[Solved] Electrolux ESF4510LOX - Error i30: Drain Blocked & Pump Running Continuously - Reset/Repair Guide
nata17d 8049 2
  • #1 16771518
    nata17d
    Drain blocked but drained. Then the i30 error appeared on the screen. How to reset or repair? The pump runs continuously from the time the water is pumped out.
  • #2 16771595
    Lodxx
    Home appliances specialist
    Help: 105
    Rate: 245
    You have to disassemble the side of the dishwasher and check if there is water at the bottom of the dishwasher, it activates the sensor and constantly pumping water out of the inside.
  • #3 17425762
    nata17d
    We called a repairman who took out the dishwasher, tilted it to the side and the water came out. The problem did not arise again.
