Wireless network diagnostics - Internet connection stability
jimasek 110613 0
  • A very common problem that appears on our forum is unstable access to the wireless network in our house / apartment. In order to be able to say anything in this matter, you need to perform a diagnostics of such a network and try to find out what is the cause of such behavior of the network or devices trying to connect to it.
    [line: a4cf5877c5]
    TEST 1 - signal measurement
    The basic test with which we must start our wireless network diagnostics. The application allows us to track the signal level from our router / access point. At the same time, we can observe its stability as a function of time and interference from other wireless networks in our vicinity.
    Windows systems - inSSIDer or Xirrus Wi-Fi Inspector or
    Acrylic WiFi Home - see the appendix to the guide
    Android OS
    Wifi Analyzer
    WiFi Analyzer (open-source)
    WiFi Monitor
    Apple OS X - Link
    WiFi Scanner
    Linux OS
    - LinSSID
    Kismet wireless
    [line: a4cf5877c5]
    TEST 2 - measuring the speed of internet access
    We measure the speed of internet access from the device on which we have stability problems. There are tons of speed tests available online.
    I recommend:
    www.speedtest.pl
    beskidmedia.speedtestcustom.com
    www.speedtest.net
    test.mm.pl
    Certified speedtest and information from UKE:
    https://pro.speedtest.pl/
    https://cik.uke.gov.pl/uslugi-teleko/pomiar-predkosci-internetu/c certowany-mechanizm/
    https://pro.speedtest.pl/pomiar_c certowany_i_niec certowany
    [line: a4cf5877c5]
    TEST 3 - network card addressing - connection reset
    We run the ipconfig / all command entered into the cmd console which will show us the addressing on network interfaces (we are interested in the card on which we have access to the Internet) - Link
    [line: a4cf5877c5]
    TEST 4 - Measurement of link stability and the amount of lost data packets
    We download the application - WinMRT or PingPlotter or PingDoctor for iOS
    We unpack and run
    In the HOST field, enter the domain address or IP address of the server with which we have problems, e.g. wp.pl, onet.pl, google.pl or 31.186.84.219 and click START.
    Remember to turn off all updates or p2p programs (torrent) at this time so that the connection is not overloaded by the computer. As far as possible, we use the Internet only on this computer where we diagnose the link:
    After about 10-15 minutes of testing, click STOP and wait for the program to finish its work. Then click the button Export TEXT so as to export the whole test to a txt file, which we will then attach to our post.
    Hostname - IP address or network name of the next router in the network
    No - another router, host on the way of data packets from our computer
    Loss% - percentage of losses on a given jump (preferably 0%)
    Sent - number of sent packets (pings)
    Recv - number of received packets (pings)
    Best - the best ping
    Avrg - Average ping speed
    Worst - worst response speed
    Last - the last answer
    PingPloter - how to interpret the results
    The PingPloter application for PC is a very good tool for diagnosing Internet access problems. You can check the delay or loss of packets in communication to a specific server (IP address or Internet domain).
    As you can see, the application shows us the next "jumps", i.e. communication nodes where our data packets (inquiries) go to the destination set by us. The program even itself indicates potential communication problems, marking the next nodes in orange or red when there are visible problems or delays. We can quickly conclude from this that if the first communication points are green (it all depends on how many devices we have) then everything is fine with us and we do not have to worry about our network.
    [line: a4cf5877c5]
    We paste all the results of the above tests into our forum thread in the form of print screens - Link - we also remember about detailed information about the models of devices that we use in the network (wireless router, access point, wireless card)
    [line: a4cf5877c5]
    FILES TO DOWNLOAD:
    • Acrylic_WiFi_Home_v4.5.7716.24042-Setup.exe (4.35 MB) You must be logged in to download this attachment.
    • pingplotter_install.exe (20.83 MB) You must be logged in to download this attachment.
    • WiFiInspector-Setup-1-2-1-4.exe (21.19 MB) You must be logged in to download this attachment.
    • WinMTR-v092.zip (1.82 MB) You must be logged in to download this attachment.
    • inSSIDer-installer.zip (3.59 MB) You must be logged in to download this attachment.
    • Inssider_Portable.zip (1.05 MB) You must be logged in to download this attachment.
    jimasek
    jimasek wrote 35287 posts with rating 2681, helped 3783 times. Live in city Piaski. Been with us since 2007 year.
