Top USB 3.0 WiFi Adapter and Repeater Models for PC Without PCI Slots
gamemaniaco1987 1866 4
  • #1 21695025
    gamemaniaco1987
    i need buy what best models of USB3.0 Wifi Adapter for use in PC with not disponible PCI and what best models od Repeater Wifi for use in PC? its necessary many money for good adapter and Repeater?
    router support some easymesh not compatible company my network
  • Clarifying router model, signal strength, and adapter needs
    #2 21695068
    dt1
    Admin of Computers group
    Help: 7315
    Rate: 8292
    Best for what? What is your access point or wifi router model? Why do you need the best and not the standard card? What is the location of your AP/WiFi router relative to a PC location (how many walls, ceilings between them)? What is the signal strength (in dBm) of Your wireless network in a place You need this card to work?
    and what best models from Repeater Wifi for use in PC?
    I am not aware of any repeaters to use in a PC. They are mostly external standalone devices. And most of the times it is advised not to use them.
    its necessary much money for good adapter and Repeater?
    Yes or no. The cheapest cards tend to be not too good. The most expensive cards tend to be overpriced, sometimes offering not too big advantage over some better priced cards.
    I can't understand this.
  • #3 21695291
    gamemaniaco1987
    The best USB Wi-Fi adapter sold on AliExpress to connect to my PC and get the maximum possible speed even though it's 9 meters away from the main TPLink BSN3000X router and against a wall.
    My Asrock motherboard is a small MicroATX, and its PCI slot is already occupied by a Radeon R7 360.
    Asrock B75M-DGS R2.0 IS My motherboard
  • #4 21695360
