ESP8266 does not display list of available WiFi networks after AT+CWLAP command
ciko 2826 4
  • #1 15345449
    ciko
    Rate: 8
    I have purchased 3 tiles from different sources.
    Unfortunately I have a problem with them.
    No matter what soft I upload I have the same thing.
    The chip responds to AT commands.
    But when I type AT+CWLAP I get only OK response. I have no list of available APs.
    But if I type AT+CWJAP="xxx", "zzz" I get the answer +CWJAP:1 FAIL
    Has anyone had a similar case?
    Regards, CIKO
  • #2 15345767
  • #3 15345775
    ciko
    Rate: 8
    I have already checked AT+CWMODE=1 and AT+CWMODE=3
    Unfortunately this is not it.
  • #4 15375810
    ciko
    Rate: 8
    Anybody have any ideas what to do about this fancy?
    Best regards, CIKO
  • #5 15396223
    ciko
    Rate: 8
    The problem turned out to be the power supply.
    The power supply I was using only had 3.3V written on it and gave 3.48V with load.
    After fitting the stabiliser the circuits started to work.
    Regards, CIKO
