Searching for Accurate BN4400622B Power Supply Schematic for Samsung TV
Kamra 16140 12
Where can I find the correct schematic for Samsung power supply BN44-00622B, since the one available online does not match my board?
There is no exact service manual/schematic available for BN44-00622B; only similar solutions based on the ICs used on the board are available [#15349164] BN44-00622B is identified as L42X10_DHS and is used in models such as UE40F6500AB, UE40ES7207, UE46ES7000, and UE46ES8000, with parts like ICP801S (SPC7011F), ICS801CS (SQD3011K), IC9201/IC9101 (SLC2013M), QS851 (MDS1653), and ICM801CS (FSFR1900/FSFR2100) [#15349164] A related supply, BN94-00622J, is used in UE40F6500AB, UE40F6100, UE40F6320, and UE40F6740, and uses IC811S VIPER12A, IC802S ICE1PCS02, IC804S STR-W6765, plus PFC transistor QP802C (60R360N) [#15349164] If you need a close reference design, BN44-00473A was suggested as very similar [#15454560]
  • #1 15342469
    Kamra
    Rate: 9
    I am looking for a power supply scheme from Samsung TV
    BN4400622B
    ps.schemat which is available on the net is not the one of this adapter
  • #2 15342512
    mirex
    Help: 1950
    Rate: 1989
    It is not and will not be there for a long time.
    However, there are some things on the systems working there as well.
    Or maybe you would be so nice and gave everyone the design of this power supply? ;)
  • #3 15347486
    Kamra
    Rate: 9
    And you do not know how it is with the power supply of LED strips, whether they are sequentially powered or parallel because half of the TV has no backlight
  • #4 15349164
    lisek
    Service technician RTV
    Help: 6339
    Rate: 6860
    BN44-00622B * L42X10_DHS
    * for UE40F6500AB, UE40ES7207, UE46ES7000, UE46ES8000
    ICP801S - SPC7011F
    ICS801CS - SQD3011K
    IC9201 IC9101 SLC2013M
    QS851 - MDS1653
    ICM801CS - FSFR1900 (FSFR2100)
    BN94-00622J
    * for Samsung UE40F6500AB, UE40F6100, UE40F6320, UE40F6740
    IC811S VIPER12A
    IC802S ICE1PCS02
    IC804S STR-W6765
    Field effect transistors in PFC QP802C (60R360N) from Magnachip co.kr Link
    There is no SM only after similar solutions based on the applied IC
  • #5 15444094
    kazikszach
    Help: 513
    Rate: 1100
    I am also looking for a scheme, Samsung UE40F6500SS TV.
    BN44-00622B * L42X1Q DHS power supply, circuits such as fox mates, only ICM801CS is FSFR1800HSL and this one is torn apart, it needs a schematic with elements next to it.
  • #6 15446940
    lisek
    Help: 6339
    Rate: 6860
    Look here at SM BN44-00428B Link_
    * click on bold (??????? ????? BN44-00428B_)
    * or search for this SM here on the forum in the schematic database
  • #7 15448815
    Michał99
    Help: 140
    Rate: 344
    File reported as dangerous, available exceptionally without logging in.
  • #8 15449044
    mirex
    Help: 1950
    Rate: 1989
    What does he say to you that he is dangerous? None of my watchmen have a problem with him. ;)
    Each file on archive. it is available without logging in, and not "exceptionally". ;)
    And anyway .... have something to fox. If he prefers foreign links, although we have two files BN44-00428, that's his thing. ;)
    Not only two, because FSFR1800 and FSR1700 are still BN44-00338, BN44-00339. ;)
  • #9 15449208
    Michał99
    Help: 140
    Rate: 344
    If you want to save it displays info that contains links to viruses and other programs.
  • #10 15449259
    kazikszach
    Help: 513
    Rate: 1100
    I tried to determine the cause of the FSFR1800HSL system damage.
    After desoldering this system I did not find any further short circuits, I decided to check the PFC voltage, I loaded it with a 1k? resistor and switched on the power supply, after clicking the relay the meter showed 310V for a fraction of second and the power fuse was blown, short circuit got MOS transistor in PFC, after disconnection and re-switching to the network, the balloon from the ICP801S SPC7011F system flew out, the voltage supplying it is 15V, which means correct.
    I suspect that the PFC system somehow went crazy and gave too much voltage, which caused damage to the FSFR1800HSL system.
  • #11 15449321
    mirex
    Help: 1950
    Rate: 1989
    But what's that talking to you? Some AVG? Nothing included, I can not see anything quickly. Maybe your anti-virus for Chinese allergy? ;)
    He treats this the same way from us?
    https://www.elektroda.pl/rtvforum/topic1497469-150.html#11931289
    You probably are right, Kazik, for the reasons for the FSFR damage.
  • #12 15450362
    Michał99
    Help: 140
    Rate: 344
    Hello mirex. The one from the electrode is ok.
    It looks like the windows firewall is working.
✨ The discussion revolves around the search for an accurate power supply schematic for the Samsung TV model with the part number BN4400622B. Users express frustration over the unavailability of the correct schematic online, noting that existing resources do not match the required specifications. Various users share insights about related components and similar models, including the UE40F6500AB and UE40ES7207, while discussing issues with LED backlighting and potential faults in the power supply circuit. Some users provide references to alternative schematics and components, such as the FSFR1800HSL and PFC systems, while others caution about the safety of certain online files.
