ESP8266 (ESP-01) resets on error, AT+CSYSWDTDISABLE command does not work
Pocieszny 2094 0
  • #1 15351256
    Pocieszny
    Help: 229
    Rate: 263
    I have an ESP9266 (ESP-01). I have uploaded this firmware to it
    AT+GMR
    AT version:0.21.0.0
    SDK version:0.9.5
    When the module returns an error message like this (occurs after an invalid client disconnection):
    0,CONNECT FAIL
    module restarts.
    I have found information that this may be the fault of the watchdog. I want to disable it with the command AT+CSYSWDTDISABLE , but I get the message ERROR . The watchdog enable command behaves in the same way.
    I got the commands from here: http://www.pridopia.co.uk/pi-doc/ESP8266ATCommandsSet.pdf
    Have any of you encountered this problem?
