Wi-Fi network channels in the 5 GHz band
bober900 36291 16
How do 5 GHz Wi‑Fi channels work in Poland, and can a router without DFS be used manually only on channels 36, 40, 44, and 48?
Yes—5 GHz Wi‑Fi channels overlap by definition, they are spaced 5 MHz apart, and the signal spectrum does not stop sharply at the channel edges, so there are no clean gaps between adjacent 20 MHz channels [#15298233] In Poland/EU, a router without DFS can be set manually only to channels 36, 40, 44, and 48 [#15298233] The remaining 5 GHz channels are generally available only in automatic mode, or they must be disabled automatically when the required conditions appear [#15298233]
  • #1 15292424
    bober900
    1. Hello, maybe a stupid question, but I wonder if the Wi-Fi network operating in the 5 GHz band in Poland has channels divided so that there are no channel gaps between them?
    For example, if the width of individual channels in the 5 GHz band, as far as I know, is 20 MHz, and the center frequency of channel 36 is 5180 MHz, channel 40 is 5200 MHz, then channel 36 ends at 5190 MHz and the channel starts from the same frequency 40?
    2. In Poland, can an ordinary user with a router without DFS, work only on 4 channels (36, 40, 44, 48) - (at least I can only choose these in the router settings)?
  • #2 15292825
    smario11
    Help: 140
    Rate: 120
    If you insist, you can operate at 4900-6100mhz, but usually the devices will not connect
  • #3 15294060
    Fotodetektor
    Level 30  
    Help: 101
    Rate: 335
    Change the country on your router to USA.
    OMNI-SAT
    WP 11, Wołów, 56-100 | Company Website: www.omnisat.pl
  • #4 15294348
    KOCUREK1970
    Help: 3862
    Rate: 5490
    Fotodetektor wrote:
    Change the country on the router to USA.
    And Poland is the USA? - Does a colleague know what the threat is?
  • #5 15294364
    Fotodetektor
    Level 30  
    Help: 101
    Rate: 335
    KOCUREK1970 wrote:
    And Poland is the USA? - Does a colleague know what the threats are?
    I'm listening? The police will come and take your router from home and put you in for 10 years ?!
    It is possible to choose the country and you can take advantage of it!
    As if something else was blocked. You are not interfering with the equipment in any way illegally.
    OMNI-SAT
  • Unlicensed Wi-Fi still requires compliant power and operation
    #6 15294506
    KOCUREK1970
    Help: 3862
    Rate: 5490
    There is no certification of the WiFi network for 2.4GHz and 5GHz, because these are free bands, you do not need a license, you only have to use devices with the CE standard, not exceeding the permissible transmission power. The CE standard obliges to maintain the appropriate purity of the emitted signal.
    Will you also drive 400 km / h on the motorway in Germany - after all, it's allowed ...
    In the instruction manual of the equipment, it is clearly stated whether or not the equipment is allowed or not and how to use it.
    You are disrupting the operation of other devices by your actions.
  • Transmit power may matter more than channel selection
    #7 15294542
    Fotodetektor
    Level 30  
    Help: 101
    Rate: 335
    Theory is important and practice verifies.
    If a guest lives in a house near the forest, who is disturbed by what ?!
    A grain of interference without LTE interference bag for SAT, DVB-T.
    You can multiply.
    I would be more on the power of the rotors than on the transmit channel.
    You know what the standard is, and there are those that have CE and regulation up to 1W.
    Anyway, even in the licensed bands of the Internet, strange things are happening and which I will not write
    OMNI-SAT
  • #8 15294655
    KOCUREK1970
    Help: 3862
    Rate: 5490
    @Fotodetektor
    All this is agreement - only this does not change the rule that you do not use something that is not certified in Poland (the equipment has the US band, because it is produced for such a market) - but common sense and our health should be the most important.
  • #9 15295211
    Fotodetektor
    Level 30  
    Help: 101
    Rate: 335
    Amen. Finally, I will add that changing the channel does not mean that the router has more power in the sense of 100 mW.
    OMNI-SAT
  • Poland restricts non-DFS 5 GHz routers to channels 36–48
    #10 15298233
    Nagus
    Help: 99
    Rate: 97
    Does the Wi-Fi network operating in the 5 GHz band in Poland have channels divided so that there are no channel gaps between them?
    In WLANs, the channels overlap by definition. In both bands, the channels are 5 MHz apart. In the 5GHz band, every fourth is used to limit the influence of adjacent channels. The spectrum of the WLAN signal does not end like a cut with a knife, tails can drag themselves along a couple of MHz.
