Nbox HDTV Recorder BZZB: Non-Invasive ENIGMA2 / OpenPli 8.6 Installation Queries
MAREK10747 8685 4
  • #1 16726790
    MAREK10747
    Rate: 11
    Hello . Recently, I have stated that since I became the owner of the Nbox HDTV RECORDER equipment and I own it, I will write to him an enigme. The problem is to download it as not as invasively as possible for nandu so as not to move it and the processor, where the BZZB series complicates me a bit with the installation of an enigma. Here I have a few questions:
    1. I have an unprocessed and factory decoder from the store, I want an enigma version 8.6 (I have downloaded to my computer), and here I have a question whether I need to lose money and send it somewhere so that someone uploaded my enigma or do I need a lot of magic here and I can brick the equipment and better not touch it ????
    2. Can I, without any equipment, etc., if I need it, upload an enigma, if not permanently, then at least to the disk to boot from it, so that I can use the decoder normally without short circuit ????
    3. Does anyone have enigma 8.6 or older on this Nbox and could describe to me how the enigma works compared to the original ????
    Added after 13 [minutes]:
    Added after 4 [minutes]:
    PS how to make MODCHIP ????
    I also read it https://www.elektroda.pl/rtvforum/topic3121817.html#15186933
  • #2 16728134
    charlee
    Help: 30
    Rate: 135
    You can buy a modchip plate on an allegro (about PLN 120) and solder yourself, after soldering you will install the appropriate enigma yourself (descriptions are on the web), you will not make the tiles yourself, there will be no details in the network and if someone makes money on it, they will not give you a patent for free .
    At the purchase price, the tiles can install it and upload the software - the matter of sending a decoder.
  • #3 16728640
    aldiro
    The modchip plate alone will not give you anything, you need to upload to NOR and will not do it alone.
    the board itself costs PLN 20 instead of PLN 120 it is a service for processing under e2 with a modchip plate
  • #4 16728967
    charlee
    Help: 30
    Rate: 135
    Fact - my mistake, you can buy the programmed memory for PLN 10, it remains a matter of exchange.
  • #5 16729716
    MAREK10747
    Rate: 11
    As for this post, I will not contribute anything to it, I am closing the topic.
