Using DDT2000 Program with VAG-K + CAN on DELL Latitude 5550, Windows 7 64-bit
djwheele 103119 11
How can I make DDT2000 work on Windows 7 64-bit with a VAG-K+CAN cable, and fix the red screen error 1009 when the interface is connected?
Use Avant Browser with IE-compatible mode; the program works on Windows 7 and even 64-bit Windows 8, and in Avant you may need to try the IE-compatible setting in the address bar until it sticks [#15297744][#15297943] Error 1009 means the communication port is not open, so change the COM port advanced Receive and Transmit bytes from 4096 to 1024, or even 512 [#15301777][#15297684] Also verify that the cable drivers are installed, because the browser fix alone is not enough [#15297744][#15299502] One reply recommends DDT2000 v2.6.0.0 as the most stable version on Windows 7, warning that newer versions such as 2.9.0.8 can freeze or be unstable, though the newer database can still be useful [#15301777]
  • #1 15263647
    djwheele
    Help: 9
    Rate: 58
    At the outset, I must say that I have read half of the internet before I decided to bother you, so forgive me if I missed something, and what has already been written.
    I have a VAG-K + CAN (usb) diagnostic interface.
    I have a DELL Latitude 5550 computer and a 64 bit Windows 7 PL
    I received from a friend the DDT2000 program with the base.
    I installed the program as it was written in the manual, along with the replacement of the registration file, etc ...
    My problem begins right now ...
    IE11 ... for my taste, nothing like it does not work with this program.
    After running it in my browser, I see the following message
    "Check your browser compatibility and VBScript support"
    Of course, I turn on the active content that the program asks me for, but that doesn't help.
    - Can anyone help me? Any browser to use?
    - Does this program run on 64 bits and on Windows 7? There are a lot of opinions on the Internet, and I would ask for a specific answer. The fact that it works on Windows XP I read to myself - I'm only interested in Windows 7 and 64 bit.
    - What browser do you use for it?
    Of course, the program, as you have guessed, does not run any further and there is nothing I can do.
    When I start the DDT2000 Light program without the cable inserted, the program starts
    When I start the DDT2000 Light program with the cable inserted and connected to the car, the program starts and shows a red screen with the error 1009 message.
    I have the following settings for the COM2 port on which I have the cables:
    Bits per second: 9600
    Data bits: 8
    Parity: None
    Stop bits: 1
    Flow control: None
    In Advanced moms
    Receive (Bytes): 4096
    Transmission (Bytes): 4096
    Delay time (msec): 1
    I was able to find so much on the Internet ...
    Can anyone give me a hint, advise or guide me on how to connect to my car (RENAULT CLIO II from 2000? 1.4 16V) or Renalt Thalia 1.4 8V from 2003?
    My goal is to remove (turn off) the CHECK ENGINE light in Thala - my dad broke the V-belt, one of the sensors broke. I have replaced the sensor for a long time, Daddy, and the belt too - it remains to erase the error and turn off the CHECK ENGINE light.
  • DDT2000 error 1009 appears with cable connected
    #2 15297684
    norman9
    Rate: 16
    In general, it should be the other way around :)
    djwheele wrote:
    In Advanced moms
    Here I have both set to 512
    The rest is approx
  • #3 15297719
    djwheele
    Help: 9
    Rate: 58
    in general, your answer did not contribute anything, but if you have already spoken, maybe you will help me ...
    how to configure DDT2000 to work?
    what am I doing wrong?
    can you suggest something constructive?
    when I run the program without the cable connected - the program starts
    when he puts the cable and under the computer - he gets a red screen and error 1009
    Use Avant Browser with IE compatibility and cable drivers installed
    #4 15297744
    norman9
    Rate: 16
    Of course it works, even on windows 8 64BIT.
    You must use the AVANT BROWSER browser and in the address bar to the right in front of the arrow, select "IE compatible."
    It works for me, sometimes you have to repeat the option with IE compatibility, but it's probably not a problem :)
    Added after 16 [minutes]:
    And did you do everything I wrote? If so, you are fast :-)
    I have described everything ...?
    And which ddt2000 do you use mister?
    I forgot the main question:
    Are the cable drivers installed?
    Browser under Avant must run, you select compatible with IE
  • #5 15297880
    djwheele
    Help: 9
    Rate: 58
    Thank you very much - I didn't notice the edition :)
    Now I have -15 outside the window :) and the rally car is in the garage next to the house ...
    tomorrow I will check if something helped.
    thanks for hint with this AVANT BROWSER ... I did not know
    Avant Browser IE compatibility mode enables DDT2000 on 64-bit Windows
    #6 15297943
    norman9
    Rate: 16
    Here you are :-) I hope you will find my hint helpful.
