Hormann BiSecur Gateway LANWAN - no connection via VPN, only works on LAN
malybz 1215 6
  • iOS app likely blocked by VPN routing or discovery
    #1 21639661
    malybz
    The Hormann BiSecur LAN/WAN gateway only works on the LAN anymore.
    From the phone outside the LAN, I connect via VPN.
    The VPN server is set up on the router to which the gateway is connected by cable.
    On the phone, after connecting to the network via VPN, I can see the BiSecur gateway in the web browser, but the BiSecur application is unable to connect to the gateway.
    When I am on the LAN, the app on the phone normally detects the gateway and works fine.
    What could be blocking the app from connecting to the VPN?
    AI: What type of VPN is being used (e.g. OpenVPN, L2TP, PPTP) and is full tunneling or split-tunneling enabled in the VPN configuration? .
    L2TP
    AI: What operating system (Android/iOS) and version of the BiSecur app do you have installed on your phone?
    iOS
  • #2 21649071
  • #3 21649200
    malybz
    The app finds the gateway itself.
  • #4 21649223
  • #5 21649268
    malybz
    In the manual it says the web goes on port 80 and on port 4000 goes some proprietary protocol via TCP. I checked with linux nmap -sV and indeed only these two ports are used. I don't know what blocks applications outside the LAN. Maybe there is a solution to enter the phone via VPN so that the gateway does not know that the phone is outside the LAN?
  • Broadcast or multicast likely blocking VPN discovery
    #6 21649289
  • #7 21649471
    malybz
    I haven't done the steps you write about, but I will look and test. For now, thank you for your replies and I hope to hear back soon with the results of your actions.
The Hormann BiSecur LAN/WAN gateway works normally on the local LAN, but the BiSecur iOS app cannot connect when the phone is outside the LAN and connected through an L2TP VPN on the router. The gateway is visible in a web browser over VPN, but the app discovers the gateway automatically and fails to connect, suggesting a broadcast or multicast discovery issue rather than a simple IP reachability problem. The gateway uses HTTP on port 80 and a proprietary TCP protocol on port 4000. Possible causes discussed include firewall filtering, blocked broadcast/multicast traffic across the VPN, or an L2-layer limitation; a tunnel solution such as EoIP was mentioned, but iOS does not appear to support it.
