led tv SAMSUNG UE40D5003 power supply+driver LED : BN44-00473A -not turn on
andrasoni_lucian 5535 2
  • #1 17707662
    andrasoni_lucian
    Rate: 11
    I have this tv with this problem: at start-up, the St.By LED flashes twice, after which it stays in St.By, sometimes the LED flashes twice in a cycle of 5 time. At the start, for moment,is present the tensions PFC = 390V, voltages of 5,2V, 12,7V and voltage for led driver, after that this tensions fall in 0. I replaced ICP801S = SPC7011F, ICM801 = FSFR1700XSL, the electrolytes caps beside these two integrated and PC801S, PC802S, PC803S optocouplers, I redo the soldering, including the smd components, "cold" measurements on components. Only the voltage St.By = 5,2V, the rest, no change. With the coupler removed from the mainboard, the backlight does not work at all. Maybe someone has encountered this problem, thank you!
    • samsung_bn44-00473a_pslf121a03s_smps_ue40d5003.pdf (203.27 KB) You must be logged in to download this attachment.
  • #2 17809672
    querij
    Help: 42
    Rate: 228
    Try replacing the CM813
  • #3 19738388
    Indyczes
    Help: 186
    Rate: 272
    I have the same fault as the author of the topic, I mentioned the same elements, maybe someone will enlighten me where is the problem?
