Seeking Firmware for Grundig 40 VLE 8042 S: Backlight Issue After Incorrect Update
michu02pl 16167 5
  • #1 15257184
    michu02pl
    Rate: 22
    Hello, I am looking for a firmware for GRUNDIG 40 VLE 8042 S firmware, because I have mistakenly inserted the other and have backlight and no picture.
  • #2 15257421
    michu02pl
    Rate: 22
    You have to substitute a clean memory and re-upload the soft, so much I know only needs a suitable model for this and not immediately to repair, such an answer is not to be called a decent forum member.
  • Requesting motherboard markings to identify compatible firmware
    #3 15257574
    lisek
    Service technician RTV
    Help: 6352
    Rate: 6883
    Do you have any subtitles on the motherboard?
    Link
    Because I know about this model as much as in the given file
    - LTA400HF16-C01 matrix
    Grundig 40VLE 8042 S
    G.BI 80-40
    JEU812-B
    Probably a Chinese invention with Lan?
    Link
    On German forums, they write Link and Link o (Software SX_NDLNA_100_737_3 / SX_NDLNA_50_737_3 / ....)
    Here is the kind of software Link_ by thommyX_16.Nov , but apparently it does not give the effect ??
    "Uncle Google" ver. it will help a lot ... (phrase: 40vle8041s firmware)
  • #4 15257615
    michu02pl
    Rate: 22
    Just after uploading this software is not good, lan does not have, from what I read is a German from grundiga service sends soft to the mail, unfortunately no contact with him, all info about the TV is on the plate in the picture, it is probably enough to choose the software.
    Added after 15 [minutes]:
    The motherboard is beko VEV190R-4 V0
    lisek
    Help: 6352
    Rate: 6883
    This uplaud from thommy is in a virus!
    These are LAN models (DNLA)
    E.g. series
    32 VLC 3001 C:
    MB: VEV190R-6 V-0
    procesor_scaler BGA MSTAR MSD3717JX-LF (IC402)
    SPI-FLASH Winbond 25Q16BVSIG (IC403) there you have only Boot file
    NAND-FLASH BGA ST NAND01GW3B2CZA6 IC101
    It's from the forum, paws contact Link
  • #6 15257740
    michu02pl
    Rate: 22
    I wrote ssss to my friend and I am waiting for an answer.
