Sharing My User Experience: nbox Decoder with Enigma2 Review
damago1 23340 10
How can I make an nbox decoder with Enigma2 work stably and simply for basic TV viewing?
Install a lightweight image such as OpenPLi 8.6.0 or PKTeam instead of the heavy preloaded setup; users reported that these systems work without hangs and already include what is needed for normal viewing [#15453187][#15454397] If you only need basic TV plus timeshift, keep the configuration minimal and use the card from the splitter with the required softcam setup if your card needs it [#15453187][#15453073] You can also set the fan or disk to go to sleep from the menu when the decoder is in standby [#15453187] Deep sleep is not available in the original software, so standby still leaves the device partly active [#15453187] If you want a fully featured, faster, and more polished receiver, the thread suggests spending significantly more than the nbox class of hardware [#15445086][#15454288]
  • #1 15444601
    damago1
    Help: 12
    Rate: 29
    I would like to describe my impressions of using the nbox decoder with enigma2. I hope they will be useful, because unfortunately I didn't find such a review before buying it.
    The receiver was recommended to me by the seller, with the assumptions I gave him:
    * the receiver is supposed to work (entertainment for me is to watch TV, not the constant burying under the hood)
    * it has to be stable (nothing annoys me as much as something that does not work properly, hangs etc.).
    * is to be simple in basic use (it is dedicated to a guest room)
    And what is the reality:
    * absolutely not plug & play. The receiver came configured and it took me about 3 hours (YES!) Before I managed to make it display the decoded image from Cyfra +. I am a programmer, I can read forums and information on the Internet, so I'm not a complete layman.
    * software crashes, hangs, crashes if the user does anything other than a correctly executed magic command sequence. Reading the messages on the screen carefully and following them certainly does not work. For example: when searching for programs, the green square = search is displayed. If it is pressed, it will sag. But if you press [ok] instead, it looks for. Over and over again. Whichever wrong path you follow: this ends up crashing the receiver.
    * trying to select the HDD check function (due to the fact that during the installation I hard reset it, I decided to check if the hdd has no errors 50 times after that) - it hangs, like it does something but I left it for 24 hours, I came the next day on he was doing (or maybe he was hanging) lame.
    ...over and over again.
    It is totally overloaded with typically technical features. For example, one of the buttons on the remote control enters the file list on the file system. Why the hell is that on top?
    Using the settings for someone who is not a total expert in DVB-SAT is impossible without a google with which we decode word by word every option available in the settings (how can a normal person know what is BZZB / BXXB or whether to choose mgcamd135_newcs165 or OSCAM 8648_110 Readers only. The worse that the device has a Polish version of the software pre-installed, so you do not know what to look for on the net - in the English version it would probably be easier to find descriptions of these different words in a foreign language of SAT geeks. There is no help that would describe the consequences of selecting a given setting and in what cases should you use it and in which not to bother with it.
    It is even more difficult because most of the information about enigma is on coded forums that require logging in and creating a profile. For today, enigma2 does not even have an article on Wikipedia (neither Polish nor English).
    As it started to work more or less, we come to the daily service:
    The first problem is that the device cannot be turned off other than by removing the plug from the socket. Kind of shutdown (only E2 is lit on the display) - the hard drive or the fan continues to work, in any case hum. When we pull the plug, the problem is different: the device turns on for a good few minutes. In the meantime, you don't want to watch.
    there is no coincidence between what is written on the buttons on the remote control and what actually happens when a given button is pressed. There is some logic in it known to people who work on it every day, but not to the person who comes and without prior training simply wants to watch TV. I tried to scroll the advertisements with the buttons >> and
  • #2 15445086
    KIEROWCA_VW
    Help: 273
    Rate: 676
    You can't handle it, sell it.
    You cling to equipment that works under different conditions than it was designed for.
    If you want properly working equipment with such capabilities, spend 2-3 times as much at least.
    Secondly: you probably have a "media" image on board, in which sellers stuff everything they can - it is surprising that this decoder does not sew or cook.