    I was also tired for a long time, because I have not found anything about win7 and 8 64 bit anywhere. I checked all available browsers and nothing, only Avant (luckily encountered) gave a positive result.
    And remember to tick at the top in the address bar to the right of "IE compatible", there are two, and it only works for one.
    I am surprised only by the reverse reaction to connecting the cable when using the DDT2000 light. It worked normally for me. I would even go around with the cable drivers. ;-)
  • #7 15298555
    djwheele
    Help: 9
    Rate: 58
    This Avant is brilliant ....
    The DDT2000 screen started to look different right away ... (attachment)
    You started a new chapter with DDT2000 in my life :D
    When I get back from Pracbazy, I immediately sit down and start working again ...
    I think the temperature discourages me :D
    [/ img]
    ps ..... what drivers to get?
    I use, say, dedicated ...
    I was buying my cable on alledrogo under passat and there were some drivers ...
    vag smigal on them .... and I'm using these now
    • Using DDT2000 Program with VAG-K + CAN on DELL Latitude 5550, Windows 7 64-bit Bez tytułu.png (26.57 KB) You must be logged in to download this attachment.
    norman9
    Rate: 16
    I personally use these drivers. Except that I have the obd2 kkl interface, but it won't hurt to try. You can always go back to the previous ones. :-)
    I checked, the drivers will match, so go ahead and install ;-)
    • CDM_2.04.16_WHQL_Certified.zip (4.06 MB) You must be logged in to download this attachment.
  • Reduce COM buffers and use DDT2000 v2.6.0.0
    #9 15301777
    gsm_virus
    Help: 240
    Rate: 191
    Data bits: 8
    Parity: None
    Stop bits: 1
    Flow control: None
    In Advanced moms
    DDT error described as 1009 is
    "1009 E_FILENOTOPEN = Communication port not open"
    ie "communication port not open" ... and it may be the setting of the transfer amount.
    Instead 4096 should 1024 (sometimes even 512 works).
    djwheele wrote:
    and 64 bit Windows 7 PL
    On Win.7, DDT fixes were included, but there is no version list at hand :|
    I suggest that you get DDT2000 v 2.6.0.0 because from my own experience I know that each version above, despite the already improved DDTregisterInfo.dll libraries, is unstable or freezes the system altogether.
    Look here http://chomikuj.pl/klikklikklikacz/Auto+-+diagnostyka/DDT2000+v.2.6.0.0
    Don't download DDT v2.9.0.8! Because you'll be disappointed anyway :D
    Only take 2.6.0.0
    from the folder with DDT2.9.0.8 take only BAZE from ECU => DDT2000data.rar
    is the most up-to-date because from 2013.
    http://chomikuj.pl/klikklikklikacz/Auto+-+diagnostyka/DDT2000+v.2.9.0.8
  • #10 15703003
    hobbyelektronik
    Help: 85
    Rate: 178
    Hello...........
    Recently released version: Renault DDT2000 v2.9.0.8 Multilanguage,
    or maybe there is an option in Polish?
  • DDT2000 supports French and English, with Polish XML translations
    #11 15703632
    gsm_virus
    Help: 240
    Rate: 191
    I do not think that anyone would like to translate into several languages ... so far I had the above-mentioned version and from the availability of languages it is with "Multi Lang", at most "dual lang" ... to choose from -> Francis or -> English
    The crack of the DDT2000 Light interface itself has already been published on the forum,
    at this link a colleague's post yarocz https://www.elektroda.pl/rtvforum/topic1286164-240.html#9010695
    As for diagnostics and displaying errors, when you see messages in English (not French) it's a success anyway ... some enthusiasts even translated these XML "flashcard" files into Polish.
    http://www.ddt2000.cba.pl/pliki.php
  • #12 15818994
    djwheele
    Help: 9
    Rate: 58
    Generally, it turns out that AVANT is the best for the ills that I had.
The discussion revolves around the use of the DDT2000 diagnostic program with a VAG-K + CAN USB interface on a DELL Latitude 5550 running Windows 7 64-bit. The user encounters compatibility issues with Internet Explorer 11, receiving an error message regarding browser compatibility and VBScript support. Suggestions from other users include using the Avant Browser with the "IE compatible" mode enabled, which reportedly resolves the issue. Additionally, users discuss the importance of having the correct drivers installed for the diagnostic cable and recommend using DDT2000 version 2.6.0.0 for better stability, while cautioning against version 2.9.0.8 due to instability concerns. The error code 1009 is identified as a communication port issue, with recommendations to adjust transfer settings.
