Dell Laptop, Windows 8, Core i7, 6GB RAM: Using VGA 15pin to COM RS-232 Adapter for Car Diagnostics
an_mat 5964 8
  • #1 16235737
    an_mat
    Rate: 46
    I want to use my Dell laptop for car diagnostics. Windows 8, Core i7 CPU, 6 GB RAM. The interface has an output that I need to connect to the laptop on COM RS-232. My laptop does not have this port, but it has a VAG connector (three rows of 5 pins). Will the interface work properly after using this adapter?
    • Dell Laptop, Windows 8, Core i7, 6GB RAM: Using VGA 15pin to COM RS-232 Adapter for Car Diagnostics VGA_port.jpg (306.14 KB) You must be logged in to download this attachment.
    • Dell Laptop, Windows 8, Core i7, 6GB RAM: Using VGA 15pin to COM RS-232 Adapter for Car Diagnostics adapter 15-9 pin.....jpg (45.47 KB) You must be logged in to download this attachment.
    • Dell Laptop, Windows 8, Core i7, 6GB RAM: Using VGA 15pin to COM RS-232 Adapter for Car Diagnostics adapter 15-9 pin..jpg (10.15 KB) You must be logged in to download this attachment.
  • #2 16235751
    Kasek21
    Help: 4981
    Rate: 3547
    No.
    You can try with the USB-> RS232 adapter, but not every interface will work.
  • #3 16235761
    an_mat
    Rate: 46
    Well, from what I read on the network, USB is not a good solution.
  • #4 16236301
    iron64
    Help: 648
    Rate: 313
    What difference what people write, it's the only solution you have. Buy, check for yourself. It works for me, many people too.
  • #5 16236308
    Krzysztof Kamienski
    Help: 2033
    Rate: 5166
    COM x (RS 232 serial port) on the VGA port (external monitor) no, no :cry: Maybe OBD2 to HDMI adapters appeared on OLX? I would buy a few pieces ... how cheap.
    VAG / VGA what's the difference and so three same letters. :D
  • #6 16237211
    bolekis
    Help: 200
    Rate: 264
    This is not VAG - Volkswagen Audi Gruppe but VGA - Video Graphics Array, i.e. monitor output. Does the laptop have an ExpressCard slot?
  • #7 16237664
    an_mat
    Rate: 46
    There is no Express Card slot
  • #8 16237929
    Kasek21
    Help: 4981
    Rate: 3547
    Check with the adapter - it's just pennies.
  • #9 16288504
    an_mat
    Rate: 46
    I resigned from buying a more advanced device and bought a scanner with an attached display, it reads the basic engine errors and clears them - enough for me
    OBD2 Vscan
The discussion revolves around using a Dell laptop with Windows 8, Core i7 CPU, and 6GB RAM for car diagnostics via a COM RS-232 interface. The user seeks to connect the interface to the laptop, which lacks a native RS-232 port but has a VAG connector. Responses indicate that using a USB to RS-232 adapter may not guarantee compatibility with all interfaces. Clarifications reveal that the VAG connector is often confused with VGA, which is a video output. Suggestions include testing inexpensive adapters and considering alternative diagnostic tools, such as an OBD2 scanner with a display, which the user ultimately decided to purchase.
