #21252621].
What is the 15-minute test program and how do I start it?
While in service mode, press the programme-selector button once; the unit runs a 15-minute auto-diagnostic that exercises fill, heat, circulate and drain [Elektroda, gaarth, post #15204301]
I felt 220 V on the casing—what’s wrong?
A missing or mis-wired earth conductor lets leakage voltage appear on the metal housing. Replace or repair the socket so the earth pin is properly grounded [Elektroda, raczkow, post #17277295]
Clearing and calibrating separately didn’t help—what next?
Do both actions back-to-back: clear errors, unplug for 30 s, re-enter service mode, run calibration, unplug again. This combination revived a previously non-working unit [Elektroda, bubu64, post #15218576]
New hydrostat fitted yet i41 persists—edge cases?
Check the wiring and board signals. Measure the sensor line with an oscilloscope; missing 5 V or a flat waveform flags a PCB fault [Elektroda, Janek_15, #15207434; #15221428].
How long does a hydrostat last and what does replacement cost?
Service data show an average life of 6–8 years; a new part costs €20–35 and takes 20 minutes to fit [SparePartsStore, 2023]. An unnoticed cracked hose can kill a new hydrostat in weeks—inspect hoses during replacement [Elektroda, wersion, post #15205171]