    In Poland, can an ordinary user with a router without DFS work only on 4 channels (36, 40, 44, 48)
    Yes. In EU, the remaining channels can only be available in automatic mode, or manual selection has to be automatically canceled after the occurrence of appropriate conditions.
    Not true. Radio parameters of devices that can be used without a radio license are specified in the regulations of the relevant ministry, most recently it was the Ministry of Administration and Digitization (Journal of Laws, item 1843 of December 12, 2014) and the Telecommunications Law (in this case, Article 144 (2)). point 5).
    Theoretically, there are penalties, but in a country where MPs steal and still boast about it on TV, who would care ...
  • Warning against illegal Wi-Fi operation and penalties
    #11 15298276
  • Smartphones can use non-European 5 GHz channels
    #12 19417315
    hubig
    Rate: 29
    Regulations, regulations, requirements, requirements, and life itself.
    Oddly enough, smartphones (legal, officially purchased) can somehow be configured in such a way that they communicate on "non-European" channels on the 5 GHz frequency. For example, my smartphone (Samsung Galaxy A40), after setting the operating mode to hot spot / access point (the so-called WiFi router), sets the channel, e.g. to 149 and the D-Link router, with the country set to Poland or Europe, cannot to communicate with it, because with these settings it does not support this pseudo-American channel. To make it funnier, the smartphone does not have the option to manually set the channel (to "allowed in Europe"). Samsung smartphone tech support doesn't do anything about it (I reported). It is similar with a laptop (HP Elitebook), also officially bought in our country (not in China, not through A..express portals) and an operating system configured for Poland - it easily connects to a smart on channel 149.
    So, reprimands, or instructions in the style of "in Europe this range must not be used" is a bit of a coquetry.
  • Smartphone hotspot uses unsupported 5 GHz channel 149
    #13 19417421
    Interesant
    Help: 204
    Rate: 249
    No coquetry, just the phone manufacturer:
    a) When writing the "He took the easy way ..."
    b) Looks to customers in the teletechnical group (Installers, IT specialists) ;-)
    Ps. Just because you have legally acquired the equipment is not the same as using it illegally. You can buy an anti-radar legally, but you can only transport it in a car when it is disconnected from the power supply.
    Not to mention cars with a maximum speed hen hen far to the right of the legal 140 km / h (I will not even mention 50 km / h).
  • #14 19417622
  • 5 GHz hotspot channels may be legally restricted
    #15 19421066
    hubig
    Rate: 29
    Interesant wrote:
    Ps. (... ;)
    That doesn't relate to the heart of the matter, but I can't help but make this comparison not very accurate. While the speed in the car is decided by the driver and has the technical ability to use = drive at the speed permitted by law, for example, the smartphone user I mean (WiFi 5GHz, channel eg 149) cannot communicate wirelessly on another, " legal "channel.
    What's more, the average electronics user has no idea which channel the devices communicate with each other. So by running a hot-spot on such a smart and connecting to it from a laptop (a set of devices from my example - I am forced to use it myself), I willingly-accidentally operate on a channel with "dubious legality".
    Surely there will be an answer that ignorance of the law does not release you from liability ... So buying the equipment would be appropriate then not to use it for certain "illegal" purposes ...
  • Complexity of modern Wi-Fi and LTE channel use
    #16 19421238
  • Driver uses location to set allowed Wi-Fi channels
    #17 19421548
    bobycob
    Help: 31
    Rate: 82
    The 2.4 GHz band also has a different number of channels available depending on the country. A device configured for the USA will not find an AP on channel 13 for anything.
    Just so that the user does not have to think about it, the driver retrieves information about allowed channels from the location. Users unaware of this when choosing a location other than the actual one accidentally end up with WiFi problems.
The discussion revolves around the use of Wi-Fi channels in the 5 GHz band in Poland, specifically addressing whether there are gaps between channels and the limitations for users with routers lacking Dynamic Frequency Selection (DFS). It is clarified that while the 5 GHz channels are spaced 20 MHz apart, they do overlap, and users can only access specific channels (36, 40, 44, 48) without DFS. The legality of using non-EU channels is debated, with some users suggesting changing router settings to the USA to access additional channels, while others caution against potential legal repercussions. The conversation highlights the complexity of Wi-Fi regulations and the challenges users face in ensuring compliance with local laws.