    Upload something light, place it under yourself and then you will like it, unless you don't bring work home ...
  • #3 15445386
    damago1
    Help: 12
    Rate: 29
    Is there any info on how to upload and configure some lightweight nbox version? What image, where to get or which specific forum to look at?
    As I wrote at the very beginning, I do not want equipment with "such capabilities", but equipment that will allow you to watch TV. From the advanced possibilities, I only need a pause (timeshift) because that's how I watch to avoid tons of ads.
    Due to the fact that I did not find a suitable review before buying (I would certainly not buy one if I knew what it looks like), I fell for the Allegro seller that it would meet my needs. Especially in terms of stability (linux = stability).
    So I wrote a review for others who quite accidentally and probably in the great minority but just want to watch TV on non-hanging equipment.
    However, if someone can help me reduce it to such a subset of functionality that is working and proven, I will be grateful.
  • #5 15453040
    marko888
    Help: 15
    Rate: 66
    Lots of advice and an appropriate system here but also registration required.
  • #6 15453073
    Darek.S
    Help: 216
    Rate: 978
    Graterlia, due to the fact that she is naked, will most likely require at least Oscam to be played. I personally am a supporter of OpenPli, although I have to admit that sometimes they got muddy. Another thing is that in order for these tuners to run steadily, they must be fully functional and their common problem is electrolytes. It is true that the sellers ensure that they are replaced, but it can be different. And they usually replace the key ones and there may be more damaged ones.
  • #7 15453187
    arecki09
    Help: 17
    Rate: 41
    Nbox is really thankful hardware for the money. If we just want to use it for "human" viewing, just upload OpenPLi 8.6.0. which has already installed what you need and you just need to apply the card from the splitter and hey. And in order for the fan or disk to go to sleep in standby mode, just set this option in the menu. And this decoder does not have a deep sleep state even in the original software. If you want something hyper extra full option, you have to take into account a target of 600+, not 150.
  • #8 15453296
    Darek.S
    Help: 216
    Rate: 978
    arecki09 wrote:
    And this decoder is not in deep sleep
    My old linux DMM7020S was in this state but it had to be run via the menu. And turning it on took as long as when it was completely disconnected from the mains. Now I have a strip and I simply turn off the entire equipment for longer breaks in viewing, which saves not only electricity (Nbox 20W on "standby") but also the above-mentioned electrolytes.
    Added after 50 [minutes]:
    arecki09 wrote:
    and just apply the card from the splitter and hey ..
    And if you have two, you don't even need a splitter :D
  • #9 15454152
    arecki09
    Help: 17
    Rate: 41
    Let us not delve into these areas for the author, because for him registration on a forum is an impassable barrier, what is the oscama configuration. And remember that this is an alternative software and not its factory because it did not have such an application at the factory ;)
  • #10 15454288
    Darek.S
    Help: 216
    Rate: 978
    Let's not exaggerate. He has signed up for Elektroda :wink: . And when he implements, he will not want anything other than Enigma :D
    This is absolutely true, but also that it is a construction from almost a decade ago.
    Such VU2Solo or DMM7080 run several times faster and also work. But they also cost several times more and the latter is a whole row more :|
  • #11 15454397
    kiko80
    Help: 67
    Rate: 163
    I can recommend PKTeam and nothing hangs there, just read, set it up and it works
The discussion revolves around the user experience with the nbox decoder running Enigma2. The user expresses frustration with the device's lack of plug-and-play functionality, requiring extensive configuration to display channels. Despite being a programmer, the user faced software crashes and instability, contrary to expectations of a stable Linux-based system. Other participants suggest using a lightweight image like OpenPLi 8.6.0 for better performance and stability. They also discuss the importance of proper hardware maintenance, such as replacing electrolytic capacitors, and recommend forums for further assistance. The conversation highlights the balance between cost and functionality, noting that higher-end models offer better performance but at a significantly higher price.
